Nissan Frontier Quirks and Oddities
Discussion in 'General Automotive' started by KenLyns, Aug 15, 2014.
  1. Aug 15, 2014 at 7:25 PM
    KenLyns
    KenLyns [OP] 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    By "luck" I had a rental 2014 Nissan Frontier DCSB 4x4 for a week while traveling on vacation. Figured I'd share a few quirks and oddities. Click on each photo for full-size.
    IMG_8741s%2Bfrontier_a0445a03b6fb226fb35d307b9e1e6bf3eb333ab0.jpg IMG_8094s%2Bfrontier%2Btacos_f588d04d81a744849bba252f462ed94117785ff2.jpg
    • VQ40DE engine is powerful enough. Old-style straight-pull shifter with O/D button difficult to shift amongst 4-2-3-1. Bumped it into neutral by accident a few times.
    • I averaged 18 mpg in the winding mountain roads (but minimal traffic). The last day had a 260-mile straight highway drive at 70 mph that averaged 22 mpg.
    IMG_7600s%2BVQ40DE_17abed80bbcc026f8432c95fc80127130a498702.jpg IMG_7594s%2Bcup%2Bholder%2Bfury_58b153e1109a96ab73f87bb98bb4bd576c708723.jpg
    • Brake pedal feel is linear, but travel is too long. Brake pedal is too far forward relative to the gas pedal.
    • Ignition key position in the dash is superior to the Taco's - keychain never stabbed knee.
    • Seats are uncomfortable. Cushion and seatback simply don't conform to the body contours as well. Inadequate side bolstering and lumbar support. Not sure if Nissan offers 2 different seat designs a la SR5 and TRD.
    • Pressing the horn (most frequently used steering wheel button) requires taking a hand off the wheel, similar inconvenience as 2012+ Taco wheel design.
    • Rear seat less roomy than Taco DC, with low cushion and less leg room.
    • 4WD selector knob works the same way as the Taco's.
    • Center console bin houses 3rd 12V plug and USB port. USB port could charge my Blackberry.
    • Two gloveboxes each individually smaller than the Taco's.
    • Cupholder rubber liner comes out with the bottle, just as annoying as the Taco.
    IMG_7595s%2Bdual%2Bglovebox_1570f6e72234471979556ef2a389ab03ba52ed92.jpg IMG_7309s%2Bfrontier%2Bdash_fc12ef331049faa58815b68d20c3ce1a51413496.jpg
    • Not sure why there's a divider bar on the rear door window. Driving at city speeds with the rear window down causes rhythmic "woop, woop, woop" buffeting sound initially thought to be coming from the tire.
    • Off-road ability is about equal to a stock Taco SR5. I've only taken it on "easy" trails due to the low front bumper cover.
    • Tire is BFG Long Trail in P265/70-16, same size as Taco TRD OR. Cornering grip is decent on pavement.
    IMG_7895s%2Bfrontier%2Bfront%2B34_05c1290998bbfc45d3d460240b0c1e878556df07.jpg IMG_7596s%2Bfrontier%2Btire_1ba4d30f9230238f3fb9edd58870a111c8586fb1.jpg
    • Plastic bedliner "buckles" under your feet, generally feels more flimsy than the Taco's composite bed.
    • Tailgate is fitted very "loosely", with big gaps all around that lets light through.
    IMG_8228s%2Bfrontier%2Bwheeling_87ad362cddd4403db01adc9a831261cee23856ad.jpg IMG_7592s%2Btailgate%2Bgap_c7fb8240391360e32f638cb69029be63ceabb121.jpg
    • A/C condensation drips from the frame at roughly the same place as the Taco.
    IMG_7640s%2Bfrontier%2Bac%2Bleak_7809f48626efa073da42ca55775eb44ac372db1f.jpg IMG_8744s%2Bfrontier_b7dc4cadb473d5a7cef44ab3fb09bf2f6abb36fb.jpg
    IMG_7638s%2Bfrontier%2Brear%2B34_3c717326026671ae1611b7f6120aff6f2cdc4acf.jpg IMG_8229s%2Bfrontier%2Brock_6a9e414852a9e9a3044b18595ea10c306c59d47b.jpg
    PennSilverTaco and surforegon like this.
  2. Aug 15, 2014 at 7:30 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    Can you show the rest of your signature?
    PennSilverTaco likes this.
  3. Aug 15, 2014 at 8:21 PM
    KenLyns
    Belly of the Beast
    Not since they shut down UG. :(
  4. Aug 15, 2014 at 8:35 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Interesting, nice review. My brother loves his 2012.
    What’s the difference between the 13 and 14? When I checked out my brother's 4x4, I don't see how off-road capability is equal. If you have a chance, crawl under your front tires and check the coilover's. They are so small, almost like a car's (coil buckets are mounted way low on the Frontier). When comparing Bilstein 5100's, 1st gen Tacoma's have longer shocks and 2nd gen's are longer, even when compressed, than the Nissan's when extended :facepalm:.
    For a comparison, below are the 5100 specs:
    2013 Nissan Frontier: (~4.7" travel)
    *Collapsed Length (IN): 10.55
    *Extended Length (IN): 15.26
    2013 Tacoma: (~5.5" travel)
    *Collapsed Length (IN): 17.03
    *Extended Length (IN): 22.56
    2001 Tacoma: (4.7" travel)
    *Collapsed Length (IN): 13.86
    *Extended Length (IN): 18.62
  5. Aug 15, 2014 at 8:41 PM
    KenLyns
    Belly of the Beast
    ^Remember the motion ratio isn't 1:1 for the front suspension. All it takes is a slight difference in the shock mounting location on the LCA to make the wheel travel very different among the three truck models. Assessment of off-road capability is purely by seat of the pants on some of the fire roads and dirt trails I found.
    The difference is the Taco has a lot more upgrade parts available which significantly improve off-road capability, but you know this already.
  6. Aug 15, 2014 at 8:46 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Interesting post Ken. Your overview concluded or still coming in? Subbing for final thoughts.
  7. Aug 15, 2014 at 9:06 PM
    KenLyns
    Belly of the Beast
    To me the Frontier feels like a 90% Taco - every aspect is "almost as good" as the Taco but no aspect surpasses it. If the Taco didn't exist, I'd trust the Frontier off road more than the new Colorado.
  8. Aug 15, 2014 at 9:15 PM
    Grundletaint
    Grundletaint Well-Known Member
    Austin
    2012 crewmax tundra 4x4
    Debadged, derped, weathertech visors, antennax, tinted, need more money
    I think the rear windows have the divider bar because they use the same window parts for xterra rather than a new unit for frontier.
  9. Aug 12, 2017 at 9:42 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    My dad and I flew into Dallas, rented one of these at DFW, and drove it to Oklahoma City. It was exactly like the one you rented except silver.
    Pros:
    Surprisingly good factory sound system
    Excellent A/C
    Plenty of power under the hood
    Cons:
    Rough, stiff ride
    2WD, and pretty sure it had an open rear differential (my Tacoma at least has what I refer to as a "fake posi rear," in the form of an automatic LSD added to the open rear differential)
    Overall quality didn't seem up to par with my Tacoma...
  10. Aug 12, 2017 at 9:48 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Holy thread revival Batman!
