Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Jul 18, 2024 at 6:51 PM
    #921
    LeadFarmer3000
    LeadFarmer3000 Member
    alex
    Tacoma 2019 4cyl
    Yotaworks tune
    I just did this mod on my 2019. my truck was not pre-wired. everything is set up when I hit the fog light button I can hear the relay go off and can see the fog light indicator on the dash go off. but the fog lights don't go off. Has anyone run into this or am I overlooking anything?
  2. Jul 18, 2024 at 9:13 PM
    #922
    mathew206
    mathew206 Active Member
    2023 SR Access Cab
    Try switching the polarity on the fog light plug.
  3. Jul 19, 2024 at 4:09 PM
    #923
    LeadFarmer3000
    alex
    Tacoma 2019 4cyl
    Yotaworks tune
    So the polarity was reversed, but im only getting 3.5v to the lights so they are still not working
  4. Jul 19, 2024 at 4:20 PM
    #924
    mathew206
    2023 SR Access Cab
    What switch do you have?
  5. Jul 19, 2024 at 4:46 PM
    #925
    caribe makaira
    Caribbean, Puerto Rico
    Seems you might have the wrong feed to the lamps from the relay...
  6. Jul 19, 2024 at 5:09 PM
    #926
    LeadFarmer3000
    alex
    Tacoma 2019 4cyl
    Yotaworks tune
    I got the suggested OEM one from Toyota
  7. Jul 20, 2024 at 7:13 AM
    #927
    mathew206
    2023 SR Access Cab
    I'm also leaning towards it's your switch wiring.
  8. Jul 20, 2024 at 9:23 AM
    #928
    LeadFarmer3000
    alex
    Tacoma 2019 4cyl
    Yotaworks tune
    Do you think I got the wires reversed?
  9. Jul 20, 2024 at 6:02 PM
    #929
    LeadFarmer3000
    alex
    Tacoma 2019 4cyl
    Yotaworks tune
    Got It running, i rewired everything. and it started to worked, I'm getting over 13v to the lights now.
    Ellefty and mathew206 like this.
  10. Jul 21, 2024 at 2:09 PM
    #930
    Jcforbes3
    Jcforbes3 New Member
    James
    2021 SR Tacoma
    Hello, I'm new here. I've read the thread pretty thoroughly but could still use some help. I have a 2021 SR that is pre-wired. My cargo lights are in use and I would like to keep it that way. Has anyone created/updated Nitori's original post to show how to do the wiring for a dash switch when cargo lights are in use? I'm slightly dyslexic, so pictures help me a lot!
  11. Jul 21, 2024 at 2:14 PM
    #931
    caribe makaira
    Cargo lights are a separate circuit, nothing to do with fogs.
  12. Jul 21, 2024 at 2:20 PM
    #932
    Jcforbes3
    James
    2021 SR Tacoma
    Ok caribe, can you help me out here? What do I need to do if the deck lighting plug is in use?
  13. Jul 21, 2024 at 3:12 PM
    #933
    caribe makaira
    Nothing.
    The plug for the deck lighting is the same for the Cargo Lamp.
    Not related to fogs.
    Are you having an issue with adding a switch and no space for it?
  14. Jul 21, 2024 at 5:00 PM
    #934
    mathew206
    2023 SR Access Cab
    @Jcforbes3 I think yoy are referring to stealing illumination? If so just tap the wires from the cargo switch. Or buy a harness that you can plug and play. I think tacomalifestyle sells them.
  15. Jul 30, 2024 at 5:45 AM
    #935
    EatingTacosinmyTaco22
    EatingTacosinmyTaco22 Active Member
    2022 White SR 4x4
    Done and done. I can’t believe how I put this off for two years. It was pretty easy, granted my SR was pre-wired.
  16. Aug 1, 2024 at 2:04 PM
    #936
    jrzjoe
    jrzjoe Well-Known Member
    Joe
    2013 trd sport 2023 trail edition
    1.75 in bilstien 5100 lift on the 2013 2023 TE OTT tune
    IMG_5592.jpgLooks like I’m prewired on my 2023 TE. Just bought a bunch of the stuff from the stealership minus the actual lights (going aftermarket) but forgot to get the self tapping screws. Anyone know the size I may need? I’m already in the hole for $514 and the DD fogs I’m getting are around $375 they were Kindof pricks and don’t want to go back if I don’t have to.
  17. Aug 2, 2024 at 10:02 AM
    #937
    mathew206
    2023 SR Access Cab
    I used some random screws I had lying around. Just made sure they were thick enough to fit well into the space the give. I haven't had any problems.
    Interesting on your cost though. I did almost everything OEM, fog light harness, fog light covers, etc. I did go aftermarket button switch (no stalk coz not prewired), and I also went DD for the foglights (but I went elites since I wanted a more OEM look, and i love the backlighting). Including fog lights, I spent $400.... granted my fog lights are almost half of the DD3s (assuming this is what you bought), and your stalk probably adds $100? but still.
    jrzjoe[QUOTED] likes this.
  18. Aug 2, 2024 at 12:57 PM
    #938
    jrzjoe
    Joe
    The stalk was $203 and the harness was over $100 $30 for each bezel. And $30 for the relay. I looked up everything and the dealer was about double the price for everything except the stalk. Obviously I have sucker written on me. What a chump. I’ll order the DD SS3 pros next month.
    Thanks for the replay.
  19. Aug 2, 2024 at 1:12 PM
    #939
    alphaomega420
    alphaomega420 Well-Known Member
    2019 SR SX V6 RWD
    If you can return your parts, I got my stalk (including an intermittent wiper switch) for $100+shipping on eBay. Mine is from a 2016 Corolla which bolts up exactly the same. I think I was all in with lights for under $350 but I bought almost all my parts used other than the harness.
  20. Aug 2, 2024 at 1:22 PM
    #940
    jrzjoe
    Joe
    No returns on electrical items or special orders. I’ll survive. Lesson learned…..again
    I’m not one to bash dealerships too much but this one I’ve had issues with all the way back to my wife’s 05 highlander.
