Newly Designed Brake Over Ride System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tracker, Jan 25, 2011.
  1. Jan 25, 2011 at 6:42 AM
    tracker
    tracker [OP] Active Member
    2008 4x4 doublecab long box
    Is there such a system? I read that that Venza and Tacomas now have this system that cuts engine power in case of simultaneous application of both accelerator and brake pedals. The reason I am asking is, I drive with winter boots and because of my big feet I can apply both brake and gas if not careful. With ABS the brake pedal goes down farther and at the same time if by accident I apply the gas pedal than stopping would be an issue. I own a 2008 taco and no problems until this happened when the road ended and the ditch started. The harder I pressed the faster I went.
  2. Jan 25, 2011 at 12:08 PM
    BCTacoma2010
    BCTacoma2010 Michigan Member
    Jay
    Southwest Michigan
    2017 Ford Platinum F150
    My 2010 had this done when the accelerator pedal recall was done and the ECU re-flashed. My guess is it is standard on the 2011.
  3. Jan 25, 2011 at 12:17 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Standard on half of 2009's and on. Brake override doesn't kick in until a certain speed (5mph-moving) so you can still do power brake launches on the strip. It also doesn't work if you apply the brakes before you apply the gas.
  4. Jan 25, 2011 at 12:22 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I love those Venzas. They are so nice.
    The brake over ride system is part of the gas pedal recall.
  5. Jan 25, 2011 at 12:31 PM
    DriverSound
    SoCaca
    Too few to list.
    In the same re-flash for the brake override includes the tranny shift point adjustment for automatics.
  6. Jan 25, 2011 at 12:32 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    You either have it from the factory (depending on year), or it gets done as part of the recall. Attached is a document that explains how it works.
  7. Oct 20, 2011 at 5:07 PM
    yarik83
    yarik83 Well-Known Member
    Yuri
    Florida
    2016 TRD SR5 DoubleCab 4x4
    Lift kit, weight distribution hitch. Camper shell. Kayak Rack.
    I hate to be the one to necro a thread but I have just almost not come back home because of brake over ride system. I got it installed during brake pedal recall.
    I was pulling out of the parking lot only to get cut off by a guy doing exactly the same from parking lot across the street. I hit brakes to slow down and like a second later want to merge into traffic before a vehicle that was still 300+ feet away. Nothing happens. NOTHING. Revs dropped waaaaay down and car slowly rolled. At this point I am still on the gas pedal and like a second or two afterwards my truck takes off like a rocket.
    Car that was 300+ feet away almost rear ended me because of this stupid recall thing.
    Sigh I miss the good old days when my ECU was not reflashed.
