newer LED taillights on a 2008
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trucknrv, Apr 12, 2011.
  1. Apr 12, 2011 at 11:04 AM
    trucknrv
    trucknrv [OP] Member
    western mass.
    08 sr5 sport
    snowsport plow with front receiver hitch, access cover, avc ventshades, covercraft seatcovers, apc line of fire tailgate area led lights, husky floor mats, grillcraft grill, k-n filter, hydraulic lift arms for hood, rear backup cam located in front windshield mirror, ipod cable located in glove box, led cup holder lights and rear floor lights, factory black running boards, direct cable from battery for jumper cables, oil plug valve, lockable bed storage areas and prodigy brake control.
    Has anyone tried the new led lights (OE) on the newer tacomas on a 2008 that has the old red taillights? Are they just a plug-n-play cuz the dealer tells me they won't work on my 2008. I purchased some ctrusa taillights off of ebay and they set my ABS light on constantly after about 10 min. of driving and shut my cruise control off on the highway when I used my directionals. I have already sent them back for a refund. I guess I can't get aftermarket ones that won't screw with my ABS light? Thx in advance..:confused:
  2. Apr 12, 2011 at 11:15 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you tallights are messing with your abs you have a lot bigger problems than just trying to find a new set of tallights. Something in your electrical system is really messed up if that's happening
  3. Apr 12, 2011 at 11:33 AM
    trucknrv
    western mass.
    08 sr5 sport
    When I run with my OE taillights....I have never had a problem with ABS or cruise.....so that points to the aftermarket lights and not the truck! :confused:
  4. Apr 12, 2011 at 11:45 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    We put led bulbs in my cuzns crown vic and it blew a relay so the trans wouldn't come out of park. It had to be towed to dealer.
  5. Apr 12, 2011 at 11:48 AM
    cb0913
    cb0913 Well-Known Member
    Charlotte, NC
    2015 Red TRD Sport 4x4
    i put these on my 08 and have not had any abs problems
  6. Apr 12, 2011 at 11:51 AM
    KPT
    09 Prerunner
    Correct but there has to be an issue with the truck if the ABS electronics are in any way tied to the taillight wiring.
  7. Apr 12, 2011 at 11:59 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I have an 08' with 2010 led tails and have even spliced into the brake wire for my camper shell.
    0 problems....there is something else causing the issue.
    Az
