newbie wheel questions...
Discussion in 'Wheels & Tires' started by islandyoda, Jul 18, 2012.
  1. Jul 18, 2012 at 6:51 PM
    islandyoda
    islandyoda [OP] Member
    Victoria, BC
    2009 dclb TRD Sport 4x4
    I'm considering wheels for purchase, which of the 2 wheels will stick out more from the side of the truck? a wheel with 4.5" backspace or a wheel with 5" backspace will stick out more? :eek: yes, im new lol...
    Will I need new lugs with either of the 2 wheels? or is there anything else I might need if i purchase one of these wheels?
    http://www.procompusa.com/prodDetai...883&catID=11&subCat=210&ptID=100073&plID=3635
    http://www.racelinewheels.com/p-550-893-monster-black.aspx
    Any help or advice is gladly taken!
  2. Jul 18, 2012 at 10:27 PM
    Parsec42
    Parsec42 Well-Known Member
    Tyler
    Oregon
    98 Tacoma SR5 V6 4x4
    UWS low pro black, Wet Okoles, Eibachs, Bilstein 5100, Total Chaos UCA, Wheelers 5-leaf pack, deck plate mod & Afe Pro Dry, plastidipped badges
    Both wheels actually stick out the same because although the raceline is an inch wider it has 0.5" more backspace so they are even. I would be wary of the procomp because it is lug centric and some people have issues with them because of that.
    Do you plan on lifting and adding larger tires? If not, make sure your tires are approved for a 9" wide wheel as not all 265/70/17 tires are.
  3. Jul 19, 2012 at 6:45 AM
    mrbee2828
    mrbee2828 Active Member
    BJ
    Virginia Beach
    I just looked up the difference and wasn't aware of the different types of balancing. Thanks.
  4. Jul 19, 2012 at 9:22 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    Tyler is correct, both wheels are pushed out about 2" more than stock. Do a google search on lug centric vs. hubcentric wheels and you see what he's referring to.
