Next best (cheapest) leveling solution instead of Billy's 5100
Discussion in 'Suspension' started by doeweb, Jul 24, 2015.
  1. Jul 26, 2015 at 11:42 AM
    Kevo526
    Kevo526 Well-Known Member
    Kevin
    Camp Lejeune, NC
    2015 White Tacoma DCSB SR5 4x4
    Bilstein 5100, OME 885s, Deaver AAL, LR UCA, 17x9in black rhino sidewinders w/ BFG KO2 275/70/17, SOS Concepts sliders and rear bumper, Nfab light bar mount w/ 30in light bar.
    How long have they been on your truck?
  2. Jul 26, 2015 at 12:27 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    They were on for about 13000 miles and no offroading with them jus stayed on the street
  3. Jul 26, 2015 at 12:33 PM
    Kevo526
    Kevin
    Camp Lejeune, NC
    Ill send you pm
  4. Jul 26, 2015 at 4:04 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    test drive didn't consist of his speeds to allow me to experience the shake.
    I have had wheel balancing done and alignments and it is the spacers.
  5. Jul 26, 2015 at 4:06 PM
    mahaloTaco
    Max
    Los Angeles
    @Justinlhc I don't quite understand what uca's do exactly. My truck already has the stock ones. whats wrong with those?
  6. Jul 26, 2015 at 4:11 PM
    mahaloTaco
    Max
    Los Angeles
  7. Jul 26, 2015 at 4:17 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Who determined the spacers are causing your truck to shake? And why? How much lift did you get from them?
    It's not possible for the spacers to cause your truck to shake. Even if it were, like I said, lifting with 5100's is going to get you the same results. Your control arms and alignment issues will be exactly the same.
  8. Jul 26, 2015 at 4:19 PM
    Justinlhc
    I got the SPC arms for $362 shipped. They can correct caster and camber issues.
    Rock Lobster likes this.
  9. Jul 26, 2015 at 4:19 PM
    mahaloTaco
    Max
    Los Angeles
    @Justinlhc toyota determined that was the cause... :confused:
    So I should get some control arms?
    I am almost out of money for a while but if I can get some inexpensive ones that would be great... @Rock Lobster
  10. Jul 26, 2015 at 4:22 PM
    mahaloTaco
    Max
    Los Angeles
    which spc ones?
  11. Jul 26, 2015 at 4:48 PM
    mahaloTaco
    Max
    Los Angeles
    Toyota told me that was the problem... I am not a mechanic man.
    I just assume what I am told is right...
    What do you think it is.... I know driving the truck would help..
    its more of swaying not shaking
  12. Jul 26, 2015 at 4:55 PM
    mahaloTaco
    Max
    Los Angeles
    That sounds like a better idea however I want to keep the height...
    But are you saying that if I take it to stock then I can see if there are other problems?
    I put 1" wheel spacers on.... can that make a car sway?
  13. Jul 26, 2015 at 5:05 PM
    mahaloTaco
    Max
    Los Angeles
    I think I have these..
  14. Jul 27, 2015 at 9:06 AM
    doeweb
    doeweb [OP] Member
    2011 Double Cab TRD 4x4
    Thank you everyone and especially for this link, I think I will bite the bullet and just get the Billy 5100s.
    Can someone assist with what I would need exactly, I have a 2011 Double Cab TRD offroad 4x4.
    I am thinking of getting the 885x coils set to .85 setting.
    Not sure what/why I would need the 4x4 diff drop for 30.00?
    Not sure exactly having or NOT having the UCA would be needed for?
    Also thinking of paying the extra 90 to have the strut included and assembled to dumb down the install for me and a co-worker.
  15. Jul 30, 2015 at 4:54 PM
    #35
    doeweb
    doeweb [OP] Member
    Thank you all for you help, I ended up going with the Billy 5100's ordering from above with the pre-built strut assembly. I choose to only go with the 2 inch lift which I believe is the 884X coils, 4x4 everything above except I did not get the UCA's, person on phone said I don't need that unless I go 2.5 or higher. We'll see, they are very helpful, she mentioned that a lot of guys end up cutting off the bolt off and replacing it with new ones and also recommended getting some C clamps to hold down the AAL.
    Anything else I should be aware of, buddy and I are going to try and tackle this.
  16. Aug 2, 2015 at 4:35 AM
    #36
    doorsidedown
    doorsidedown Well-Known Member
    Congrats. I just installed mine last week. You'll definitely need a 6" c clamp for the AAL. Enjoy the install, it's a lot of fun.
  17. Aug 2, 2015 at 5:13 AM
    #37
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Wait to find some used CO's
