Newbie needs help with tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hellonweels89, Jul 9, 2016.
  1. Jul 9, 2016 at 5:15 PM
    Hellonweels89
    Hellonweels89 [OP] Active Member
    Reno, NV
    2010 Regular cab 2.7L, 5MT
    Fox Racing 2.5 with ext. reservoir, King 700lb springs, Pro Comp UCA, OME progressive leaf springs, Nitro 4.88's, Yukon Posi rear, Relentless front & rear bumpers, Avid sliders
    Hey guys, I have a 2010 4wd access cab with a front end level (spacer) and no fender flares. I was going to get 265/75's but someone at 4Wheel Parts told me I could fit 285/70's. I don't run fenders or mud flaps and I'm also getting new wheels 16x8 with a 3.6 bs. I think it might work but I've read through a lot of posts but I still can't seem to find an answer. Thanks in advance!
  2. Jul 10, 2016 at 4:04 AM
    Thebearded1
    Thebearded1 New Member
    2005 silver tacoma TRD Sport
    6 inch pro comp lift, after market wheels, 285/70/17 big horns
    I have a 05 double cab and I run 285 70 17 but I have a 6 inch pro comp lift. Just looking at the tire sitting in there... I don't think it will fit, even with a front end level (spacer). Just my two cents
  3. Jul 10, 2016 at 8:56 AM
    JLaScala
    JLaScala Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    265/75/16 will have no, to absolute minimal rubbing. Plus it looks killer with a level lift. :thumbsup:
  4. Jul 10, 2016 at 8:57 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Worst case you trim a little
    JLaScala likes this.
  5. Jul 10, 2016 at 9:05 AM
    Hellonweels89
    Reno, NV
    Thanks for the replies, from what a buddy told me most of the rubbing is on the fender flares and the mud flaps, which I took off. And with the added back spacing of the wheels I mentioned I figured the 265/75/16's would be fine, the guy at 4wheel parts said "I wouldn't run anything less a 285/70/16" and was very adamant about it. I'm not sure if he wanted the sale or if he knew what he was talking about. From what it sounds like though 285/70/16 will definitely rub and might not even fit so I'll probably go with the 265/75/16. Thanks guys!
