Next gen LED lighting
Discussion in 'Lighting' started by alphabravo, Oct 2, 2015.
  1. Oct 2, 2015 at 12:36 PM
    alphabravo
    alphabravo [OP] Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Hi guys,
    Does anybody know what kind of technology is being used in the DRLs I'm seeing in the new Volvo, Jeep, BMW, Mercedes, etc? It looks like probably LED and is very white and very bright.
    TIA
  2. Oct 2, 2015 at 1:26 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  3. Oct 2, 2015 at 1:41 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    :notsure:
  4. Oct 4, 2015 at 12:14 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Those Jewel Eyes are pretty sick. Each "cube" shines at certain degree of angle which together covers the proper areas. I think Andrew was designing a version of this for the 2012-2015's at one point.
  5. Oct 6, 2015 at 8:09 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  6. Oct 7, 2015 at 2:00 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Cob are still in a somewhat unreliable and unstable state. I'm not sure if newer cars are using these or not but, if they are, the tech that goes into them must be far better than what's available to the general public. Because from the cob I've tried, and have read about from multiple sources, is that they are very unstable and have a short life span. If newer cars are using these then that tech needs to be implemented into the aftermarket stuff. I'm sure there's lots of factors that play into the reliability of them as to what's available to the general public and how they use them, but so far I'm not impressed and am anxious to try anything cob again.
    Edit: I think that most of the led drls in newer cars use independent leds and utilize special reflector technology to disperse the light more effectively. Kinda like the led light bars. Think of them like that, as mini led light bars. Independent leds inside a reflector housing. That's all it is. It's not just a board. It's a combination of premium leds with awesome reflectors. To which you'll never be able to replicate in older vehicles unless some kind of retrofit is possible. Which will be very expensive, and highly unlikely to accomplish a retrofit like that. But, cob is the latest thing (as far as I know) as far as trying to replicate that kind of tech.
    alphabravo[OP] likes this.
  7. Oct 7, 2015 at 9:01 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah you're absolutely right man. I spent like an hour searching for links about quality COB LEDs. You know its bad when the only thing that comes up is Alibaba and Ebay hits.
