newbie lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cwagner588, Jan 17, 2010.
  1. Jan 17, 2010 at 8:30 PM
    Cwagner588
    Cwagner588 [OP] Member
    Clint
    Marietta ohio
    silver 4wd 4cy
    3 inch lift 33s
    i have a 2007 ext cab tacoma 2.7 cyl 5 spd anyway i have the 3 inch lift kit by revtech with 33s and i would like to make it an inch or inch and a half taller i noticed today that the actual spacer in the front for the coil spring is only an 1 inch is a good idea to get a 2 inch one if so who makes it....and for me to make the back taller id just ad another leaf but idk about the front helppp
  2. Jan 17, 2010 at 8:46 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    you shouldnt do any higher than three inches in the front (if your a 4x4 which you are). end of story. the rear you can do whatever with really. I have an AAL and a 1 inch shackle lift. so my rear is taller than a normal 3inch lift kit
  3. Jan 17, 2010 at 8:51 PM
    Cwagner588
    Clint
    Marietta ohio
    silver 4wd 4cy
    3 inch lift 33s
    i just wish it sat a little taller...why is the spacer on the three inch lift only an inch?
