Nice aftermarket wheels with close to stock spec's ?
Discussion in 'Wheels & Tires' started by vermintrex, Feb 5, 2012.
  1. Feb 5, 2012 at 10:35 AM
    vermintrex
    vermintrex [OP] Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    I really want to be able to fit front flaps again...so sick of the damage being done to the front doors.
    Currently running Koenig Countersteer Type X...they have -10 offset which works out to about 4" of offset....I think :rolleyes:
    I've got 1.6" of lift up front which cured the worst of the fender well rubbing, except at full lock in reverse...but I can't fit flaps at all...not the stock flaps or the Husky's I bought in the hopes they'd fit.
    I'd love to run some AR ATX Mojave's, Artillerys or even Ledge...but I don't know enough about offsets / back spacing....even after reading all the sticky's...just not smart enough haha
    All I know is the stock 17's with plus sized 265/70/17's never rubbed at all....even before adding 1.6"s of lift.
    So the simple solution would be to find something closer to stock spec's than the Countersteer's....but still look tough/industrial
    Any suggestions's guys ? Just want to stop thrashing the finish...and yeah...I know it looks more badass without flaps...but I'm over it :D
  2. Feb 5, 2012 at 10:41 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I'm running 16x8 0 os and 4.5 bs with 265 70 16's. Fits fine with no rub and flaps are stock except for trimming the length of the fronts.
  3. Feb 5, 2012 at 10:49 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    thanks for the reply...but I think my tires would be still be larger than yours..265/65/17's = 265/70/16's if I understand correctly....but I wouldn't be surprised for a second if I had that wrong :D
    edit: looks good by the way !
  4. Feb 5, 2012 at 10:55 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    just because I learned how to calculate metric sizes the other day here on TW....
    265/65/17 = 30.56" tire
    265/70/16 = 30.6" tire
    same overall diameter :)
  5. Feb 5, 2012 at 10:58 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    sweet...so I am unfairly super intelligent after all ;)
  6. Feb 5, 2012 at 11:07 AM
    TacoDawgfan
    Georgia
    Yeah I know. But I though you were asking more so about the off set and back spacing. Plus with you having a lift I knew that changed things also. But was just trying to help as much as I could. Maybe others will have better info for you.
  7. Feb 5, 2012 at 11:23 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    oh I am talking about bs and offset for sure...it's just that my tire size is different than your's I'm not sure that what is working for you would work for me.
    really appreciate the input bro...thanks for trying to help !!
  8. Feb 5, 2012 at 5:20 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    just bumpin this shit
  9. Feb 6, 2012 at 8:45 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Your countersteers rub because they stick out too far with their 4" of BS. If you get a rim with 4.5"-5.5" BS you will alleviate the rubbing.
  10. Feb 6, 2012 at 1:28 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    ok cool...thanks for the info.
    So if the ATX Mojave's are 4.44" BS and 0 Offset and the ATX Artillery's are 4.52" BS and -12mm Offset they should both fit without rubbing ...or at least better than my current 4" BS wheels ?
    thanks again for the help
  11. Feb 6, 2012 at 1:41 PM
    KPT
    09 Prerunner
    Yessir.
  12. Feb 6, 2012 at 2:40 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    thanks man....guess I'm shopping for wheels :D
  13. Feb 6, 2012 at 2:44 PM
    KPT
    09 Prerunner
    I just re-read your OP and saw that you want to run your flaps again. With 265's the 8" wide wheels (mojaves) will give you a better shot at that than with the 9's (artillery) because they will stick out 1" less.
  14. Feb 6, 2012 at 3:18 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    ok...good to know...and just to clarify they're 265/70/17's...still think the mojaves will work ?
  15. Feb 6, 2012 at 4:44 PM
    Large
    Large Red
    Just stick close to 4.5" of bs, I ran 265/70 on stock sport wheels with flaps with no rub lock to lock.
  16. Feb 6, 2012 at 6:48 PM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    I ran the same size on my stockers and no lift without issue to but they are more like 5.5" bs, so I just wanna make sure 4.5" bs isnt gonna stick out too much and cause problems....but if KPT thinks it'll work that's good enough for me.
