Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Sep 27, 2020 at 11:24 AM
    #441
    bingo
    bingo Member
    David
    2016 Toyota Tacoma SR
    Is there any way this mod could be draining my battery? I did do the lighted switch.
  2. Sep 27, 2020 at 11:27 AM
    #442
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Is the switch staying lit when the truck is off?
  3. Sep 27, 2020 at 11:28 AM
    #443
    bingo
    bingo Member
    David
    No. Just wondering in the wiring if there would be something that is always hot and a drain.
  4. Sep 27, 2020 at 11:33 AM
    #444
    Puppypunter
    Johnny
    2019 Black SR
    I don't think so. The only hot wire I believe would be the one on the relay, but it shouldn't have load as long as the relay isn't pulled in. You could check with a multimeter if you have one. And depending on which one you might have, it might be a pain. Sorry, hard to trouble shoot this kind of stuff remotely.
  5. Sep 27, 2020 at 11:34 AM
    #445
    bingo
    bingo Member
    David
    Thanks
  6. Sep 27, 2020 at 11:41 AM
    #446
    Puppypunter
    Johnny
    2019 Black SR
    No problem. Good luck. But off the top of my head, I would think if the fogs aren't lit up, and the switch isn't lit up, you shouldn't have any draw from this set-up.
  7. Sep 27, 2020 at 2:31 PM
    #447
    bhanna8081
    bhanna8081 Active Member
    2020 SR 2.7 2WD
    It shouldn’t. If the switch light turns off when the lights are turned off there shouldn’t be any power draw.
    davidstacoma likes this.
  8. Oct 11, 2020 at 3:30 PM
    #448
    whitej938@ gmail.com
    whitej938@ gmail.com New Member
    James
    2020 Tacoma sr 4cly
    Do you have to change the stalk out in order for this to work seems like a lot of work is there a way around this ?
  9. Oct 11, 2020 at 3:34 PM
    #449
    caribe makaira
    Caribbean, Puerto Rico
    Re-read the first post...slowly....then again.
    lamjam and Boghog1 like this.
  10. Oct 11, 2020 at 3:42 PM
    #450
    James
    2020 Tacoma sr 4cly
    I did so I have to buy the stalk even if I am pre wired I still have to buy the stalk
  11. Oct 11, 2020 at 4:29 PM
    #451
    bhanna8081
    2020 SR 2.7 2WD
    You don’t have to go the stalk switch route. Read through the entire thread, somewhere someone goes over doing a dash switch instead of stalk switch. I followed that one instead. All the steps for the engine bay are the same, but a few more wires get hooked up in the cab.
  12. Oct 11, 2020 at 4:35 PM
    #452
    bhanna8081
    2020 SR 2.7 2WD
    Look on page 4 of the thread. The OP does the write up for the Pre-wired and goes over the install without removing the steering wheel. Sorry it took a minute to find it.
  13. Oct 11, 2020 at 4:39 PM
    #453
    caribe makaira
  14. Oct 28, 2020 at 1:25 PM
    #454
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    It's a bummer he sold the truck, but I spotted it in the wild. New owner seems to be appreciating the legend itself.
  15. Oct 28, 2020 at 1:28 PM
    #455
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    He who? Nitori?
  16. Oct 28, 2020 at 1:30 PM
    #456
    Snaeper
    Martin
    Phoenix, AZ
    Yeah, he edited the OP. First line.
    davidstacoma[QUOTED] likes this.
  17. Nov 27, 2020 at 10:39 AM
    #457
    ChuckTacoTruck
    ChuckTacoTruck Member
    Charleston, SC
    2020 Black SR DCSB 4x4 V6
    Just finished this mod with the OEM stalk switch on my 2020 SR. I’ll have to admit, the pucker factor was high as I was playing around with the airbag and the clock spring. But everything came right off and went back together flawlessly!
  18. Dec 4, 2020 at 8:53 AM
    #458
    Jimmywestco
    Jimmywestco Well-Known Member
    James
    2019 SR AC
    Intermittant wipers, fog lamps wired like factory, remote entry via SE Toyota Dealers kit installed.
    Hi can anyone here tell me the pin internal switching of the 2011-2016 fog lights switch? 84160-04020 What pins make to what other pins when the switch is operated? Trying to figure out how to use a different switch. For instance it appears that pin 4 makes to pin 3 - using that logic then we assume that pin 1 makes to pin 2 when they switch is actuated. Correct? Or is it switching differently? Why would illum beige and illum green connect? And what is on pin 26 of the body ECU? [​IMG]
    I'm thinking of using a switch with this pinout [​IMG]
    Thanks
  19. Dec 4, 2020 at 5:01 PM
    #459
    davidstacoma
    David
    NC
    What switch are you planning on Using? pin 1 does not make to pin 2, it’s dash illumination power to the switch led.
    See theses posts:
    Circuit diagram for a Mictuning switch. CH4X4 fog light switch connections are the same as the Mictuning but it uses a solid state switch. Wiring dash illumination to the switch this way allows the led brightness to be varied with the dash button you turn to change dash brightness.
    Read both posts thoroughly and you will understand how it all works and the circuits.
  20. Dec 4, 2020 at 5:49 PM
    #460
    Jimmywestco
    James
    2019 SR AC
    Hi David I've read through the threads - I ordered a caliraised switch https://caliraisedled.com/collectio...s/products/toyota-oem-style-fog-lights-switch
    .. trying to save a few bucks. OK I see your switch is the same.. that's very useful information.. think I can make this switch work using your method. I'll copy the info and save it. I am also using CaliRaised Led Fog lamps and mounts. How did you get the left switch panel off?
