Newbie wants to put bigger wheels and raise truck
Discussion in 'Wheels & Tires' started by demirm, Mar 18, 2008.
  1. Mar 18, 2008 at 1:42 PM
    demirm
    demirm [OP] New Member
    2003 Tacoma SR5
    Hi everybody. Great forum and I'm so happy I found this. Thanks in advance for all your help.
    First off, I know very little about raising trucks and bigger tires. I have a 2003 Tacoma SR5 with access cab and I want to raise the truck. Basically give it a prerunner look not monster truck. I just want to add a little style since it looks so lame right now. I will probably never go off roading. Only city driving.
    The wheels I have on it are 15". I would like to go with bigger wheels - probably 16" and no more than 17". Can I do this? Also, the current wheels on it have only 5 lugs and all the bigger wheels I find for the tacoma are 6 lug. I did find on Tundras they had 16" wheels with 5 lugs. Could I put these wheels on my Tacoma?
    As far as raising the truck, some guy told me that based on the look I'm going after I could just do a leveling kit. With the bigger tires and raising the front so that it is level with the back should be fine. What do you think? Any thoughts would be appreciated.
  2. Mar 18, 2008 at 7:06 PM
    ahigginsdeca
    ahigginsdeca Higgins
    Alex
    Fort Collins, CO
    08 TRD shortbed
    3" Revtek Suspension Lift with a rear aal, 285/70/17 Pro Comp Xtreme M/T & Pro Comp Extreme Alloy 7189 wheels, magna flow exhaust, CB with dual antennas, AFE Cold Air Intake, CB Radio with dual antennas and a bull horn
    You could go with a leveling kit, which can look pretty nice, but I like to do it right. :) I just put a 3" RevTek lift on mine and it's not anything big, but it looks really good...at least I think so. I also put on new 17" Pro Comp wheels along with some 33" tires and am extemely happy. I've seen plenty of people put on a 2" lift with 32" tires, but I think the extra inch on each makes it look a little bit better, but it also cost more. A lot of it depends on how much you want to spend...
  3. Mar 19, 2008 at 8:27 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Fabtech makes a 3.5 inch lift kit for the 95.5 to 2004 5 lug tacos.
    Here are the specs.
    95.5-04 TACOMA 5 LUG
    • 3.5” PERFORMANCE SYSTEM
    • 30/9.50R15 TIRES 15X7 WHEELS W/3 3/4” BACK SPACING
    here is the website, if you get it post up picks I like the look of lifted 5 luggers.
    http://www.fabtechmotorsports.com/applications/toyota/2wd95-04tacoma5lug.html
    Pic of the truck lifted.
  4. Mar 19, 2008 at 10:44 AM
    demirm
    2003 Tacoma SR5
    Thanks for your help. Unfortunately, I am really trying to go the budget route and can't drop too much cash.
    For example, I found these wheels and tires below that came off a tundra. Can I just swap my old ones out and put these on my truck?
    http://losangeles.craigslist.org/sgv/pts/610823590.html
    Also, a guy will charge me $400 (everything included) for installing a leveling kit. Is that a good price? I'm hoping I could get those wheels, do the leveling kit, and only have spent $800 to give my truck a new look. What do you think? Please let me know.
    And finally, does anyone know what the bolt pattern size with offset is for my 2003 toyota tacoma sr5 2wd with an access cab? I keep finding mixed info. Please let me know.
