Newbie Exhaust Questions
Discussion in 'Performance and Tuning' started by Jigzor, Sep 16, 2009.
  1. Sep 16, 2009 at 2:32 PM
    Jigzor
    Jigzor [OP] Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    I am going with a Flowmaster 40 Series Delta Flow muffler. I have a couple questions.
    1. What is the stock exhaust piping size on a '08?
    2. I would also like to have dual side exit, which would you recommend?
    Center inlet/dual out or offset inlet dual out?
    3. What size outlet do you recommend?
    4. So many exhaust tip available, I chose flowmaster because it does not sound 'ricey'. Which type of tip and size would give me the deepest sound?
  2. Sep 16, 2009 at 7:31 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    the pipeing is 2.25 inch inlet and outlet. running a Flowmaster is bad for performace, if your wanting something for sound then this is what you need. if your going for performacne, get a magnaflow
