Newbie needs help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coachsmyth, Feb 9, 2024.
  1. Feb 9, 2024 at 11:40 AM
    Coachsmyth
    Coachsmyth [OP] New Member
    Scott
    2019 Tan TRD Sport
    2.5” Billstein lift, icon add a leaf, blackout kit for graphics
    Guys and gals, I’m new here and new to the 3rd Gen Tacoma. I am having an issue and couldn’t find good info in the search. So bear with me.
    I have tail lights and brake lights so it doesnt seem to be a fuse issue. I do not see any cuts or nicks in the wiring and haven’t added any components to the truck since I bought it used.
    My tag lights don’t work. Other than bulb, which i will check on today, what else could it be? Where do I start that is simple for the non mechanical types?
    Thanks for your help and the inevitable smart comments that will follow! :)
  2. Feb 9, 2024 at 11:43 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    OP- I’m assuming you’re referring to the rear license plate lights? If so, check bulbs first. Are there any aftermarket electrical upgrades to the truck? People have issues running aftermarket electrical components(our ECMs hate any fluctuation in signal strength).
    Have you checked the FSM?
  3. Feb 9, 2024 at 11:44 AM
    OkieTom
    OkieTom Member
    White 2020 SR5
    Yeah, definitely check the bulb. Could also be a loose connection somewhere. Maybe even some corrosion but that's less likely.
    Also, if you have a multi-tester check for voltage if the bulb appears to be OK.
  4. Feb 9, 2024 at 1:50 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Are your headlights on? ;)
  5. Feb 9, 2024 at 1:51 PM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    Welcome to TW.
