Ngk plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Dec 27, 2014.
  1. Dec 27, 2014 at 7:12 AM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    I'm about to change my plugs on 4.0 but ngk has a PDFs which tells you nt to use antiseize paste. What are other members doing?
  2. Dec 27, 2014 at 7:36 AM
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
  3. Dec 27, 2014 at 7:36 AM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    I just changed to NGK's at 30k, so far I like them, although the old plugs looked good & the gap was fine, the NGK's seem to smooth out the engine a little (that could be just in my mind) gas mileage did improve noticeably . To your question, Yes, I used antiseize (very sparingly) jmop
  4. Dec 27, 2014 at 7:42 AM
    Beerline123
    I'm sorry I don't know what I was thinking of I bought denso also. I think it's my seadoojetski that uses ngk. Thanks for answering my question. Happy holidays
  5. Dec 27, 2014 at 8:36 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    NGK puts a special plating on the threads they say serves the same purpose as anti-seize.
  6. Dec 27, 2014 at 8:45 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    when i changed mine at 30 thousand the ngk's were noticeably worn more than the denso's were. replaced with denso's
  7. Dec 27, 2014 at 1:21 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    Just did mine, first interval since buying it and the previous owner had Densos in the passenger bank, NGKs in the driver. It's possible someone got lazy and only swapped one bank last time around (not wanting to disconnect the heater core hose/support bracket to get at the last 2 cylinders there) but wow, those NGKs were dead while the Densos still had about 1/3 life left at least.
    Stick with OEM and feel free to use a little anti-sieze on them either way, it's not going to hurt and it might just help.
  8. Dec 27, 2014 at 1:30 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Seems that is the way they leave the factory, one bank NGK, other bank Densos.
  9. Dec 27, 2014 at 1:43 PM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    This is how Toyota decided to show both of their plug suppliers they were getting 50% of the business.
  10. Dec 27, 2014 at 1:45 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Yes. They come from the factory one side NGK, other side Denso. Toyota wisdom:rolleyes:
    Forgot to mention, I apply anti-sieze to every sparkplug I change. And about everything else I touch on my truck. (Wisconsin winters)
  11. Dec 27, 2014 at 1:49 PM
    lowcountrytj
    lowcountrytj Third Member
    Phillip
    Probably at Work
    2012 DCLB TRD SPORT "BLACKOUT"
    I always use Anti seize regardless. As long as they are properly torqued no worries. I always check torque on the next oil change following plug replacement. Just my 2cents.
  12. Dec 27, 2014 at 2:48 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +1
  13. Dec 27, 2014 at 3:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i find it interesting that the densos are the better wearing plugs. I know on the 3.4L NGK plugs were the ones that look almost new at 100k and the densos look like a 2 dollar whore.
  14. Dec 28, 2014 at 10:02 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Differences in spark plug wear may simply be:
    A: Fuel - good fuel vs. cheaper brands
    B: Engine Seal - Valve stem seal/piston ring leakage
    C: Driving conditions - stop-n-go vs. highway
    D: Type of driving - aggressive vs. conservative
    Drive for a year with NGK; then a year with Denso and compare.
  15. Dec 28, 2014 at 10:08 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I use NGK and anti-seize
  16. Dec 28, 2014 at 10:51 AM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    x2
    The gap on my three Densos was close to 0.050, and the NGKs were closer to 0.060. I'm sticking with Denso.
  17. Dec 28, 2014 at 12:54 PM
    t4daddy
    North Alabama
    I'm thinking it's past time to change mine, what is the proper gap?
  18. Dec 28, 2014 at 1:55 PM
    TACK
    Nevada
  19. Dec 28, 2014 at 2:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Anti seize EVERY spark plug change and the proper torque.
    I bought my plugs at the dealer and they're pre-gapped. Trucks been running fine (on my 2nd spark plug change).
  20. Dec 28, 2014 at 2:34 PM
    DocD
    Mn./SoCal
    09 access cab
    I don't think they are, I changed mine at 30k both were will within tolerance,
    if I were to pick one, it would be the NGK, only because that is what most Japanese car makers use, Yes they are usually a little more spendy. but I am not going to disagree with Japanese, engineers. I have never liked the idea of two different brand plugs in a vehicle, not sure why this is done, one can only guess, but by putting all NGK's in mine really smoothed out the engine, & gas mileage improved noticeably, maybe Denso's would do the same, I don't know. If I ever need new plugs I may try them.jmop
