Nimble9 Nerds Out - Custom Water Cooled Computer and 3D printer build
Discussion in 'Technology' started by Nimble9, Dec 20, 2021.
  1. Feb 11, 2022 at 7:29 PM
    #61
    Nimble9
    Nimble9 [OP] visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    i know! I feel wildly lucky that the first time I ever played the Newegg shuffle I won!
    sourcing waterblocks is another story lol
  2. Feb 12, 2022 at 7:23 AM
    #62
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  3. Feb 12, 2022 at 11:21 AM
    #63
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  4. Feb 13, 2022 at 2:25 PM
    #64
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Cables ordered! went with 8" so I can plug them into stock 8 pin PCIE cables on the backside.
    Now should I run a new line and play with the 3080 air cooled or just wait for the water block to arrive and then assemble everything.
    hmmmmmmmmm
  5. Feb 15, 2022 at 5:34 AM
    #65
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Gunshot-6A likes this.
  6. Feb 15, 2022 at 8:02 AM
    #66
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  7. Feb 15, 2022 at 10:02 AM
    #67
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  8. Feb 15, 2022 at 11:15 AM
    #68
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Actually compared the card I got to other 3080s and I really lucked out:
  9. Feb 16, 2022 at 5:07 AM
    #69
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Well the 3080 12gb arrived yesterday!
    Thing is a beast
    Couldn’t wait the 2 weeks for the water block to arrive so bypass it is.
    I LOVE this upgrade. 17 fps to 200 plus on ultra everything.
    can’t wait for the water block to arrive!
  10. Feb 28, 2022 at 7:48 AM
    #70
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Well my order wasn't on the latest import from ModMyMods so it'll likely be the 18th when the next shipment arrives. Hopefully it's on there and obviously with current events it's not that big of a deal.
    Until then I ordered a heatsink and thermal pad to help control the backplate temps as they're pretty high.
  11. Mar 1, 2022 at 5:58 AM
    #71
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Forgot to share!
    Snagged a new monitor as it was too good of a deal to pass up
    Happened to walk by it at Costco
    saw it was 1440p at 165 Hz, did a double take and it ended up on one of our carts!
    Into the dadwagon to my house
    Fargo Taco, Gunshot-6A and MY50cal like this.
  12. Mar 1, 2022 at 6:08 AM
    #72
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  13. Mar 1, 2022 at 8:39 AM
    #73
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    So I decided to pony up and snag this on sale.
    https://cpu.userbenchmark.com/Compare/AMD-Ryzen-9-5950X-vs-AMD-Ryzen-7-2700X/4086vs3958
    It's 38% faster overall, and the next gen AMD processors have an LGA socket meaning I'll have to upgrade my MOBO if I went that route.
    I should be pretty future proofed for years to come now.
    The last pieces I would like one day are SSD storage to replace my HDD and a quieter PSU
    I guess it's time to update my bios :bananadead:
  14. Mar 1, 2022 at 11:29 AM
    #74
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    After further research I'm in a dilemma. my MSI X570 A pro has weak VRMS which aren't the best for the 5950x.
    The CPU is compatible with the motherboard, however the weak VRMS could throttle the CPU without proper cooling.
    Technically I should upgrade my motherboard to have higher quality vrms, so that they don't throttle my cpu. The only reason I seized the deal was to avoid upgrading my MoBo, because if I was going to upgrade my cpu and MoBo I would just wait for the latest AMD zen 4 stuff.
    Maybe I'll just send it, and flip my rear exhaust fan to intake and add some heat sinks to the existing VRM heatsinks
  15. Mar 3, 2022 at 4:43 AM
    #75
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Well this sucked. Opened the unopened Amazon box to find this:
    This was clearly used and I peaked at the chip to see a few bent pins as well.
    I tried to replace it but replacing won't work since it's one per customer.
    I decided to buy a 5900x on sale for now, hope it comes in brand new shape, so I can hold it and possibly return it for the 5950x.
    After doing some research the 5900x in stock form outperforms the 5950x in a few key areas regarding Solidworks: https://www.pugetsystems.com/labs/a...5-AMD-Ryzen-5000-Series-CPU-Performance-2011/
    Also going to do some research to compart it for gaming
  16. Mar 5, 2022 at 5:36 AM
    #76
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    5900x arrived without an opened seal, so that's good at least
    https://www.amazon.com/dp/B08164VTWH?ref=ppx_yo2_dt_b_product_details
    Unless I overclock, it looks like the 5900x might be faster than the 5950x for gaming and some productivity tasks so I think I'll be happy with it. Not to mention that it'll be 50% faster than my current 2700x and that the cost difference can go towards a new PSU. What really gets me stoked, is that the 8 core 16 thread 2700x and my new 12 core 24 thread 5900x are almost the same regarding power draw. That's absolutely wild!
    I'm also considering getting some slim fans so the top rad is a push pull setup, but only if the 12gb 3080 produces so much heat that the water loop increases in a dramatic fashion.
    Slim fans - https://www.amazon.com/dp/B07P989QSM/?coliid=I39JGURDPOQSQ5&colid=1JJYF1CABU3OY&ref_=lv_ov_lig_dp_it
    Also, I need to flip my rear exhaust to be rear intake so I can cool my VRMS a bit better. Going to order this to help with dust control: https://www.amazon.com/dp/B07LG1XLPN/?coliid=I3726YAEX8WFIO&colid=1JJYF1CABU3OY&ref_=lv_ov_lig_dp_it
    As soon as the water block comes (hoping by the end of March) I'll be able to finish this iteration of the build and simply enjoy it.
  17. Mar 7, 2022 at 1:02 PM
    #77
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Well cancelled my order with ModMyMods.
    My block was not in the past 2 shipments from Alphacool and they wouldn't have any available until later in the month if any, so I bought one that's arguably better:
    https://www.newegg.com/p/37B-000X-004X4?Item=9SIAEMWEYC1574
    This block from Bitspower is confirmed to work with the new 3080 12gb and actually covers more of the chips and hot components than any other block. At double the cost it better. Shipping from Taiwan so I hope it’s here by the end of the month!
    Gunshot-6A and Bot_Chu like this.
  18. Mar 9, 2022 at 6:24 AM
    #78
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I was hoping my Bitspower Block would arrive by the end of the month, but I woke up to a notification that the item has shipped!
    I check the tracking number and it's supposed to arrive today!?
    I ordered the block on the 3/7/2022 so it's a bit sus that it's already arriving. Maybe they had one in stock already?
    I hope it's the right block, because I've has the worst luck getting a water block for this card :bananadead:
    Link for instructions
    https://shop.bitspower.com/index.php?route=product/product&product_id=8025
  19. Mar 9, 2022 at 7:14 AM
    #79
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    What a PITA.
    They attempted to deliver but my wife was likely in a meeting and couldn't come to the door so they didn't leave the package. SO annoying I've ALWAYS hated FedEx and this just perpetuates the hate.
  20. Mar 10, 2022 at 4:50 AM
    #80
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    After a month I finally have all the pieces for the next phase of this build.
    new parts include:
    • 5900x
    • Gigabyte 3080 gaming OC 12gb
    • Bitspower Water block
    • MP5WORKS active backplate
    • New EK fittings
    Actually still waiting on DIYMod cables to arrive. But the system will run without them!
