Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Dec 4, 2020 at 6:04 PM
    #461
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Jimmy the Cali raised switch should work just fine wired per my first link, it has the same wiring instructions as the CH4X4 and Mictuning switch.
    Jimmywestco[QUOTED] likes this.
  2. Dec 4, 2020 at 6:08 PM
    #462
    Jimmywestco
    Jimmywestco Well-Known Member
    James
    2019 SR AC
    Intermittant wipers, fog lamps wired like factory, remote entry via SE Toyota Dealers kit installed.
    David I changed my post.. after looking at the links you provided.. It does look doable thanks to that info. How did you get the switch panel off. Today I tried to separate the steering column
    covers (clamshells) off and they will not come apart for me.. without using tools..it's like mine are glued together ...
  3. Dec 4, 2020 at 6:11 PM
    #463
    davidstacoma
    David
    NC
    Pm sent.
    Are you talking about the little switch panel to the left of the steering wheel? That’s the one I removed to wire to pin 26 and to the cargo connector and install the switch. I used a plastic trim removal tool to carefully pry out the upper left corner of the panel, them pulled out the other corners. Came right out.
    I could explain how to remove the steering column clamshell but not sure why you would do this if using a switch in the lower left panel, not required unless you are doing the stalk add on method instead of the switch.
    Edit: perhaps you want to remove the cover just to see if you were “pre-wired”. Just follow Nitoris first post for this however I too had a little trouble separating and later learned after screw removal, if you press in on both sides of the lower panel, it will separate the locking tabs there (toward the end of the sides toward the dash if I remember right.)
  4. Dec 4, 2020 at 6:20 PM
    #464
    Jimmywestco
    James
    2019 SR AC
    thank you
    davidstacoma likes this.
  5. Dec 4, 2020 at 6:23 PM
    #465
    davidstacoma
    David
    NC
    Most welcome, see my added comments in my last post.
  6. Jan 13, 2021 at 1:29 PM
    #466
    oyemengitsamie
    oyemengitsamie amie.
    Gainesville, FL
    2020 Toyota Tacoma SR V6 4x4 in MGM
    don’t mean to bring up an old thread... but do these steps also work if we decide to go a non OEM route? plan on getting Diode Dynamic fogs.
  7. Jan 13, 2021 at 2:08 PM
    #467
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Yes, the SS3 fogs will be plug and play as intended. Once you complete these steps
  8. Jan 13, 2021 at 2:11 PM
    #468
    oyemengitsamie
    Gainesville, FL
    thanks!
  9. Jan 13, 2021 at 3:23 PM
    #469
    tpp4
    tpp4 Well-Known Member
    Memphis
    2018 DCSB SR
    I can confirm, I installed the DD SS3 pros with this method. See the link below
  10. Jan 13, 2021 at 3:43 PM
    #470
    oyemengitsamie
    Gainesville, FL
    which link...?
  11. Jan 13, 2021 at 4:30 PM
    #471
    tpp4
    Memphis
    2018 DCSB SR
    in my signature
  12. Jan 18, 2021 at 12:08 PM
    #472
    MedicineMan2
    MedicineMan2 Active Member
    Jake
    North Texas
    2017 sr
    added extra tie downs in bed, the tool-less 32oz cupholder mod, fog lights in process...
    Does everything here work the same way on SR5's? I checked under the steering wheel and I do have the 2 wires so it appears to be prewired..also have the connection on center bumper behind the grill.
  13. Jan 18, 2021 at 12:09 PM
    #473
    bhanna8081
    bhanna8081 Active Member
    2020 SR 2.7 2WD
    It will operate as if you had fogs installed from the factory
  14. Jan 18, 2021 at 12:10 PM
    #474
    caribe makaira
    Caribbean, Puerto Rico
    Only if he adds the correct light stalk...
  15. Jan 18, 2021 at 12:11 PM
    #475
    MedicineMan2
    Jake
    North Texas
    2017 sr
    but as far as the process described, I can follow all the steps the same way on my SR5?
  16. Jan 18, 2021 at 12:12 PM
    #476
    MedicineMan2
    Jake
    North Texas
    2017 sr
    I am planning on doing a dash switch instead of the new stalk. Just want to make sure I can follow these directions on an sr5
  17. Jan 18, 2021 at 12:17 PM
    #477
    caribe makaira
    You're golden.
    If you jump the blue to the green on C11, the fogs illuminate with the Tail/Parking light. No added switch.
    MedicineMan2[QUOTED] likes this.
  18. Jan 18, 2021 at 12:20 PM
    #478
    bhanna8081
    2020 SR 2.7 2WD
    Dash switch works as well if wired in correctly. I did it since I wasn’t thrilled about messing with the airbag lol
    MedicineMan2 likes this.
  19. Jan 18, 2021 at 12:24 PM
    #479
    bhanna8081
    2020 SR 2.7 2WD
    Yup. The method for a dash switch, the way I did it, is also on one of the pages in this thread.
  20. Jan 18, 2021 at 12:24 PM
    #480
    MedicineMan2
    Jake
    North Texas
    2017 sr
    Did you follow the directions on this thread? I'm going to have a friend help with this since I don't know much about wiring and don't want to mess with the airbag either. I was planning on following this guy's directions on youtube until I found out it was pre-wired.... https://youtu.be/zr82GLFWzPc
