Next project
Discussion in 'Suspension' started by 05tundra13, Aug 17, 2011.
  1. Aug 17, 2011 at 8:05 PM
    05tundra13
    05tundra13 [OP] Well-Known Member
    Devin
    Simi Valley
    05 tundra doublecab
    alright guys so im still pretty new to all of this but i am learning at the same time. as if now i am full lt besides my stock leaf springs in the back. (i need a sua kit). (and bump stops) (and bedside fenders) ok so I kind of need a few things..list goes on. for now my main concern is trying to get the truck mainly done soon. what should I get next. some deavers, bedside, bump stops, etc. what would be the best idea to go with next?
  2. Aug 17, 2011 at 8:11 PM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    05 tundra limited 2wd
  3. Aug 17, 2011 at 8:30 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Having seen your truck first hand, you sir need a SUA. Having a front LT and stock rear really restricts your performance (which is why the ass of your truck was bucking all over the place in the whoops at pismo). There's no sense in dropping money into deavers and keeping the springs over the axle. As I saw it, you have like 2.5" of uptravel limited by your bumps.
    I say save the money, get the Giant SUA kit. Its bolt in and gives you a whopping 20" of wheel travel.
    http://giantmotorsports.com/index.php?option=com_content&task=view&id=69&Itemid=89
    You will need glass bedsides due to the amount of uptravel you'll get from the SUA kit so plan accordingly.
    And have your fabricator redo that bedcage and make him do it right. If you are going to keep the low pro cage, you'll need a second surrounding tube and gussets for strength. Otherwise install a crossbar for the shock mounts. Honestly, if I were you, I'd try to get my money back and get the cage that Solo motorsports made. That bed cage needs a lot of help. Also instead of the shock tabs being on the top of the axle (as they are now) I would plan to have them off the back of the axle and something a little thicker than is currently on there (try 1/4" plate). You can look at nelson18matt's build for cage ideas and both Matt and I have pretty much the same lower shock mounts.
    Bump cans are nice, but not required, and can be added later. You can use a regular rubber bump for the time being to keep the shock from bottoming out. Spend the money on what you need first.
  4. Aug 17, 2011 at 8:46 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    And on a separate note, you have some SERIOUS preload on your front coils. What spring rate are you running? I know you're not dealing with the weight of a front diff, but that 4.7L has a cast iron block, not aluminum. It's not exaclty light. I'm not sure how your front end feels, but you might want to consider stepping up the spring rate.
    I still say handle the rear of the truck first though.
  5. Aug 17, 2011 at 10:34 PM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    Alright Jason, thanks for the in-depth response. I have already called killer off road and will be bringing my truck in as soon as i have a chance to go back to my hometown (since i live in sb). Adam and I talked about my cage and I'm going to demand my fab guy to do use DOM steel this time since he used cheap steel before. what is the difference from having the shock tabs on the axle then hanging off the back?
  6. Aug 18, 2011 at 8:37 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    With your current setup, nothing. You're current uptravel is limited by your spring pack/bumps/fenders. If you go SUA and have the shock tabs on top, you'll be limiting the amount of uptravel you have by a few inches.
  7. Aug 18, 2011 at 8:52 AM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    ok that makes sense. so once i get my fenders and the SUA kits then i should have the tabs off the back of the axle.
  8. Aug 18, 2011 at 8:54 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Typically yes. You will maximize your travel numbers that way. It depends on the fabricator as well though.
  9. Aug 18, 2011 at 12:09 PM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    unless i tell him to fabricate it a specific way ha. or make it easy and go to adam.
  10. Aug 18, 2011 at 12:10 PM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    also why is this kit so much more? you said don't waste your money on deavers..but it would be less to get deavers. explain more please?
  11. Aug 18, 2011 at 12:23 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    the leafs that come with the GIANT kit are deavers..my giant kit came with em anyway. Its more expensive because the fab work is top notch, GIANT is a big name and race proven
  12. Aug 18, 2011 at 1:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ^What he said.
    When I said don't waste your money on Deavers, I meant the Deaver stock replacements. The Deavers in the Giant SUA kit are 64". The Giant kit gets you the shackles, deavers, bushings, straps, hangers, ubolts and bash plates. Quality kit. I have the Giant kit for my Tacoma.
  13. Aug 18, 2011 at 3:32 PM
    rondog
    Ronnie
    Escondido/San Diego
    ahh gotcha, misunderstood what you said then ;)
  14. Aug 18, 2011 at 3:48 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Its cool. My posts tend to not make sense when I drink at work.
  15. Aug 18, 2011 at 4:52 PM
    rondog
    Ronnie
    Escondido/San Diego
    hah well at least you get to drink at your job
  16. Aug 18, 2011 at 4:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Not like i'm supposed to. :spy:
    Extenuating circumstances forced me to have a few adult beverages at lunch time.
  17. Aug 18, 2011 at 6:08 PM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    haha alright totally makes sense now. dang, all i need is some more money and i can do this, to bad i dont.
  18. Nov 17, 2011 at 9:59 PM
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    Check my build out!!
