Newbie help: tire purchase
Discussion in 'Wheels & Tires' started by tacochessee, Jan 7, 2024.
  1. Jan 7, 2024 at 7:28 PM
    tacochessee
    tacochessee [OP] Member
    Josh
    ‘20 TRD Sport
    3/2 leveling kit, aftermarket wheels and tires
    My first post and I’m humbly asking for guidance. I have a 2020 Tacoma TRD sport with 3/2 leveling kit installed.
    I purchased a set of slightly used wheels with 255/80/17 Toyo open country A/T’s and now I need new tires. I don’t know a lot about tires so here are my questions.
    Why are the 255/80/17 tires less available? (I can get them but they are more expensive)
    Is this size made for a particular purpose?
    I have used the tire size calculator and found several that are close in comparison. However, I like the 255/80/17 on the calculator the best. Based on experience and my current configuration is there a tire size you would recommend to replace these?
    Guys I am learning so I’m open to suggestions and constructive criticism. Thank you in advance.
    jd
    Tenmile Tacoma and Road_Warrior like this.
  2. Jan 7, 2024 at 7:50 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    That size is considered a “skinny” tire which is used by a lot of off road enthusiasts. There is alot of debate but many people will tell you that a skinny tire is better in a lot of off road situations than the wide tires that look “cool”.
    I personally have a 16” wheel and I run 265/75/16 tires. There are similar sizes in most tires for the 17” wheel. It’s a great size for a do it all truck. It might look a bit small with your lift, if that’s something you’re concerned about.
    If you don’t do anything crazy with the truck, a 275/70/17 tire would be a good practical size. It wouldn’t look too small but it won’t kill your braking/acceleration/MPGs too much either.
  3. Jan 7, 2024 at 7:58 PM
    tacochessee
    Josh
    ‘20 TRD Sport
    That makes perfect sense. I do like the look of the skinnier tires as opposed to wide tires or offset wheels (just my taste). I live in northwest Florida so I’m a flat lander but it is wet here. Most of the time I’m just going in and out of my hunting lease so nothing too crazy. Thank you for the info.
  4. Jan 7, 2024 at 8:28 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    255s will be taller, heavier and harder to find, they're generally a dually tire. 265s there are alot more options, they're cheaper and lighter. I've had 4 tacos and several different tire sizes/models. I honestly think they do best with 265s all things considered. Subjectively 255s look better, but you'll definitely see the MPG loss and feel the power loss from the taller, heavier tire. I'm on 16"s, so you'll have to translate your size.
    Edit: I only run E rated, I don't know how many options for non E Rated 255s there as they're usually a heavy duty truck tire. 265s you can still find in SL or P rated if that's what you're going for. Lighter tire, less off road puncture protection.
  5. Jan 7, 2024 at 8:57 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    235/80r17 is an LT tire size that will offer good protection and the lighter weight will not affect performance or mpg much. Going down slightly in size will not hinder performance, but going over stock dia. may. Heavy tires suck. Firestone Destination X/T s are great LT tires that are 40lbs and e rated.
    I'm really happy with mine so far. Running 215/85r16s. This tire also comes in a C rated 255/75r17 that is the same weight.
    Are your rims alloy? That makes a difference as well.
    tacochessee[OP] likes this.
  6. Jan 7, 2024 at 9:02 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    255/80r17 is popular because it’s a 33” tire and you gain the ground clearance of a wider 33” tire like a 285/70r17 without all the cutting and trimming to make the wide tire fit.
  7. Jan 7, 2024 at 9:11 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  8. Jan 8, 2024 at 4:03 AM
    tacochessee
    Josh
    ‘20 TRD Sport
    So I just got back from this rabbit hole. No idea and no idea that’s what I was a fan of. Thank you so much!
    Road_Warrior likes this.
  9. Jan 8, 2024 at 4:10 AM
    tacochessee
    Josh
    ‘20 TRD Sport
    They are Rock trixx RT113. Believe they are all aluminum if I am reading correctly.
  10. Jan 8, 2024 at 4:11 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
  11. Jan 8, 2024 at 4:17 AM
    tacochessee
    Josh
    ‘20 TRD Sport
  12. Jan 8, 2024 at 4:18 AM
    tacochessee
    Josh
    ‘20 TRD Sport
    I had no idea about tire ratings. So looking into this now!
  13. Jan 8, 2024 at 4:18 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
  14. Jan 8, 2024 at 5:52 AM
    tacochessee
    Josh
    ‘20 TRD Sport
    Road_Warrior[QUOTED] likes this.
  15. Jan 8, 2024 at 6:25 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    255 75 17 is also an option. They came on Rubicon wranglers for a while I believe.
    If I remember correctly they come in C load.
  16. Jan 8, 2024 at 7:28 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I gotta tell you the 265’s are really an amazing size. They don’t look super cool but I’ve driven all over North America with them and they preform fantastic. They’re the perfect functional tire for a daily driver that’s also a weekend warrior rig. As long as you aren’t doing any rock crawling they’re a good choice.
  17. Jan 8, 2024 at 8:39 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Tire size.com is a good website, you can put in your tire size and it brings up lots of options.
  18. Jan 8, 2024 at 8:40 PM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    Welcome to the forum
  19. Jan 9, 2024 at 7:03 AM
    tacochessee
    Josh
    ‘20 TRD Sport
    Thank you everyone for your responses. Even if I didn’t respond directly I have read every post and looked into what you all have suggested. It honestly has created a lot more questions such as tire ratings, and weight that I never even thought about. I still have a little time and tread left before I absolutely have to purchase, so I’m gonna research a little more. Thank you all
    Discount Tire likes this.
  20. Jan 9, 2024 at 8:27 AM
    Sharpish
    Brian
    Buying tires is the worst. There’s no such thing as the perfect tire. Don’t subject yourself to paralysis by analysis haha
