Newbie question about lockouts for 02
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dutchman, Apr 12, 2011.
  1. Apr 12, 2011 at 5:19 PM
    Dutchman
    Dutchman [OP] Active Member
    Up North
    02 2.7 5sp SC 4X4
    Is it a worthwhile mod to do?
    Knowing the shafts and cv's are spinning all the time it seems (to me) that L/O hubs would be a good way to go.
    If this mod is more or less common could someone point me out to what hubs are best?
    Thanks!
  2. Apr 13, 2011 at 5:50 AM
    silverstar
    silverstar Active Member
    Dave
    Bloomsburg, PA
    I'm not sure about the tacos but I know the L/O hub conversions for the fords and dodges are SUPER expensive!
  3. Apr 13, 2011 at 6:20 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
  4. Apr 13, 2011 at 8:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Like a solid axle swap with lockout hubs. :D
    Sorry, had to mention it.
  5. Apr 13, 2011 at 8:52 AM
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    All that is rotating is the CV shafts in 2x4, the rolling resistance is not really all that different. I love lockout hubs for their reliability and assurance, but it's just not worth the money on these trucks. I'll be putting up a writeup sometime in the near future on how to use ADD like cab mounted lockout hubs (with the ability to keep it unlocked and locked as well as the factory auto position).
  6. Apr 13, 2011 at 3:50 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Would this be so you could have L2 (2WD Low Range)?:cool:
  7. Apr 13, 2011 at 8:28 PM
    JeffsJeep04
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    Yup, gains 2 lo and allows you to keep it locked in so 4wd shifts are much easier when it's cold.
  8. Apr 13, 2011 at 9:17 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I did alot of research on this and decided against it.
    #1 the lock out hub is weaker than the add hub. People who have run manual hubs have blown the hub out multiple times. This kind of failure is way less common on ADD hubs. IMO the benefits are not worth just one blow hub if that happens on a trail your up the creek. I would much rather have to replace a Cv on the trail than to find a replacement spindle.
    #2 If you arn't religious about locking your hubs and driving around for awhile you may have problems with SPS "stagnant parts syndrome".
    #3 It is way cost prohibitive unless you find a truck in a junkyard.
  9. Apr 13, 2011 at 9:25 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    IF you really want to have 2low and have a pushbutton 4wd shifter its super easy:cool:
  10. Apr 14, 2011 at 4:44 AM
    JeffsJeep04
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    It's not hard with the J-shifter either...but yeah, not nearly as easy as with the push button.
  11. Apr 14, 2011 at 7:33 AM
    David K
    Is there a 2-Low Mod for 2nd Gen Tacos?
  12. Apr 14, 2011 at 8:12 AM
    JeffsJeep04
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
  13. May 20, 2011 at 3:14 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    The boots wouldnt wear but from what i have heard over 3 inches can cause cv's to bind. Binding = breakage.
