Next Arizona Mod Day!
Discussion in 'Arizona' started by chris4x4, Feb 28, 2011.
  1. Feb 28, 2011 at 3:09 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im thinking in the next couple months. You guys want to throw some dates around??
  2. Feb 28, 2011 at 3:17 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    april 23? should be enough time to get my LT kit!.
  3. Feb 28, 2011 at 3:19 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    5/14-- EAAAAAAAST VALLEY!!!
    AZ
  4. Feb 28, 2011 at 3:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking end of April too..
  5. Feb 28, 2011 at 3:23 PM
    97yota4wd
    Eric
    Mesa, AZ
    i think it would be a good date! im okay with 5/14 also. as long as its not on the same weekend as one of my races like the last one was ):
  6. Feb 28, 2011 at 3:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    we'll throw some dates around, then get a location, and set up a poll.
  7. Feb 28, 2011 at 3:24 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    How do you guys feel about replacing a clutch and flywheel?
  8. Feb 28, 2011 at 3:25 PM
    97yota4wd
    Eric
    Mesa, AZ
    ^^ill watch and learn... haha
  9. Feb 28, 2011 at 3:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If no one else is doing anything, It doesnt bother me.
  10. Feb 28, 2011 at 4:23 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    April. /thread
    It starts to get warm outside in May. No me gusta.
  11. Feb 28, 2011 at 5:06 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I'm down for whenever...as long as i'm off that weekend. I'll be there :cool:
  12. Feb 28, 2011 at 5:07 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    April 23rd is KUPD's UFest, not sure how many people will be attending that...
  13. Feb 28, 2011 at 5:11 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I may be down depending on date... Would be a good time to do my AAL if people are down to help. May have some new springs by then as well.
    You guys can check out my leather seats ill be rocking by then.
  14. Feb 28, 2011 at 8:32 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Early is better May tends to get warm.
  15. Feb 28, 2011 at 8:35 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    How about we just do 1 persons truck and do a full build. Pull everything off, cage it, box the frame, engine swap to a 5.7L, full LT front end, rear links....
  16. Feb 28, 2011 at 8:39 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    Do you have anyone in mind Oliver?:)
  17. Feb 28, 2011 at 8:40 PM
    08pretaco
    az
    Hmm let me see how the drug smuggling business goes and my hoes are performing :rofl:
  18. Feb 28, 2011 at 8:56 PM
    97yota4wd
    Eric
    Mesa, AZ
    by then i will have my lt kit so we can do that! and i can learn how to pull my bedsides!
  19. Feb 28, 2011 at 9:42 PM
    03aztaco
    03aztaco Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
    what kinda lt kit you getting?
  20. Mar 1, 2011 at 1:08 PM
    97yota4wd
    Eric
    Mesa, AZ
    probably gonna go camburg unless i can get the money in time to buy nelson18matts
