Next step: Blowing Truck Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barretrobbins, Aug 24, 2023.
  1. Aug 24, 2023 at 11:49 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Could be the needle bearing. Lots of threads on here about vibes at certain speeds, remedied by the ecgs clamshell bushing.
    Revelations likes this.
  2. Aug 24, 2023 at 11:50 AM
    barretrobbins
    barretrobbins [OP] Member
    Trace
    2013 TRD off road toyota tacoma
    all
    was waiting for this one haha.
    I have the bushing already. my needle bearing is shot and i need to replace it.
  3. Aug 24, 2023 at 11:59 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Long story short, bearings can be bad even without play.
    Longer version: I just replaced my front wheel bearings. They had zero noticeable play on the truck, but were VERY loud. It grew loud over such a long time, I didn't really know they were loud. I actually thought it was my newer E-Load tires I moved to recently. Not saying this is your issue, but others above said to check for bad bearings by looking for play. That's not always good enough. Even off the truck I can't see any play, but it's a night and day difference in my truck.
    barretrobbins[OP] likes this.
  4. Aug 24, 2023 at 11:59 AM
    barretrobbins
    Trace
    all
    thanks for the highly educational input meat
  5. Aug 24, 2023 at 12:01 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    probably a bearing. i got similar issues right now that no one seems to be able to figure out.
  6. Aug 24, 2023 at 12:01 PM
    barretrobbins
    Trace
    all
    facts. at this points i’m about to replace them to rule out what else it couldn’t be lol
  7. Aug 24, 2023 at 12:03 PM
    barretrobbins
    Trace
    all
    boutta just send it to rule it out
  8. Aug 24, 2023 at 12:04 PM
    barretrobbins
    Trace
    all
    Everything I have replaced seems like it should have fixed it. so probably should definitely maybe work right?
    cryptolime[QUOTED] and YF_Ryan like this.
  9. Aug 24, 2023 at 12:06 PM
    YF_Ryan
    Kent, WA
    Couldn't hurt depending on how many miles are on them. You can buy the entire assembly with quality bearings for like 150-ish each. I'm no mechanic, but was able to pump it out without hardly any issue. You seem to know what you are doing, so might take less than 2 hours to do both for you. Or even less.
    Here's my one f-up... Put the damn shield plate thing on 90 degrees off... lol. Hard to mount your caliper like this.
    jw_96taco and barretrobbins[OP] like this.
  10. Aug 24, 2023 at 12:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    1. You want help, you can only be helped if you provide as much info from the get go as possible
    2. I offered valid suggestions, which are already being echoed
    3. No need to get hurt over a simple correction
  11. Aug 24, 2023 at 12:11 PM
    barretrobbins
    Trace
    all
    why are you the way you are
  12. Aug 24, 2023 at 12:12 PM
    barretrobbins
    Trace
    all
    that does make it more difficult.. or caliper delete
    YF_Ryan[QUOTED] likes this.
  13. Aug 24, 2023 at 12:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's a helpful criticism.
    Providing more info such as having a lift, can help come up with theories as to why you're having the issues you are having.
    Did the issues only appear after your lift? Or were they there before?
    You mentioned no excessive play in your wheel bearings but was this something you thoroughly checked yourself, or ask one of the many shops you've been to?
    It's simple really. People are asking questions to gather more information in order to help you.
    2015WhiteOR likes this.
  14. Aug 24, 2023 at 12:20 PM
    barretrobbins
    Trace
    all
    i’ve answered all these questions you just asked from other people. you just are not helpful.
    I gave the basis of my problems and this is an educational forum network for people to cast their knowledge to my problem that I am searching for, yes. Again great job with giving more knowledgeable feedback to me and everyone else reading your post right now
    YF_Ryan and SmoothTRD like this.
  15. Aug 24, 2023 at 12:24 PM
    #35
    SmoothTRD
    SmoothTRD Well-Known Member
    There is always a Richard Cranium to be found
    racerX969 and YF_Ryan like this.
  16. Aug 24, 2023 at 12:56 PM
    #36
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Yes. I've read that it needs to be replaced with the ecgs clamshell for lifted trucks.
  17. Aug 24, 2023 at 1:13 PM
    #37
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Was carrier bearing OEM? This 4x4 i assume? If so mark and take out the rear driveline, take a short test run on 4x4 without the reardriveline. If the vibe is there you can rule out the rear driveline. Maybe threw a balance weight on driveline.
    jw_96taco likes this.
  18. Aug 24, 2023 at 1:27 PM
    #38
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    try a drain and fill on the transmission. i used the idemtisu stuff last time which doesn't have the exact amount of friction modifier the Toyota WS stuff has. maybe the tc doesn't like it.
  19. Aug 24, 2023 at 1:28 PM
    #39
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    smooth...
    SmoothTRD[QUOTED] likes this.
  20. Aug 24, 2023 at 1:31 PM
    #40
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    that lock nut looks fancy. or maybe i just haven't noticed mine
