Next Generation LED Technology - Meet the SL2 Pro LED Bulb | Diode Dynamics
Discussion in 'Diode Dynamics' started by Diode Dynamics, Mar 22, 2024.
  1. Mar 22, 2024 at 11:40 AM
    Diode Dynamics
    Diode Dynamics [OP] Automotive Lighting Experts Vendor
    St. Louis, Missouri
    Diode Dynamics set the standard for LED bulbs in 2017, with the introduction of the SL1 LED. The SL1 was the first bulb engineered to provide a true increase in performance. After many years, and thanks to improvements in technology, we are excited to introduce its successor: the SL2 Pro!
    The new SL2 Pro LED Bulb has been carefully refined and improved with some major upgrades: next-generation TST LED technology, an integrated top-mount fan, and a fully-integrated, wire-free design. As a direct plug-and-play replacement, it provides a significant increase in output, in a compact package.
    APPLICATION NOTICE: LED bulbs are legal in the USA for Fog Light use only. Not compliant with DOT / FMVSS108 and not street legal in the USA for Headlights. Legal for off-road use in ATV, snowmobile, and off-road racing use. International legality varies by country. Note: This usage regulation is not unique to Diode Dynamics bulbs. All LED bulbs from all brands, regardless of marketing claims, are prohibited from street use in halogen headlights in the USA. Click here to learn more.
    Next-Generation TST Technology. The SL2 Pro features new thermal separation technology (TST) LEDs. Unlike a traditional LED chip, TST LEDs are designed with electrical connections on the top. This means the entire bottom surface of the LED can be dedicated to channeling thermal energy out and away from the LED. This lowers thermal resistance, allowing the SL2 Pro to run at higher power levels than traditional LED bulbs, while maintaining focus.
    Optimized Optical Focus. Your vehicle's housings are designed to focus light. If the light source in the housing is out of focus, it doesn't matter how bright the bulb is - you won't have a focused hotspot of light to shine down the road where you need it. Instead, you'll have more glare, which lights up the foreground and makes it harder to see in the distance.
    The SL2 Pro LED bulb was engineered to focus light just like your original bulb, matching the original beam pattern while still providing an increase in total output. These days, some LED bulbs on the market use the smallest LEDs possible to accomplish focus, but this leads to "over-focus", where you begin seeing streaks, lines, and harsh cutoffs in the beam pattern. Instead of using the smallest LEDs possible, the SL2 Pro was optimized to provide a smooth and comfortable beam pattern, while still maintaining focus and increased output.
    Internal Cooling. The SL2 Pro features an integrated top-mounted fan for superior thermal management and reliability. Since the fan is sealed inside the housing, there's no concerns about damage from dust or moisture over time. And with the fan on the top of the bulb, the cooling happens right next to the LEDs - the source of the heat.
    While standard LED bulbs use heat pipes and other tricks to move heat to the bottom of the bulb, where it's cooled off, the SL2 Pro keeps it simple and more efficient. This provides maximum cooling efficiency and output.
    Fully Integrated Design. Unlike traditional LED bulbs, the SL2 Pro LED bulb doesn't have any extra wires or external drivers. Along with its compact size, that means excellent fitment inside your housing, without the need to tuck away wiring or bulky drivers. Installation is easy - simply remove your factory bulbs and the SL2 Pro will fit in its place, with a plug-and-play connector. And if your original bulb is installed at an angle, no worries - SL2 Pro has you covered with an adjustable collar that can be securely locked at the correct position. For specific fitment information, please see Vehicle-Specific product listings, or contact us.
    Reliability. Every part of the SL2 Pro LED was engineered for reliability, from its full metal construction to the fully-sealed design. The SL2 Pro was put through its paces in our environmental testing chambers - where the bulb lasted through repeated thermal cycles from -40 through 85 degrees Celsius (-40 to 185F), along with a range of other environmental tests. It's also designed with transient protection, to prevent premature failure from electrical spikes in the vehicle. It's even compatible up to 30V! We're so confident in the SL2 Pro, that it's backed by an industry-leading limited LIFETIME warranty.
    Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer an increasing number of products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
    If you're ready to upgrade your halogen bulbs, you can purchase our SL2 Pro LED Bulbs by clicking here or using our dealer locator to find a dealer near you.
    Want to know more about Diode Dynamics products? Visit DiodeDynamics.com and subscribe to our Newsletter for new product releases and more!
    Forum Member Exclusive:
    If you're a US resident, you're eligible for a free US shipping code courtesy of Diode Dynamics. Please send us a direct message to us here on the forum for the code.
    Questions/Concerns:
    Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
    Email: contact@diodedynamics.com
    Phone: 314-205-3033
    If you're looking for a lower price point option and not needing the maximum output, then be sure to check out our SL2 Replacement LED Bulbs.
    rgvaggie11 likes this.
  2. Apr 11, 2024 at 11:11 AM
    Diode Dynamics
    St. Louis, Missouri
  3. May 24, 2024 at 5:23 PM
    rgvaggie11
    rgvaggie11 Well-Known Member
    2017 Quicksand TRD 4x4
    How's output vs sl1? I had the sl1s and ended up going with the supernova v4s because of light output. Want to go back with American made if I can!
  4. May 28, 2024 at 11:39 AM
    Diode Dynamics
    St. Louis, Missouri
    Our SL2 and SL2 Pro bulbs are both a huge upgrade in performance and technology.
    However, to be transparent these bulbs are designed and engineered in-house here at our HQ but we decided as a performance LED manufacturer, we would delegate certain smaller projects to suppliers overseas, to give us more availability to focus on much bigger projects that are currently in the pipeline for our production team in Missouri.
    rgvaggie11[QUOTED] likes this.
  5. May 28, 2024 at 11:54 AM
    rgvaggie11
    Beautiful! Any promo codes for Tacoma world? Would love to place and order
    09 Redneck likes this.
  6. May 29, 2024 at 5:47 AM
    Diode Dynamics
    St. Louis, Missouri
    We do not have any promotions ongoing at this time. However, we do offer free US shipping exclusively for forum members! Just shoot us a direct message for the code.
