Next best bed mat?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DaveInTahoe, Sep 28, 2023.
  1. Oct 16, 2023 at 12:32 PM
    #61
    mattyshum
    mattyshum Well-Known Member
    I also ended up getting a DeeZee on Amazon and it seems very good to me. Seems about same quality as OEM, and maybe even better considering the track's on it are entirely vertical which help with cleaning out the bed. Was also only around $100 versus the $150 for OEM too.
    #61
    pdxTacoSR5[QUOTED] and McHale like this.
  2. Oct 16, 2023 at 1:46 PM
    #62
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
  3. Oct 16, 2023 at 2:15 PM
    #63
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
  4. Nov 21, 2023 at 8:28 PM
    #64
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I just (about a week ago) bought a new double cab long bed Tacoma. I was planning to buy an OEM bed mat right away, but now see that is not possible. I’m not really happy with any of the aftermarket options. If I bought a SB mat, would it fit up to the tailgate and leave a 1 foot gap by the cab? I think I could live with that. Have the OEM tonneau cover, which covers the front ~2’ of bed anyway.
  5. Nov 21, 2023 at 10:04 PM
    #65
    tacoma_ca
    I just got the Dee Zee DZ86964 heavyweight bed mat off Amazon for my '23. It is no worse than the OEM bet mat. SB mat sounds like a nuisance...
  6. Nov 24, 2023 at 3:59 PM
    #66
    sark
    sark Member
    Mordoregon
    2022 OR AC
  7. Nov 24, 2023 at 4:17 PM
    #67
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    RIX TUX likes this.
  8. Nov 25, 2023 at 10:20 AM
    #68
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    How about Synthetic grass? It’s cooler to the touch in the summer time especially if you park your truck in the sun. Maybe your local hardware might have a scrap piece for cheap.
  9. Dec 14, 2023 at 11:15 AM
    #69
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    Based on your recommendation, I went to the DeeZee site and confirmed the DZ86964 is the correct match for my 2023 Tacoma long bed.
    This appears to be the same quality mat I have in my 1991 Truck that has lasted so very well.
    Your comment about directing water and debris to the rear and not to the sidewalls has significant merit.
    I have this mat on order from Amazon now.... thanks!
    #69
    tacoma_ca and pdxTacoSR5[QUOTED] like this.
  10. Dec 14, 2023 at 12:38 PM
    #70
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
    Functional and reminds me of caddy shack!
  11. Dec 14, 2023 at 12:43 PM
    #71
    pdxTacoSR5
    PDX area
    :thumbsup: i hope the quality has not degraded over the years. most likely it is the same. only issue i have with mine is it is heavy and my need for it is very small...so it sits in the garage most of the time and is easy to install when needed. for constant use, i'd be happy with it though.
  12. Dec 14, 2023 at 4:37 PM
    #72
    bgavin
    Orangevale, CA
    My need is more simple: set and forget.
    I've only had the mat out of my '91 a couple of times over 31 years.
    Just long enough to hose out the bed, let it dry and toss the mat back in.
    Amazon says it will get here in 4 days, so I will install and report back here.
    pdxTacoSR5 likes this.
  13. Dec 14, 2023 at 4:44 PM
    #73
    H4I2G0H
    H4I2G0H Access, 6spd
    PNW
    22 TRD SPORT, MT
  14. Dec 15, 2023 at 2:56 AM
    #74
    TacoTuesday1
    FL
    if you're looking for a bed mat,
    OEM bed mat.
  15. Dec 15, 2023 at 3:06 AM
    #75
    Doc62
    Dave
    SE Pennsylvania
    Unless you are looking for one for a long bed. My 21 came with it. When my son bought his 23 long bed, we found that the OEM long bed mats were no where to be found. And I tried.
  16. Dec 15, 2023 at 3:47 AM
    #76
    TacoTuesday1
    FL
    used is usually cheaper
    if not that then something thick
    The OEM one is pretty thick and grippy
    the problem is they seem to stay dirty even after cleaning
    Like turn things black that touch it
    bed rug is another good one
    Either full or semi size
    but usually goes hand in hand with some sort of cover whether that be tonneau, shell, Softopper, etc
    don’t know how they do exposed open
    But they are durable
    another full truck bed mat from a bigger truck would probably work if cut down
    That thick of rubber can be hard to cut though. OEM is. Boring holes to clear adding tie down hooks is a pain.
  17. Dec 15, 2023 at 9:30 AM
    #77
    Doc62
    Dave
    SE Pennsylvania
    I ended up getting him this one:
    https://www.amazon.com/dp/B0BCFKJWPN?ie=UTF8&th=1
    works just as good as my OEM one.
  18. Dec 16, 2023 at 6:27 PM
    #78
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    My Westin mat is 3/8" thick and has held up fine over the years parked outside every day and has held down fine with no adhesive/etc. It was around $100 in '19 if I remember.
  19. Dec 17, 2023 at 7:46 AM
    #79
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Find someone that has an electric tire knife. Makes quick work of the stall mat.
  20. Dec 18, 2023 at 7:17 PM
    #80
    TacoTuesday1
    FL
