newbie help with tail light
Discussion in 'Lighting' started by Taco Tuba, Oct 10, 2009.
  1. Oct 10, 2009 at 10:16 PM
    Taco Tuba
    Taco Tuba [OP] Member
    Northeast
    Little Red Truck
    undercover
    I've just had my first pickup for a few days now and I'm very happy with it. I should have noticed at the dealer that this 05 reg cab red truck had a small prob. with the right rear light. The red part is lit but does not get brighter when the brakes are pressed. Left light and cab light are OK. Reverse lights ok too.
    1. Just replace the center bulb (I assume there are three bulbs in there?) Also wheres best place to buy?
    2. Access through the little panel on the side of the bed?
    3. I would need a special star shaped bit to get in there. Where could I get one?
    If I get access I'm sure the rest will be no problem.
    Thanks for your help.
    Steve.
  2. Oct 10, 2009 at 11:23 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    The tail lights come out with just a 10 mm socket wrench. Just twist the bulb holder and swap bulbs. You can pick these bulbs up from anywhere. You just need a new bulb, it seems like the brighter filament burnt out.
