Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Feb 12, 2017 at 8:15 PM
    #41
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    So if the truck is pre-wired from the body ECU can you still use the switch from the second gen? It seems like you would have to trace the wire back some, cut it, and run it to the dash mounted switch. Am I understanding this correctly?
  2. Feb 23, 2017 at 6:22 AM
    #42
    Heifetz17
    Heifetz17 Member
    Billings
    2016 Tacoma SR Gray
    Off road wheels and tires
    I can confirm that my '16 access cab 4 cyl is pre wired for fogs up to the switch. I'll be tearing into this as well for a "factory" install and will post my results. I work in a body shop so pulling the airbag is nothing to me!
    Storman, 7r41lbr34k3r and fdb03taco like this.
  3. Feb 23, 2017 at 6:44 AM
    #43
    fdb03taco
    Danny
    SOMD!
    If it's pre-wired to the switch do you just need to pull the steering wheel to change out the stalk and install the fog's in the bumper? No more having to pin the harness and stuff correct?
  4. Feb 23, 2017 at 6:58 AM
    #44
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Nice write up! Thanks for putting all of that together!
  5. Feb 23, 2017 at 7:27 AM
    #45
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Subbed. I'm assuming convenience package is prewired, and utility not? I can check mine tonight. Would definitely be interested in a revised process for prewired, especially considering the $25 coupon i just got from Olathe Toyota.
  6. Feb 23, 2017 at 7:31 AM
    #46
    fdb03taco
    Danny
    SOMD!
    I need some clarification on the right switch for the stalk control as well. There's a few different ones out there. Some look the same, but have one number different in the pn.
  7. Feb 23, 2017 at 8:56 AM
    #47
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Parts diagrams never show the actual differences, it's just a stock drawing of what the assembly vaguely looks like.
    My understanding is the correct P/N for stalk switch is: 84140-0R030 (the "without" fog switch is *R020)
    I haven't gotten confirmation on this yet. If someone would be so generous as to confirm on their pre-wired truck, @Heifetz17 maybe... (You should see a BLUE wire in body ECU pin 26 described in my guide)
    I could update this guide for pre-wired folks, because then it would really just be swapping in the stalk and plugging in the relay/ fogs, no crawling around under the dash necessary.
  8. Feb 23, 2017 at 9:27 AM
    #48
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I have an SR utility and would like to do the fog light mod I can check mine tonight
    Storman and fdb03taco like this.
  9. Feb 23, 2017 at 9:40 AM
    #49
    Heifetz17
    Heifetz17 Member
    Billings
    2016 Tacoma SR Gray
    I have my switch, lights, and bezels on order. I'll confirm this weekend if I have the wire at the computer and the harness from the computer to the lights. If so it should just be plug and play.
    fdb03taco likes this.
  10. Feb 23, 2017 at 12:26 PM
    #50
    fdb03taco
    Danny
    SOMD!
    I have a DCSB SR with convenience package. I can check mine and report back as well.
    @Nitori thanks for the confirmation on the switch!
  11. Feb 23, 2017 at 5:36 PM
    #51
    Hiluxski
    Ventura California
    I don't think my Tacoma is prewired, I can't find the wire that everybody's telling me to look for
  12. Feb 24, 2017 at 5:33 AM
    #52
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    As promised, here is my picture. SR 5MT w/ convenience package. Looks like I'm going to be getting some fog lights!
    fdb03taco and Farcedude like this.
  13. Feb 24, 2017 at 6:08 AM
    #53
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Liking the shit outta this, because it means I likely have the wiring too. (SR, 5MT with conveniene package)
  14. Feb 24, 2017 at 8:53 AM
    #54
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Can you check your body ECU terminal under the dash for the wire there, please? It should be a blue wire going in to the red circled pinout:
    Black wire to the left of it, green wire under it. Once I have confirmation on this I can amend the guide a bit. (See the OP for more info, I think you could possibly peer up there with a flashlight and see without any dash removal)
  15. Feb 24, 2017 at 9:46 AM
    #55
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Okay, I had a look. You will have to forgive me, as electrical is a weakness of mine ... so I had to google what a body ECU was.
    I'm pretty sure I can see the terminal, peeking through/past my OBDII port ... and there is definitely a blue wire going in at the approximate location. Well, If I'm looking at the correct terminal, of course. I would have to confirm by taking the dash panel off as I cannot see the terminal face since I'm sort of looking around a corner at it. The wires are tough to track from the perspective I can see from, and I'm red/green colorblind ... so outside of blue I will always question what I am seeing.
  16. Feb 24, 2017 at 10:05 AM
    #56
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I stole this pic from Corey's write up. Circled in yellow (?) is the terminal I was looking at. Is this the correct one?
  17. Feb 25, 2017 at 8:18 AM
    #57
    Hiluxski
    Ventura California
    Can somebody help me try to find the correct wire on my utility SR. I'm trying to locate the correct wire to help identify if the truck is prewired.
  18. Feb 25, 2017 at 10:25 AM
    #58
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Refer to post #27
    Hiluxski[QUOTED] likes this.
  19. Feb 25, 2017 at 11:52 AM
    #59
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Post #30 may help you out as well.
  20. Feb 27, 2017 at 8:50 AM
    #60
    fdb03taco
    Danny
    SOMD!
    I've got a line on some OEM take off fogs and bezels locally. If I can get my hands on those I'll move forward with sourcing a switch and harness.
    I am going to check, but the reports in this thread make me confident my truck is pre-wired. It's a 2017 DCSB V6 with convenience package. Before I move forward with getting a switch I will check to make sure the truck is pre wired. If for some reason it isn't I can always follow plan A in this thread!
