Next step: Blowing Truck Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barretrobbins, Aug 24, 2023.
  1. Aug 24, 2023 at 10:39 AM
    barretrobbins
    barretrobbins [OP] Member
    Trace
    2013 TRD off road toyota tacoma
    all
    Hey all, for about the last 9 months I have been taking my truck into shops and working on it myself also. 150k on my 2013 TRD off road. I have shakes that start about 55mph and get worse with speed increase. passenger seat is screaming for its life and wants to jump out of the window. Nobody can figure it out.
    I have replaced the following
    -struts around (6-7k ago)
    -front and rear breaks (5k ago)
    -new Nitto trail graps 265/75/16r
    -new rear end minus the diff (4k ago)
    -intermediate steering shaft(4k ago)
    -road forced wheels/tires(recent)
    -new carrier barrier
    -greased and inspected u joints
    I have thrown on stock wheel/tires and they did not take away the vibrations.
    I also had the driveline inspected and there seems to be nothing wrong.
    I will take any and all feedback lol
  2. Aug 24, 2023 at 10:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lift your vehicle up on a jack and check your wheel bearings, super quick and easy to do
    Any prior accidents? No bent spindle or anything?
    How's your alignment, surely if you had issues it would've been mentioned
    23MGM and TnShooter like this.
  3. Aug 24, 2023 at 10:43 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did the problem start before or after you jd the carrier bearing and rear end replaced?
  4. Aug 24, 2023 at 10:48 AM
    barretrobbins
    Trace
    all
    From what I’ve been able to see there is no significant play in the wheel bearings.
    no prior accident. other than taking it off road
    I was doing alignment and everything but haven’t gotten one in awhile because even with my old KO2’s the wobble/vibration was still present so i was just dumping a hundred bucks into the shop. Camber/caster is never far off
  5. Aug 24, 2023 at 10:50 AM
    barretrobbins
    Trace
    all
    Problem was before i replaced them. I was running KO2’s that has significant runoff so thought it would solve it. and then kept getting quotes from shops different things so then i would replace them lol
  6. Aug 24, 2023 at 10:55 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Is the truck lifted? Did you do any work around the time the issue first started?
  7. Aug 24, 2023 at 10:57 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  8. Aug 24, 2023 at 10:59 AM
    barretrobbins
    Trace
    all
    Yes 6-7k ago i replaced the block lift and OEM struts and put bilstein 5100’s that is 3”.
    Not being a dbag but there is not a certain time I vaguely remember it starting after i replaced something. Like I don’t remember being drunk and hitting a tree ya know? haha
  9. Aug 24, 2023 at 11:02 AM
    Revelations
    2014 MGM DCSB
    If I'm reading you right, you installed a 3" lift? I'm no expert, but I would suspect your driveline geometry is off now. Plenty of threads on it. Sorry. I'm not lifted, so I can't offer much more help.
  10. Aug 24, 2023 at 11:05 AM
    barretrobbins
    Trace
    all
  11. Aug 24, 2023 at 11:06 AM
    barretrobbins
    Trace
    all
    At this point I wish i was not lifted lol. But i am running shims in the back.my bad i feel like a lot of these should be givens to people with trucks lol
  12. Aug 24, 2023 at 11:10 AM
    Revelations
    2014 MGM DCSB
    I like the look, but it's not practical for me. I don't do any off roading. Anyways. Even though you have shims, there might still be an issue. The issue you describe really sounds like a driveline issue because the shaking gets worse as your driveshaft speed increases. It's possible it needs a re-balance. I've read other people had to go with a 1 piece driveshaft to cure their issues.
  13. Aug 24, 2023 at 11:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Mentioning the "being lifted" part would've been important from the get go.
    I always suggest not to exceed 2" even.
    PS, these trucks don't use struts ;)
    TnShooter likes this.
  14. Aug 24, 2023 at 11:23 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    55 and above is 99% of the time a hub/bearing/wheel/tire. Drivetrain vibes usually start at takeoff or 35mph.
    is it a fast vibe or a slow vibe?
    I would definitely just pull the wheel bearings and check them. I bet they are worn out.
    barretrobbins[OP] likes this.
  15. Aug 24, 2023 at 11:26 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Out of curiosity, what were the numbers?
    Also, I crank my ubolts to 100ft #'s. They can handle it.
  16. Aug 24, 2023 at 11:39 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    When the vibrations start, do you feel them first in the steering wheel or more of the "whole truck"?
  17. Aug 24, 2023 at 11:45 AM
    barretrobbins
    Trace
    all
    yeah it comes into my wheel around 35-40mph. but progressively gets worse at the 55+.
    it’s a fast vibe
  18. Aug 24, 2023 at 11:46 AM
    barretrobbins
    Trace
    all
    it starts slowly in the steering wheel around 35 with play back and forth but 55+ gets progressively more catastrophic lol.
    it’s mainly in the front end, shaking my passenger seat and everything like crazy
  19. Aug 24, 2023 at 11:48 AM
    barretrobbins
    Trace
    all
    will get back to you.
  20. Aug 24, 2023 at 11:48 AM
    Naveronski
    Fort Worth
    At this point, you’ve replaced the easy things.
    Wheel bearings and CV axles would be next.
