NFS257's next build (Trailer Build)
Discussion in 'Other Builds' started by nfs257, Jan 26, 2016.
  1. Jan 26, 2016 at 10:12 PM
    nfs257
    nfs257 [OP] Well-Known Member
    DFW
    She gone
    So I stumbled across a trailer that looks to be almost perfect for what I need and want.
    Its a utility trailer that has a tent in a bag that sets up on the trailer. I needed something light enough that my truck with all the suspension modifications would still be able to easily pull and not pull the truck all over the road.
    • Camper Removable end gates (front and back) position and slide over trailer's sidewall track for interior sleep and gear surface area; Deck WIng panels set up to outside using trailer's sidewall track with added hardware fitting supplied. Dome style tent affixes around trailer's circumference.
    • Tent Fully-featured, spacious tent and rain fly with 6'10" interior height. Doors with screens on both ends (end gates are removed and positioned inside trailer)
      Screened ceiling (great sky view) and screened bay windows.
      Tie-Outs and Tie-Ins (self-contained anchors).
      Gear Loft for flashlights and small personal affects
      Power Port for electrical wire pass through
    • Mobility Leveler Kit and Marine Jack included for mobility and stability off the hitch.
    • Dimensions (Trailer)
    • Bed Dimensions 86"L x 54"W x 24"H (7' x 4' 6" interior)
    • Overall (with tongue and tires) 123"L x 70"W x 41"H
    • Dimensions (Camper) Set up interior-7'L x 8' 5"W x 6' 10"H Deck Wing 84" x 22"
    • Weights (Trailer)
    • Tongue Weight 30 lbs
    • G.V.W.R. - 2,460 lbs.
      Payload Capacity - 2,000 lbs.
      Curb Weight - 460 lbs.
      Construction - 18 ga. sheet metal over tubular “box truss” frame
      Solid steel bed with 24” high sidewalls
      C-Channel track integrated on top of sidewalls
      Flat black powder coat over galvanized metal finish
      End Gates - Front & Rear, easily removable
      Axle - Torsion with Sure Lube bearing system
      20” Ground Clearance
    Im going to customize the hubs to match the Tacoma lug pattern so I dont have to worry about spares. Also upgrading to the Lock and Roll trailer hitch system to be friendlier off-road.
    On to the pics from the website, will update with my own after April or so. Using this as a sounding board and easy way to lay out my thought process for now.
    501-1024x1024-500x500.jpg 501B-1024x1024-500x500.jpg 504A-1024x1024-500x500.jpg Overlander_Camper_Tent_Utility__62310.1446590263.1280.1280.jpg Overlander_Camper_Trailer_ArcHaus_Outdoor_Shelter_Side_View__38692.1446590262.1280.1280.jpg Overlander_Camper_Trailer_Leveler_Kit_Side_View__14412.1446590264.1280.1280.jpg Overlander_Camper_Trailer_Tent_Inside_View__64810.1446590264.1280.1280.jpg Overlander_Camper_Trailer_Tent_Rear_View__65540.1446590264.1280.1280.jpg Overlander_Camper_Trailer_With_Arc_Haus_Living_Shelter_Side_View__57875.1446590264.1280.1280.jpg Spec_Ops_Close_Up_C_Channel_View__53346.1446852905.1280.1280.jpg Spec_Ops_LeatherBack_Cover_Utility_Trailer_Side_View__66491.1446852883.1280.1280.jpg Spec_Ops_LeatherBack_Utility_Trailer_Front_Side_View__13806.1446852882.1280.1280.jpg Spec_Ops_LeatherBack_Utility_Trailer_Rear_View__36347.1446852883.1280.1280.jpg Spec_Ops_LeatherBack_Utility_Trailer_Side_Top_View__21165.1446852959.1280.1280.jpg Spec_Ops_Trailer__79082.1446853020.1280.1280.jpg Spec_Ops_Trailer_Tailgate__93918.1446852901.1280.1280.jpg Spec_Ops_Trailer_Three_Quarter_View__11637.1446852995.1280.1280.jpg Spec_Ops_Trailer_Utility__20047.1446852888.1280.1280.jpg
    Dalandser, ChadsPride, Crom and 4 others like this.
  2. Jan 26, 2016 at 10:13 PM
    nfs257
    DFW
    She gone
    ChadsPride likes this.
  3. Jan 26, 2016 at 10:13 PM
    nfs257
    DFW
    She gone
    I called USCargoControl and asked their stock of the green since they had discontinued it. So I ordered everything I hope I needed for the trailer and all the gear.... :eek: :D
    49627-airline-track-filler-strip-10_1_75_a739182ded5eb60270e489e3c5c7d2648ea71ffa.jpg 2 Of the filler strips Airline Track Filler Strip - 10'
    42437-2-green-l-track-logistic-track-pie_3838f15d511c36f590612cec133e8eb5c3f1c33e.jpg 6 Of the Airline Track 2" - Green
    42439-round-airline-track-style-l-track-_247a0b72e7aaf23992f3bbd51a8a0b232525d745.jpg 6 Of the Round Airline Track 2" - Green
    42471-48-airline-track-style-l-track-wit_b8e2eea9ed95bcf62414028de875d04aa9c9312d.jpg 3 Of the Airline Track 48" - Green
    42431-24-airline-track-style-logistic-tr_8b2dfcb6777ebaf1e3e4e9d78ca220e029e6c3f0.jpg 6 Of the Airline Track 24" - Green
    42433-12-l-track-with-powder-coated-gree_b7fd823a2a9b05c64458c85533c41eb78ff5cdf7.jpg 2 Of the Airline Track 12" - Green
    42488-single-stud-fitting-w-black-ring_1_d2f3617428b818fba946fe689f24f81de6ebadf4.jpg 20 Of the Single Stud Fitting w/ Round Ring - Black
    Looks like this in person:
    ChadsPride and Crom like this.
  4. Jan 26, 2016 at 10:13 PM
    nfs257
    DFW
    She gone
    Reserved 3
  5. Jan 27, 2016 at 5:09 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I like it! Good idea on the hubs. :)
    ChadsPride and nfs257[OP] like this.
  6. Jan 27, 2016 at 9:22 PM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    subbd :popcorn:
  7. Jan 27, 2016 at 9:23 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Subd
  8. Jan 28, 2016 at 5:36 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Nice
  9. Jan 28, 2016 at 5:40 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    SUB'ED:popcorn::yay:
  10. Jan 30, 2016 at 11:03 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    I like it but I already got the pop up kinda I want mine to have an RTT as a just in case and plenty of storage room for goodies and such
  11. Feb 5, 2016 at 9:09 PM
    nfs257
    DFW
    She gone
    @Crom any suggestions for a propane tank holder? For the 20# and where would you put it for maximum storage capacity? And safety while off road?
    Kinda thinking just strap it in and remove when camped...
  12. Feb 5, 2016 at 9:11 PM
    nfs257
    DFW
    She gone
    Or about here on both sides...
  13. Feb 6, 2016 at 4:01 AM
    Crom
    Nick
    San Diego, CA
    Millions
    I looked for a bracket that i liked for a long time, and I settled on ratchet straps. It's not the best, but it certainly works well enough. General safety rules are to transport with valve covered, but no POL plugs, bottle upright and ventalated.
    Attaching to trailer is a popular method.
  14. Feb 6, 2016 at 6:00 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Maybe make your own mounts outta some angle iron just build a cage around it and ratchet strap it in the cage?
  15. Feb 7, 2016 at 11:46 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  16. Feb 7, 2016 at 11:51 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    :popcorn:
  17. Feb 7, 2016 at 11:54 AM
    nfs257
    DFW
    She gone
    Its gonna be a slow one. Gotta talk to them Monday to start the payment process lol
    Biscuits[QUOTED] likes this.
  18. Feb 7, 2016 at 12:10 PM
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
  19. Feb 7, 2016 at 5:59 PM
    Crom
    Nick
    San Diego, CA
    Millions
    This. If you can, build your own.
    HAVVOKK[QUOTED] likes this.
  20. Feb 7, 2016 at 7:25 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Doesn't seem like it would be too hard and only about 10 bux in metal
