NFAB step owners. Pls help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LEX, Mar 29, 2011.
  1. Mar 29, 2011 at 3:26 PM
    LEX
    LEX [OP] --- --- --- - ----
    Houston, Texas
    100 Series LC
    I'm embarrassed, but I can't figure out how to mount the steps. The instructions I got are faded to shit. All I can read is "remove factory hardware"
    Could someone possible take a pic of where they mount? Thanks
  2. Mar 29, 2011 at 3:31 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Real simple. Under your truck one screw by the front two in the middle two at the back.. There phillups (cross tip) and should be plastic take those out then the bolts that came with your NFABs should go in there place.
  3. Mar 29, 2011 at 3:32 PM
    LEX
    Houston, Texas
    100 Series LC
    Found it. Thanks so much.
  4. Mar 29, 2011 at 7:37 PM
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport
    Just got some Smittybuilt steps, but they are actually Nfabs as they say Nfab on the step... Double cab and extra cab are actually the same thing, i called because the box said "double cab" and i have an extra cab.
    Instructions say to start with the middle bracket first, finger tight only, then attach the front and back mounting points. front bracket only gets one bolt and the middle and rear use 2. Torque to 15 ft lbs. Small end of the bar to front and the instructions say mounting bracket bent flange should face rear but mine actually face front and the representative said don't worry about that. Oh and mounting goes bolt, lock washer, flat washer...
  5. May 13, 2011 at 9:04 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Can anyone measure from the door sill to the step on NFabs or Smittybuilt (I understand from posts on TW they are the same thing with different label) steps B 4 I pull the trigger and need to know if they will help the situation. Thanks.
  6. May 13, 2011 at 9:33 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    5 5/8" from top of step to underide of door / top of sill
  7. May 13, 2011 at 9:38 AM
    george3
    New Jersey
    Cool ! Thanks. I'll have 2 C if 5 5/8" inches is enough for her. I'll just lie and tell her it's 6" - been doing that for years anyway:D Peter North - were you a porn star back in the day ? If not maybe a name sake.
  8. May 13, 2011 at 9:48 AM
    OZ-T
    Peter North
    British Columbia
    You heard of me ?
  9. May 13, 2011 at 9:51 AM
    george3
    New Jersey
    You're my hero. ;)
  10. May 21, 2011 at 5:32 PM
    george3
    New Jersey
    Just wanted to thank you for the measurement - it helped me make the decision. Pulled the trigger today - got the powder coat though.
  11. May 21, 2011 at 8:35 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  12. May 21, 2011 at 10:52 PM
    tanzak88
    tanzak88 Well-Known Member
    Lmao
  13. May 26, 2011 at 6:49 PM
    george3
    New Jersey
    Got them today. Ordered 5/21 Sat. Shipped 5/23 Mon. Delv 5/26 Thurs. AutoAnything.
  14. Jun 3, 2011 at 2:31 PM
    george3
    New Jersey
    Got mine on today. Ordered Smittybilt - the steps have NFab embossed on the steps. No reason to pay extra for NFab, they are the same. I never read directions so I always get into trouble. I put them on by myself. Use a couple of milk crates to hold them up. Once you get one bolt in the middle bracket you are good to go. Don't forget to take all the plugs out first. Ask me how I know.[​IMG] There is only one hole in the body for the front bracket even though there are two holes in the bracket. The front of the passenger side tube hit the seam on the body so I used the two extra washers for spacers.
