Nicked my suspension mounting bracket, am I okay?
Discussion in '1st Gen. Tacomas (1995-2004)' started by robman3, Jun 13, 2019.
  1. Jun 13, 2019 at 10:09 AM
    robman3
    robman3 [OP] Member
    1997 3.4l TRD
    Nicked my suspension mounting bracket while using a grinder to cut the bolts out, am I okay? The bracket is normally 1/16” (0.0625) thick, I ground down the lower quarter of it to approx 1/32”-3/64” (0.0155”-0.0312”). I think the weight of the axel assembly is press up into the mount normally...do I absolutely need to re-weld the damaged part of the mount? All input welcome thanks in advance!
  2. Jun 13, 2019 at 10:11 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I would, but I also have a welder handy.
    Wulf likes this.
  3. Jun 13, 2019 at 10:20 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Man, I thought when I read the title that it would be OK but kind of cringed when I saw the photos. I bet you'd be OK but I'd want more material personally.
    How much 'wheeling do you do?
    SR-71A, CanisLupus and Wulf like this.
  4. Jun 13, 2019 at 10:32 AM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    Yeah, nicked would be an understatement... I'd say nearly decapitated would work better.
    OP, you're right that while under normal driving, most of the forces are going to be directed upwards, but as soon as that rear end hits a dip in the road or you're wheeling a bit, that leaf spring will flex down putting forces towards the damaged part. You're also forgetting about horizontal forces on the mount. Those leafs already sit at a slight angle to the frame and they may bend your damaged portion outward.
    I really think your best bet would be to grind off this mount and weld a new one on... there are several manufactures that make these as they are a common issue, especially for rusty frame folks.
    http://www.lowrangeoffroad.com/welded-toyota-leaf-spring-hangers.html
  5. Jun 13, 2019 at 10:36 AM
    robman3
    robman3 [OP] Member
    1997 3.4l TRD
    Better safe than sorry, I have a neighbor with the equipment and ability to fix it. Kind of curious about the frames strength anyway, Thanks for your input. I do get out on a lot of washboard/rutted our roads. No dedicated “wheeling” but yeah, Suppose the peace of mind is worth it. Where I live a break down can mean $12k helicopter extraction or a flatbed and cutting torch
  6. Jun 13, 2019 at 10:53 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I don't think that it'd be a sudden catastrophic failure but I suspect the tab will eventually crack. I'd do just like @AKsavanaman says, grind off the mount (which you will be able to do, I have complete faith!) and weld on a new one.
    CanisLupus likes this.
  7. Jun 13, 2019 at 11:08 AM
    robman3
    robman3 [OP] Member
    1997 3.4l TRD
    Thanks Dave...I'm using a Metabo grinder and its so squirrely, way to much grinder for the application. In fact, knowing what im capable of from past "experience", im surprised thats all the damage I managed to inflict.
  8. Jun 13, 2019 at 11:25 AM
    Indy
    Indy Master of all I survey.
    Your leg's off!
    No it isn't, just a flesh wound!
    That's bad enough to merit repair.
    Matic likes this.
  9. Jun 13, 2019 at 11:25 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I think a hack saw or maybe a Sawz-All is the appropriate tool, if what you were doing is cutting off a rusted spring bolt.
  10. Jun 13, 2019 at 11:50 AM
    robman3
    robman3 [OP] Member
    1997 3.4l TRD
    Tried the sawsall...my patience is thin...probably deserved it. Those brackets posted are twice the thickness and prep/install really isn't that much work..assuming i dont knick my frame. Focus on the positives i guess...
  11. Jun 13, 2019 at 11:52 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Fix that. Good luck.
  12. Jun 13, 2019 at 11:54 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    If you leave it like that it will tear thrue in no time. I'd just weld a new hanger on there.
    Mully likes this.
  13. Jun 13, 2019 at 11:58 AM
    robman3
    robman3 [OP] Member
    1997 3.4l TRD
  14. Jun 13, 2019 at 12:08 PM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    This image is concerning
    In theory yea it's compromised since there's a designated torque spec for that thru-hole, now all that's changed.
    But then again most of the force will likely be exerted upward where most of your mount is still whole. So you'd probably be fine
    I vote welding it up
  15. Jun 13, 2019 at 12:46 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  16. Jun 13, 2019 at 12:48 PM
    jbrandt
    Justin
    When it's just sitting in your driveway, sure, most of the force is probably straight up, but not when it's bouncing around on the road or on the trail and under articulation...
  17. Jun 13, 2019 at 1:07 PM
    buildataco
    buildataco Well-Known Member
    Brian
    2003 Tacoma Extended Cab 4 wheel drive
    5100 All Around Dakar Leafs 881 Coils Smittybilt Overlander RTT 265/75/15 Falkens Pro Comp Wheels
    This is prime time to learn to weld. You can get a cheap MIG welder and get that fixed easy. I think you might be okay...but that 'might' is pretty scary.
  18. Jun 13, 2019 at 1:37 PM
    Wulf
    rock raisin
    Weld it up and then grind it flat like it was
  19. Jun 13, 2019 at 1:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Myself I would fix it when it broke.
    Unless your into serious Rock bouncing where that wheel is going to hang in the air quite often .
    I always use a grinder to cut those bolts off
  20. Jun 13, 2019 at 1:47 PM
    jbrandt
    Justin
    That material isn't very thick. Seems you're likely to warp it pretty easily as you're building up the weld. I'm sure it could be done, but certainly not by a novice first time welder...
    IMO, you'd be better off cutting the stock hangers off, and replacing them with some 1/4" beef.
    If you're planning on doing suspension work, bumpers, etc... I'm not sure I'd go the "cheap welder" route. I'm regretting the Lincoln 125 welder I got (not really even "cheap", at least compared to a HF one, lol). It was a PITA to weld my bumper with it. Thinking I'm going to sell mine and get a 180 before I do a rear bumper.
