newbie needs advice for 5100's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by themouth, Apr 22, 2009.
  1. Apr 22, 2009 at 5:35 PM
    themouth
    themouth [OP] Member
    Long Island, New York
    2006 SR5
    A.R.E shell. Rigid light bar on Nfab mount.
    I've got a 2006 Double Cab long bed, SR5. It came stock with the 245 tires. I also have an ARE topper on the bed that adds some weight to the rear.
    I want to get a more aggressive look for my truck, as it appears a little wimpy with the 245 tires. I don't do a lot of offroading, just some occasional beach driving.
    I wanted to put the 5100's on all four corners to get a little lift, and add 265x75r16 tires. I have never gotten the rear leaf TSB done, and I am not dissatisfied with my current ride.
    After doing all the research that I could, I believe I have to add some kind of lift to the rear to get the truck level if I want to set the fronts at 1.75". My question is, do I need to get the TSB rear spring fix, or can I add a spacer (or block, I'm not sure of the correct term) to the existing springs? I am still under warranty. Could someone advise me of what my options are/what to do? Any help would be appreciated.
  2. Apr 22, 2009 at 5:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I think at 1.75" front lift, you should be sitting pretty level. For a rear lift, if you cant get the TSB springs, choose an AAL over a block.
    Welcome to TW! :)
  3. Apr 22, 2009 at 8:35 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Interestingly enough, I said this in his other thread (didn't realize the multi threads):
  4. Apr 22, 2009 at 8:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good advise. :)
