Newbie engine swap questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by nathandex, Sep 1, 2010.
  1. Sep 1, 2010 at 11:44 AM
    nathandex
    nathandex [OP] Well-Known Member
    nathan
    illinois
    02 sr5
    Hey eveyone. i was wondering if any of you have or know someone who has succesfully swapped our engine for a larger one..i have the 3.4l v6 and when i come back from afghanistan was thinking about swapping it for a tundras 4.7 or similar.... my knowledge is not extensive (i mean i know my way around but never done a project this big before) and so i probably will either be getting some help or paying someone to do it. does anyone have any guesstimate on what a project like that would cost if i paid a mechanic to do the work? otherwise ill proly purchase a crap car to get me to work until its finished and do it myself (which would take along time bc it would b dictated to my helps availability as well as my own). any and all help would b appriciated!!
  2. Sep 1, 2010 at 11:46 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :popcorn:
    With enough money anything is possible. It would be pretty damn cool if you can pull it off.
  3. Sep 1, 2010 at 11:49 AM
    nathandex
    nathan
    illinois
    02 sr5
    im not too worried about the money, and id rather do it myself with someone to guide me. i am interested in it being a learning experience as well...
  4. Sep 1, 2010 at 11:53 AM
    nathandex
    nathan
    illinois
    02 sr5
    but its def a plausible idea right? and do u think the tranny i have would b compatible with the 4.7l? or would i b lookn at swapping that out too?
  5. Sep 1, 2010 at 11:53 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    go for it man. i like to see the 1st gen. with a v8 motor.
  6. Sep 1, 2010 at 11:55 AM
    Jester243
    Dan
    Spokane, WA
    I would guess you would be replacing everything, motor, tranny maybe want to go to a heavier rear end and ECU. Do you have a place to do any fabrication work or can you build motor mounts on your own?
  7. Sep 1, 2010 at 11:56 AM
    nathandex
    nathan
    illinois
    02 sr5
    my thoughts exactly....i love this truck but giving it a v8, in my mind, could only make it that much bettter. ok say i undertake this as a project. worth it to buy a brand new engine or better to find a used one?
  8. Sep 1, 2010 at 11:58 AM
    Jester243
    Dan
    Spokane, WA
    If money were no object I would go with a new "built up" motor myself.
  9. Sep 1, 2010 at 11:58 AM
    nathandex
    nathan
    illinois
    02 sr5
    i was imagining a much higher number...didnt want to spend more than 10k or so if i do it myself (was what i was thinking)...and no i couldnt build mounts on my own
  10. Sep 1, 2010 at 11:59 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    take the frame and cut everything off the bottom. weld on everything from a tundra, slop in the new motor wiring and trans BAM!!!! done 20 minutes max!
  11. Sep 1, 2010 at 11:59 AM
    nathandex
    nathan
    illinois
    02 sr5
    what do you meab by built up?
  12. Sep 1, 2010 at 12:00 PM
    nathandex
    nathan
    illinois
    02 sr5
    wolfgang; hahaha thats not quite the same is it?
  13. Sep 1, 2010 at 12:01 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Go on TTORA or Desert Rangers. There are plenty of guys there that have done swaps to different motors. No one on TW that I know of has does one so you will find better info in other sources.
  14. Sep 1, 2010 at 12:03 PM
    nathandex
    nathan
    illinois
    02 sr5
    ok ill check those out now...im at work, nothing else to do anyway lol
  15. Sep 1, 2010 at 12:11 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    If, when, you do this.... take a lot of pics and keep a journal of parts, cost and special fabs needed. I know I would love to see/read your build process.
    :popcorn:
  16. Sep 1, 2010 at 12:13 PM
    nathandex
    nathan
    illinois
    02 sr5
    i think i found someone who should b able to help :) ima try to contact him. obviously this project wont b done for along time..im b in afghanistan for a year but ive been lurking on this site for a bit and it has been rly helpful on other areas so ill def take pics and post on here when it does happen...lookin like a 99% likelyhood its goin to ;p
  17. Sep 1, 2010 at 12:15 PM
    cankel
    cankel Well-Known Member
    Texas
    09 Tacoma White DC SB TRD-Off Road 4x4
    ARB Bumper , spacer lift, kumho A/T, TRD Sport Hood
    why not just get the supercharger. youll get the power, its from the factory, you are still covered by toyota,not as expensive,and you could probably do it yourself. Although the V8 would be pretty cool
  18. Sep 1, 2010 at 12:18 PM
    nathandex
    nathan
    illinois
    02 sr5
    thought about supercharger... its just not the same tho...and ur last sentence says it all :p
  19. Sep 1, 2010 at 12:23 PM
    cankel
    Texas
    yes it does lol, hey going back to the swap you might also need to reinforce your frame, all the torque and the weight of the V8 might cause some damage
  20. Sep 1, 2010 at 12:32 PM
    nathandex
    nathan
    illinois
    02 sr5
    i understand the implications... i will in essence be building an entirely different truck...but rly if im going to put that much work into a vehicle what makes u think i would try to sell it??!! and there are alot of reasons why id like to do it, i do use my truck for " Racing, mudding, rock crawling"....not so much racing i guess...but that last two...must u b so negative?? jeeze......and thanks cankel, yea i was wondering about that too im lookin at those forums dude gave me earlier, there is more info on them about all the headaches im goin to have..i cant wait! lol
