Newbie
Discussion in 'New Members' started by dvinson, Sep 10, 2015.
  1. Sep 10, 2015 at 6:50 PM
    dvinson
    dvinson [OP] New Member
    David
    2004 Tacoma pre runner v 6
    lift kit
    Got my 2004 Tacoma pre runner in 2008. Great truck~
    She don't want to go
    Edit ConversationMark as UnreadStar ConversationLeave Conversation
    1. [​IMG]
      dvinsonNew Member
      Today
      David
      lift kit is the only addition
      She starts great. She runs great most of the time. Has began to stall out occasionally as you begin acceleration. It freezes..Back off the peddle and she romps out like a race car runs and idles perfect. I never know if its going to stall so now I wait for everyone before turning left in cross traffic. It has been getting worse. Last night I was ready to say uncle..It was stalling 80 percent of accelerations and i almost got rear ended. I filled up the tank and now its problem free. This issue has gone on through last 3 tanks. Perhaps worse when fuel is low....
      The truck has not thrown a warning.No rattles in the catalytic converter plus mileage is normal Any ideas.
  2. Sep 10, 2015 at 7:13 PM
    Mt_Habit
    Mt_Habit Member
    For how long has it been doing this? Did you make any changes to the truck prior to noticing? What kind of routine maintenance do you do?
    edit: sorry noticed you said last 3 tanks
  3. Sep 10, 2015 at 7:19 PM
    dvinson
    David
    lift kit
    no changes prior. The stall started very lightly.Yesterday it was to the point I thought it went dead. I have not changed fuel filter. All other maint done.
    No stall today after fill up..
  4. Sep 10, 2015 at 7:35 PM
    Mt_Habit
    Mt_Habit Member
  5. Sep 10, 2015 at 7:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm thinking the egr valve or maybe switch out the fuel pump relay if you can to see what happens. Check for pinched or burned wiring around the egr.
  6. Sep 10, 2015 at 7:49 PM
    dvinson
    David
    lift kit
    Thanks for the links. it could be a lot of things. It sees regular fuel injector cleanings. Plugs have 30,000 miles.
    I think with the addition of gas. I am eaning toward trash in the tank , blocking harder at low fuel levels
  7. Sep 10, 2015 at 7:55 PM
    dvinson
    David
    lift kit
    Seems like erg was changed about 9 months ago. but it threw a light with a code? Ill check thanks
  8. Sep 10, 2015 at 8:11 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Dunno, but a bigger penis seems to be a fix. :rofl:You called it a she. You lost all control once you did that. Pour a beer and chant football songs on it till you fall down and name it just before you become stuipid. Stupider more than I am right now. I'm stuipd drunk.:drunk:
