Newbie with a newbie question Oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by XR1200Tom, Apr 27, 2022.
  1. Apr 27, 2022 at 3:30 PM
    XR1200Tom
    XR1200Tom [OP] Member
    I have several vehicles and was recently given a low mileage 2016 Tacoma, 3.5, crew cab.
    In changing the oil, after watching several youTubes , I gathered my tools and set to work.
    After removing the skid plate and the oil drain plug I moved to the filter canister. I used the 3/8ths drive extension in the canister drain plug but the ENTIRE canister turned. So instead of removing the canister drain followed by removing the canister, I just took them off together.
    I don’t see how it may make a difference but I just wanted to check. I replaced the filter insert and big O-ring but never removed the canister drain plug.
    Surely I’m not the first person to experience this .... I tried the search function but didn’t see anyone else with this prob.
    Is there any reason I should worry about this?
    Thanks!
  2. Apr 27, 2022 at 3:34 PM
    AZ_J
    AZ_J Well-Known Member
    Ahwatukee, AZ
    2019 TRD OR 4x4 DCSB
    265/75r16, sliders, softopper, roof rack, 6112/5160's
    whats the question? Refer to the manual. google is your friend
    wilcam47 likes this.
  3. Apr 27, 2022 at 3:41 PM
    XR1200Tom
    Typing on my phone and the message submitted before it was complete. But thanks for the Google advice ...
    CG256 and Skydvrr like this.
  4. Apr 27, 2022 at 3:47 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    That drain plug is there just to make it less messy removing the canister. I don’t think you will have any issues if you just leave it. At the most, it might start a slow drip after a while.
    I do replace mine everytime though, never had issue with it being stuck.
  5. Apr 27, 2022 at 3:48 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nah you’re good. Only issue is a potentially bigger mess. Easiest way to get that smaller plug off is to smack the ratchet with your hand or rubber mallet or something. The main canister can only spin so fast because its own oring, so if u give it a little shock, it’ll usually loosen up. Don’t over torque anything. It’ll become a pain next oil change
    JmsWms, splitbolt, Tacospike and 2 others like this.
  6. Apr 27, 2022 at 3:49 PM
    XR1200Tom
    Thanks amigo!
    Skydvrr likes this.
  7. Apr 27, 2022 at 3:51 PM
    XR1200Tom
    Thanks, just looking for the peace of mind.
  8. Apr 27, 2022 at 3:51 PM
    Tacospike
    Two Trucks
  9. Apr 27, 2022 at 3:53 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Lube the o rings and dont overtighten things and your good
    XR1200Tom[OP] and Junkhead like this.
  10. Apr 27, 2022 at 3:57 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I'll still never understand why Toyota used this 1950's-canister-technology. It's idiotic. Gimme a spin-on every time....
    Evostaco and XR1200Tom[OP] like this.
  11. Apr 27, 2022 at 4:02 PM
    XR1200Tom
    Roger, that’s standard procedure, I’m all over it. Thanks!
  12. Apr 27, 2022 at 4:03 PM
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    YES
  13. Apr 27, 2022 at 4:05 PM
    XR1200Tom
    I agree but I had a 2001 BMW 528 with a canister system that was cool. The canister was on TOP of motor and easily accessible. Easiest oil change ever.
    JJ Diablo likes this.
  14. Apr 27, 2022 at 4:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Ease of manufacturing
    Junkhead and XR1200Tom[OP] like this.
  15. Apr 27, 2022 at 4:14 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Lots of oil change threads these days...
    The filter housing plug area, from what I've seen on YouTube, has a spring loaded valve (that's what I'll call it) for pushing that plastic plug in that allows oil to come out. (Pre-draining)
    I find it interesting that if you remove the canister & bypass the housing plug, there would be even more of a mess than where the plastic plug (that comes with the new paper filter) would insert to allow the oil to flow at a slower pace.
    I'm really looking forward to doing my own oil change so I can give an actual testimony here instead of visually explaining something I haven't done yet.
    XR1200Tom[OP] likes this.
  16. Apr 27, 2022 at 4:19 PM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    Sounds like the last person to change the filter took care not to over tighten. Usually from others, the experience is the opposite.
    It is not a bad idea to buy a spare filter canister. They can break or crack while trying to remove. They are not expensive and will save you a lot of aggravation if it breaks on a Sunday afternoon oil change.
    i agree with the others, no harm.
  17. Apr 27, 2022 at 4:22 PM
    XR1200Tom
    Thanks. I’ve been looking at some or the aluminum replacement options and those make a lot of sense to me.
    ThreeBeers[QUOTED] likes this.
  18. Apr 27, 2022 at 4:24 PM
    XR1200Tom
    I gotta say, I’m a member of several forums, mostly motorcycle and truck sites, but not all are as helpful as this one! Thanks everyone.
    tacoshell88 likes this.
  19. Apr 27, 2022 at 4:24 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Here's one I bought off Amazon in Jan this year...it was $40 then. It includes the housing plug.
    XR1200Tom[QUOTED][OP] likes this.
  20. Apr 27, 2022 at 5:00 PM
    XR1200Tom
    Ha! I’ll be getting one of those!
