Newbie question and yes I searched and read stickies 1st.
Discussion in 'Suspension' started by wolverine768, Mar 27, 2013.
  1. Mar 27, 2013 at 5:30 PM
    wolverine768
    wolverine768 [OP] Well-Known Member
    Los Angeles
    Baja in White
    I am going to be the owner of a 2013 double cab long bed. most likely a trd sport. I had a few questions.
    1. Can I do icon coil overs in the front and not touch the rear to just run a winch bumper(with winch) and some bigger tires on stock 17" trd rims (265 70 17)?
    2. will my ride suck if I do this?
    3. What other likely problems may I encounter? Looking to do mild offroad(like trails around big bear/ gorman, etc)
    thanks in advance!
  2. Mar 27, 2013 at 5:34 PM
    wolverine768
    Los Angeles
    Baja in White
    ooops 4x4!
  3. Mar 27, 2013 at 5:37 PM
    beerking
    beerking Well-Known Member
    Trey
    Utah
    09 Access V6 TRD Sport
    All-pro APEX front bumper, 4xInnovation sliders w/kickouts, ATO front skid, Smittybilt XRC-8 winch, Icon 2.5 Front coilovers with 700lb King shocks, 5100's on the rear, TSB Toytec AAL, slimcubby HID headlights, debadged, Magnaflow muffler, AFE drop-in, Python 991 Remote start/alarm, Clarion NX501, Wet Okole's, Weathertech digifit floor mats, Midland CB, Blue 4' Firestik II, Tailgate anti-theft mod, power tailgate lock, rear differential breather relocation & yellow wire mod.
    You should be fine running a setup like that. Depending on the total weight up front, you may way to upgrade to beefier springs, but with only a bumper and winch the standard 650# icon springs should be fine. Especially if you use synthetic rope instead of a cable.
  4. Mar 27, 2013 at 5:38 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    1 Yes
    2 No
    3 You can adjust the lift height on the Icons. Depending on tire size and wheel choice and degree of offroading, you will have to trim. I dont wheel mine and have 2.5'' lift from Bilstein 5100's and run 285/75/16 BFG KM2's and only had to remove the flaps from the front of the front wheel well. If you are looking to wheel it, CMC and trimming will be required.
