newbie to anything dealing with lifts
Discussion in 'Suspension' started by ckeeton, Nov 10, 2010.
  1. Nov 10, 2010 at 7:04 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  2. Nov 11, 2010 at 11:36 AM
    ckeeton
    ckeeton [OP] Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
  3. Nov 11, 2010 at 1:23 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Yeah. I assume those come with the dust cover boots, but you better make double sure, as I've heard some suppliers sell the struts without the boots included. Also would be a good idea to get a replacement bushing/washer kit for each strut. Toytec.com sells the bushing kits in pairs (one kit for both front struts) for $20. Since you say you don't know much about this stuff, it would be a good idea to read some of the how-to threads buried in this forum. Try starting with a search for "5100 install" and read up.
    In general, a popular affordable way to lift a Taco around here seems to be 5100's front and rear with rear add-a-leafs, and new wheels with reduced backspacing if you want to run bigger tires, or you can run the stock wheels with bigger tires if you use Spidertrax wheel adapters ($90 a pair at 4wheelparts).
  4. Nov 11, 2010 at 1:29 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Only need wheel spacers or rims with different backspacing for 285 and wider tires. I have 255/85/16 (33" tire) on stock rims with no issues. You can also get a 265/75/16 which is roughly 32" tire.
  5. Nov 11, 2010 at 1:32 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    So could I get 5100s in the front for a little raise, then just add a leafs for the back?
    what bilsteins are on the back? and why do alot of people get "Bilstein 5100s All Around"? I also don't know much about lifts
  6. Nov 11, 2010 at 2:53 PM
    ckeeton
    Duluth, GA
    just from reading i think thats what some people do. being the 5100 up front and AAL in the back
  7. Nov 11, 2010 at 2:55 PM
    BenWA
    Boston burbs
    Yes, you could just get them for the front and AAL's for rear, using your stock rear shocks. But the rear 5100's provide a better ride and have better dampening over rough terrain than the stock shocks. The rear 5100's are just shocks, not struts and they do not contribute to lift in the rear -- the AAL's do the lifting. The front 5100's are height adjustable struts that are designed to work with your stock coils and they actually provide lift, if one so desires.
    S.B. is correct above -- you only need wheel adapters/spacers or different wheel backspacing if you are running 285 or wider, or if you want a wider stance while sticking with narrower tires.
