Next Step Sell Or Keep
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JSB10, Aug 30, 2019.
  1. Aug 30, 2019 at 10:46 AM
    JSB10
    JSB10 [OP] Well-Known Member
    2005 Tacoma
    My 05 Tacoma 5 speed has been exhibiting some funky sounds off and on now for some time. I have taken it to my my mechanic and even the dealer to help me figure out where this noise has been coming from and haven't been able to diagnose until now. My mechanic says need new manual transmission from Toyota and new clutch for a grand total of 3100. My truck has 211000 miles currently. New frame, leafs, u-joints, and always on time with regular maintenance. Is my truck worth keeping and putting 3100 back into it? Ihave thought about selling it as is and finding a small car for now. My father passed on Easter and between a headstone and cremation I cant do this anytime real soon but I'm hoping I can get the time I need to come up with the money without my truck quitting me.
  2. Aug 30, 2019 at 10:50 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Getting a rebuilt might be a better option, ide get some quotes from dedicated trans shops, if you have the 4cyl ide keep it cause its pretty much bullet proof and with a new/rebuilt trans you could get a lot more miles out of it.
    NAAC3TACO and JSB10[OP] like this.
  3. Aug 30, 2019 at 11:02 AM
    ImBillT
    ImBillT Well-Known Member
    2010 4x4 base
    I wonder what a salvage trans costs.
    JSB10[OP] likes this.
  4. Aug 30, 2019 at 11:15 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    More deets on the sound(s).
    Do you have a 4.0?
  5. Aug 30, 2019 at 11:28 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    There comes a time in vehicle ownership where you here this sucking sound, first it’s not to bad, and then it starts to get louder and louder. That’s the sound of money being sucked out of your wallet.
    When you start asking questions about to sell or not. That’s your clue to move on and quit draining the wallet. I say sell.
    Turdyota3000, KY_Rob and JSB10[OP] like this.
  6. Aug 30, 2019 at 11:44 AM
    JSB10
    2005 Tacoma
    I have the 2.7 4cyl. I have had a intermittent rattling/knocking sound. My mechanic had my truck yesterday and I asked him to take it out and drive it and he said it did it on the drive. He has always taken care of my truck except what the dealer has done. Still kinda hard for me to believe my truck is in this condition but I guess even Toyotas die sooner or later.
    Turdyota3000 and PzTank[QUOTED] like this.
  7. Aug 30, 2019 at 11:50 AM
    PzTank
    Above the Notches
    Hummm,
    Internal to engine or transmission, heat shield, loose bolts, loose nuts..
    Does it ever happen in Park w the engine running?
    There are systems where you can place remote microphones on your vehicle to trace them down. Maybe your guy would want to invest in one (should be a write off for him and then he’d could offer another service from his shop).
    I wouldn’t give up just yet..
    JSB10[QUOTED][OP] likes this.
  8. Aug 30, 2019 at 11:55 AM
    JSB10
    2005 Tacoma
    Doesn't happen in park w engine running usually in the lower gears between first and third. IIRC he said lower end of the transmission. Thanks for the input.
  9. Aug 30, 2019 at 12:12 PM
    PzTank
    Above the Notches
    If it’s the transmission, go with the used one like @ImBillT and @coopcooper suggested. This should be well under the initial estimate..
  10. Aug 30, 2019 at 12:15 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If you truly do need a replacement trans, check out car-part.com
    Is your truck 4wd or 2wd?
    I have a 2wd 5spd and found a used trans with 77k on it for $375 shipped. Dont let others take advantage of you at a shop. Buy the trans yourself and take it somewhere to get swapped or talk to the locals on here in your area and see if someone is willing to help. Are you in central texas by chance? Id be happy to help you drop the trans
    Wattapunk, b_r_o and PzTank like this.
  11. Aug 30, 2019 at 12:19 PM
    BassAckwards
    When is the knocking/rattling present? Rpm range, acceleration, deceleration etc
    please try to provide as much description as possible. I had hub on a clutch come loose on me and it made all kinds of nasty vibes/rattles under certain driving conditions
  12. Aug 30, 2019 at 12:29 PM
    JSB10
    2005 Tacoma
    Its 4wd 5 speed.
    Its present on takeoff from a complete stop between first and third and not just driving down the road it doesn't make any sound then. My shifting range is usually around 2500 rpm and no noise on deceleration. My first thought was to do the clutch and just drive it for now that's my short term plan.
    BassAckwards[QUOTED] likes this.
  13. Aug 30, 2019 at 12:38 PM
    BassAckwards
    How does your transmission mount look? I doubt this is the issue, but something to check and make sure its in decent shape. My stock one lasted 250k before i replaced it, couldve gone longer though
    Does it make any noise if you rev the truck in neutral? Trying to isolate the problem to the trans, which it sounds like it is..
    Is this the original clutch, or has it ever been changed before?
    When this rattle/knocking occurs, is it in a certain rpm range only, or does it consistently happen in only 1st-3rd gears at any rpm?
    Have there been any drivability issues with shifting? Hard shift, not wanting to shift at all, hard clutch pedal, clunky when releasing the clutch, etc?
    PzTank likes this.
  14. Aug 30, 2019 at 12:40 PM
    BassAckwards
    b_r_o, PzTank and JSB10[OP] like this.
  15. Aug 30, 2019 at 12:46 PM
    JSB10
    2005 Tacoma
    Original clutch and hasn't been changed yet. Shifting between gears feels like bumping up against a wall before it goes in. He said bearing in clutch was going out. Replacing the clutch is the cheapest option I have now. Its still driveable some days it drives better than others.
  16. Aug 30, 2019 at 12:47 PM
    JSB10
    2005 Tacoma
    PzTank and BassAckwards[QUOTED] like this.
  17. Aug 30, 2019 at 12:54 PM
    BassAckwards
    Yeah it is probably the throwout bearing hes referring to. I would start by putting a clutch, throwout bearing, and pilot bearing in it. I think this will fix your issues
    I feel your pain brother, i just fought my 5spd for 6months chasing a nasty vibration while accelerating and decelerating. Ended up i got a defective clutch right out of the box and the hub came loose. I replaced the trans and it the problem continued.. so id start with a clutch kit since itll be cheaper.
    I just put a Luk 16088 clutch kit in mine and it solved my issues. Its been great for about 7500 miles now. I got it off rockauto, it was about 85 bucks for the whole kit that came with the TOB, pilot bearing and pressure plate
    b_r_o, PzTank and JSB10[QUOTED][OP] like this.
  18. Aug 30, 2019 at 12:56 PM
    BassAckwards
  19. Aug 30, 2019 at 1:20 PM
    PzTank
    Above the Notches
    b_r_o and BassAckwards like this.
  20. Aug 30, 2019 at 4:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Robert to the rescue! :hattip:
    OP I'd jack up the rear end and run it through gears while listening with a stethoscope. Bad trans bearings should howl like a mf.
    Sounds like a new clutch kit would be a good first step. Then a low mileage used trans if needed
    BassAckwards and JSB10[OP] like this.
