Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Feb 2, 2023 at 9:16 PM
    #781
    Chizzle
    Chizzle Member
    '23 SR5 Trail Edition
    daveeasa says he doesn't make these...
  2. Feb 2, 2023 at 9:20 PM
    #782
    caribe makaira
    Caribbean, Puerto Rico
    I think one has moved on to flat pasture and the other is way behind in stocking the barn...
    You could do without the plug and play by using posi-taps and mini zip ties to the required wires.
    Chizzle[QUOTED] likes this.
  3. Feb 2, 2023 at 9:28 PM
    #783
    Chizzle
    Chizzle Member
    Well, it might help if I dont mix up the damn numbers and letters. But maybe he has moved on from making them...I sent the correct information and picture, worth 1 more attempt lol.
  4. Feb 2, 2023 at 9:37 PM
    #784
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Kyle had a bunch of cargo T switch illumination harnesses made. I’m not sure where they might be sold. I checked caliraised and didn’t see it.
  5. Feb 2, 2023 at 9:39 PM
    #785
    Chizzle
    Chizzle Member
  6. Feb 2, 2023 at 9:41 PM
    #786
    caribe makaira
  7. Feb 2, 2023 at 9:41 PM
    #787
    daveeasa
    David
    PNW
    I’ve only done 2 or 3 cargo T’s.
    DSIM makes a cargo rock light harness but it’s not cheap.
    I would like to do fog lights off the stalk in my ‘05. I’m way behind on my own truck mods. Hence I’m trying hard to avoid new one off efforts.
    Chizzle likes this.
  8. Feb 2, 2023 at 9:42 PM
    #788
    caribe makaira
    Pruis light stalk works/fits. Or 2000 Tundra
  9. Feb 2, 2023 at 9:44 PM
    #789
    daveeasa
    David
    PNW
  10. Feb 2, 2023 at 9:45 PM
    #790
    Chizzle
    Chizzle Member
  11. Feb 2, 2023 at 9:47 PM
    #791
    daveeasa
    David
    PNW
    I need to do my Tundra as well.
  12. Feb 2, 2023 at 9:47 PM
    #792
    Chizzle
    Chizzle Member
    Is that both or just the "D35"?
  13. Feb 2, 2023 at 9:48 PM
    #793
    caribe makaira
    Without the ground wire...but a butt crimp & a positap will complete it. Or Dave could sell ya a dual crimp wire with 090 terminals. YOu's have to de-pin the connectors to add that dual wire.
  14. Feb 2, 2023 at 9:52 PM
    #794
    caribe makaira
    Just the D35 ($29.99)...daisy is extra (for more added switches)
  15. Feb 2, 2023 at 10:44 PM
    #795
    Chizzle
    Chizzle Member
    Did I find it?
  16. Feb 2, 2023 at 10:48 PM
    #796
    caribe makaira
    Yes
  17. Feb 7, 2023 at 3:07 PM
    #797
    Chizzle
    Chizzle Member
    Now, just need someone to make a C11 intercept/T Harness and this can be a plug and play upgrade for pre-wired rigs.
  18. Feb 24, 2023 at 4:32 PM
    #798
    Kevin45036
    Kevin45036 Member
    2023 Tacoma SR
    I used the Cali Raised LED switch and the illumination harness. Was able to get my pin in spot 26, and found a good ground right above the control module, it is a nut you take off from the tube frame for the dash. Big chunk of steel.
    not behaving as I expected. Maybe you guys could tell me what your taco did.
    I have an SR “prewired “.
    It seems like the computer thinks the fog light should always be on when the headlights are on.
    they turn off when the brights are on or I turn DRL on.
    This seems independent of the fog light switch position. It’s dark and cold now, so I haven’t troubleshot yet. Tomorrow , I’m gonna see what happens when I disconnect the switch and just have the harness inserted. And maybe throw an ohmmeter on the switch pins.
    The way I envision this working is…
    Fog lights off when switch is not engaged, and only on when the switch is engaged.
    What did your SR do?
  19. Feb 24, 2023 at 4:41 PM
    #799
    caribe makaira
    Fogs only come on after TAILS/Parking lights are selected. They also turn OFF when high beams are selected.
    09 Redneck likes this.
  20. Feb 24, 2023 at 7:09 PM
    #800
    Chizzle
    Chizzle Member
    This is normal for fog light equipped vehicle too isnt it?
