Nimble9 has a Fozzy
Discussion in 'Other Builds' started by Nimble9, Jul 9, 2018.
  1. Jul 9, 2018 at 7:47 PM
    Nimble9
    Nimble9 [OP] visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Creating this strictly to keep track of what I’ve done to her. Bought in May of 2018, with 100,300 on the odometer!
    Current:
    When the Fozzie first met my tacoma:
    The day it was mine:
    Current 07/09/2018:
    Mods:
    Custom Ram mount phone holder
    15% tint all around
    Cut up new Rubber floormat for trunk liner
    Thule aero bars
    Thule sidearm bike trays
    To Do:
    - new windshield wiper fluid reservoir
    - DS Headlight
    MySubaru LINK
    Maintenance:
    ~80k | 12/10/2016 - head gaskets and heads machined
    ~88k | 3/25/2017 - new radiator
    ~95k | 3/17/2018 - New Alternator
    99,569 | oil change
    99,798 | front diff oil changed
    100,158 | tranny fluid and filter
    100,579 | front pads and rotors
    101,745 | NGK Platinum spark plugs
    103,428 | 4 wheel alignment
    103,856 | Coil Pack and wires
    104,626 | OEM timing belt, OEM T-stat, OEM water pump, OEM idler pulleys, Fresh coolant, Rear drum shoes, inspection
    104,953 | 7/9/2018 - MAF and Throttle Body Cleaned
    105,376 | 7/25/2018 - new tires and wheels, balanced
    106,171 | oil change, Mobil 1 synthetic high mileage, k&n filter
    111,063 | oil change, Mobil 1 synthetic high mileage, K&n oil filter
    111,876 | 11/11/2018 - Optima Yellow Top Battery
    113,402 | 2/2/2019 - Oil change, Mobil 1 synthetic high Mileage, K&N Oil filter
    113,402 | 2/2/2019 - NGK Laser Platinum Spark Plugs
    117,286 | 7/9/2019 - Oil Change, Mobil 1 Synthetic High Mileage, K&N Oil Filter
    117,315 | 7/11/2019 - New Spectre Air Filter
    118,356 | 8/5/2019 - New Front Catalytic Converter
    120,384 | 10/1/2019 - Oil Change, Valvoline Synthetic High Milage, k&n oil filter
    124,477 | 2/1/2020 - Oil Change, Valvoline oil and K&N oil filter
    128,088 | 8/12/2020 - NGK Irridium Spark Plugs, Cleaned the Throttle body
    128,777 | 9/1/2020 - Oil Change, Valvoline Oil and K&N Oil Filter
    132,319 | 2/5/2021 - valvoline high milage 5w-30 k&N oil filter
    136,711 | 5/17/2021 - Oil Change, Valvoline 5w-30 and K&N Oil Filter
    138,348 | 7/12/2021 - AC Tensioner Pully Replaced
    3pooches, 96accord, Tatts521 and 3 others like this.
  2. Jul 9, 2018 at 7:50 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Throttle body before and after pics
    Gross
    Much better
  3. Jul 10, 2018 at 2:51 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    HELPFUL INFO:
    Rear Diff oil change info:
    Ok a little more details with part numbers.
    803926090 - Front Differential Seal (also tranny seal on MT cars) - Torque is 51.6 Ft-Lbs
    11126AA040 - ATF Drain Seal - Torque is 18.1 Ft-Lbs
    Torque for rear diff plugs is 36.1 ft-lbs.. FSM specifies to use Three Bond 1105 on the threads, Permatex and 3M make equivalents that are easier to find and cheaper.
    Front diff holds ~1.2 qts 75W-90
    Rear diff holds ~0.8 qts 75W-90
    Ignore my earlier 21mm socket comment, you need an 8mm Hex for your AT drain.
    T70 is for front differential drain.
    13mm Square is for rear diff drain and fill plugs.
    Tranny Cooler
    https://www.subaruforester.org/vbul...ng-4eat-cooler-merged-thread-5574/index3.html
    3pooches likes this.
  4. Jul 11, 2018 at 3:34 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    So far so good, was having an issue where the car shut off after it was running for a bit, but after new coils and wires the car ran fine! just drove it an hour 1 way to work.
    I think the problem was the wires, the old ones seemed to not "pop" onto the sparkplugs as nicely and as firmly as the new ones.
    No codes yet!
    If it stays this way, new tires or wheels and tires soon!
    Timing belt scheduled at Orbachs Automotive in Denver PA for the 20th of July!
  5. Jul 12, 2018 at 5:12 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    150 miles in, no codes, no pending codes, car is running smoother than ever, and at idle it's much quieter than I remember.
    I also added foam to the drivers side door near the mirror and boom all the wind noise is gone!
  6. Jul 24, 2018 at 5:14 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Fozzie took me and my buddy to blue!
    Boy does it run awesome now after the timing belt and all the other new parts in the top post!
  7. Jul 24, 2018 at 5:25 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    How is dependability and market value of these? My girlfriend is going to need a new-used car soon and I would love to pick one of these up for cash
    But from my understanding Subaru's reliability is all over the place
  8. Jul 24, 2018 at 6:04 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    almost new tires on old outback wheels!!
  9. Jul 25, 2018 at 5:21 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Before:
    After:
  10. Aug 10, 2018 at 7:42 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    106,171 oil change! Mobil 1 synthetic, k&n oil filter!
  11. Aug 13, 2018 at 5:34 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Pic of current mileage right after oil change (for record purposes)
    fatfurious2 likes this.
  12. Aug 13, 2018 at 5:38 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    my neighbor is selling his.. maybe you want it for parts?
    its an 08 manual, but the transmission is going.. still driveable, but horrible noises
  13. Aug 13, 2018 at 5:43 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    if he is parting out, i'd be interested in the driver's side headlight! lol
  14. Aug 13, 2018 at 5:45 AM
    fatfurious2
    David
    Ashburn, VA
    I think he is selling as a whole. I couldnt find his listing to post here
  15. Aug 13, 2018 at 10:06 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    it's all good, i'm squirreling away all my money for the future lol
    fatfurious2[QUOTED] likes this.
  16. Sep 1, 2018 at 7:25 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Made a thing for our road trip to Asheville
    It’s on outdoor Velcro so it’s removable too
  17. Sep 4, 2018 at 4:44 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Pics from our road trip to Asheville!
    River arts district
    Scenic overlook
  18. Sep 4, 2018 at 4:54 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I was very close to buying a 2007 Legacy Wagon. Beautiful looking car and was going to use it for work commuting. Didn't get it for a few reasons. 1. Head gasket issues scared the shit out of me. 2. Would have ended up modding it. 3. I've been working a lot more from home lately. I still want it.
  19. Sep 4, 2018 at 5:04 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I LOVE those wagons! I was looking at those but I bought this one from my friend. It's my DD so I haven't done too much of it, heads were already machined and new OEM gaskets installed, I just had the timing belt, water pump, idlers, and t stat done at the same time. I did the coil, spark plugs, wires, and when my friend owned it alternator and radiator!
    I know what you mean by modding it. I just tinted it out and sprayed the wheels black, i just want it to last another 100k haha
    diabetiktaco[QUOTED] likes this.
  20. Sep 4, 2018 at 5:13 AM
    planters15
    planters15 Well-Known Member
    Q (irfan)
    Pa - Spring City
    2010 Double Cab SR5 6spd
    Stuff to make go more off road
    Nice daily.
