Next issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BYBO, Feb 18, 2017.
  1. Feb 18, 2017 at 5:49 AM
    BYBO
    BYBO [OP] Well-Known Member
    Byron
    Indiana
    Does anyone have an issue with your transmission not going into 5th gear on the highway?
    Sometimes I'll notice when driving around 70mph, my tach will be reading 3000rpm. I can usually accelerate to 75 and get it to shift, or manually shift into 4 then back to D and it upshifts.
    It's not really an issue, but I'm sure it has cost me gas money.
  2. Feb 18, 2017 at 6:33 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If it actually isn't shifting into 5th gear without you making it, something isn't working correctly.
    Lord Helmet likes this.
  3. Feb 18, 2017 at 6:57 AM
    Pigpen
    Dan
    Northwest Montana
    Check to make sure there's enough fluid in the transmission.
  4. Feb 18, 2017 at 7:16 AM
    BYBO
    Byron
    Indiana
    That is a huge operation. I tried to get the dealer to do it, and they wouldn't without charging me, A lot!!
    I'll try to review the procedure again and see if I can figure it out.
  5. Feb 18, 2017 at 7:18 AM
    Pigpen
    Dan
    Northwest Montana
    Uh, pull the fill plug. If no fluid drains out, fill until it does. Replace fill plug. Am I missing something?
    outlawtacoma and jv_74 like this.
  6. Feb 18, 2017 at 7:31 AM
    moondeath
    Pa, Gardners
  7. Feb 18, 2017 at 7:41 AM
    Pigpen
    Dan
    Northwest Montana
    I only skimmed it, but it seems like you can just pull the fill plug if you're only checking fluid level and topping it off.
    Sorry for my ignorance. I have a man trans, and this is how it's done with those.
  8. Feb 18, 2017 at 8:01 AM
    moondeath
    Pa, Gardners
    The tranny fluid has to be a specific temperature to check the level. Which is indicated on the dash when you jumper an electrical connector. Then you check at the overfill plug. Filler plug is just a filler plug. If the temperature gets too warm you must turn the vehicle off and restart.
  9. Feb 18, 2017 at 8:01 AM
    NM Lance
    NM Lance Well-Known Member
    If only Toyota, or some other car manufacturer, could create some sort of a "stick" that could be lowered, or "dipped" into the fluid thus giving the owner or technician an accurate idea of the fluid level... until then, we can only dream I suppose.
  10. Feb 18, 2017 at 8:10 AM
    Pigpen
    Dan
    Northwest Montana
    :rofl:
  11. Feb 18, 2017 at 8:14 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Ain't that the truth
  12. Feb 18, 2017 at 8:14 AM
    Pigpen
    Dan
    Northwest Montana
    Worth the effort if the fluid might be low.
  13. Feb 18, 2017 at 8:27 AM
    BYBO
    Byron
    Indiana
    I'm going to pick up a quart of fluid today. I'll check it when it cools. Hopefully, it's just a little low.
  14. Feb 18, 2017 at 8:46 AM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    And even more cunning: they could put the marks on the stick that could be read when the vehicle's fluid is cold and not require some difficult process to measure. Engineering is hard though...
    jv_74, SeafireXV and Shelf Life like this.
  15. Feb 18, 2017 at 8:54 AM
    Lord Helmet
    Nick
    '24 X3 M40i
    That's too much of common sense idea...won't work with toyota.
  16. Feb 18, 2017 at 8:55 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Try backing off on acceleration instead of racking it. My truck does the same thing on occasion. If I'm goosing it getting on the freeway and it wont shift into OD, just a slight back off on the gas pedal and it goes right in.
  17. Feb 18, 2017 at 9:06 AM
    Shelf Life
    Rob
    Central Oregon
    Even worse are the new cars that don't even have an engine oil dipstick. Your supposed to rely on a light that says your low.
  18. Feb 18, 2017 at 9:08 AM
    moondeath
    Pa, Gardners
    I guess the reason Toyota didnt put a dipstick in is because it was suppose to be a 'lifetime' sealed transmsission. They changed the fluid change interval after a while though and now it's just a pain in the ass.
    Pigpen likes this.
  19. Feb 18, 2017 at 9:49 AM
    NM Lance
    Well don't talk about it too much guys! I am planning to make millions on this novel idea, would hate for someone to beat me to it.
