Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Jun 22, 2017 at 3:18 PM
    #101
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Zero issues returning it. They couldn't figure out a part number, and wanted to order me a 0R010 stalk based on their information. I had to show the guy this thread for an answer, ha.
    davidstacoma likes this.
  2. Jun 23, 2017 at 8:41 PM
    #102
    t.i.
    t.i. Active Member
    Did you install it yet?
  3. Jul 14, 2017 at 9:32 PM
    #103
    trzpiola
    trzpiola Member
    2017 tacoma
    none
    what is the part number for the wire harness that goes up to the steering wheel with an extra blue and white wire, where to connect them on the other side , still trying to get some info about non prewired sr and make it work with the factory stalk instead dsh switch
  4. Jul 14, 2017 at 9:42 PM
    #104
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Ah jeez dude, I can try to find you the part number, but you aren't gonna like the answer.
    It's an integral part of the dash harness. You gotta replace the WHOLE HARNESS for those 2 wires. That means strip your center console out, strip the entire dash out, and replace.
    You're also looking at $2,000+ for that full wiring harness.
    My advice: learn to love the button.;)
  5. Jul 15, 2017 at 6:50 AM
    #105
    trzpiola
    trzpiola Member
    2017 tacoma
    none
    I will , thank you for that, you answered all my questions, i was thinking Thats easy like the wiper mod and i will add 2 extra wires but now i will love that button
    Thank you
    magicgus323 likes this.
  6. Jul 15, 2017 at 8:19 AM
    #106
    jeffkimkp
    jeffkimkp Well-Known Member
    2017 silver tacoma sr
    none
    Wow thanks for the write up.... but wow i will have to do a u-turn on wanting to add fog lights now..... sigh.. is adding led rigid lights going to be just as difficult?
    t.i. likes this.
  7. Jul 15, 2017 at 10:17 AM
    #107
    t.i.
    t.i. Active Member
    I don't think it's difficult at all. Nitori did the hard work trying to figure what goes where, now it's just matter of following his directions.
    I installed ridgids on my SR using his guide, only thing I had to take it to the dealer was installing the stalk. I didn't want to mess around with airbag
  8. Jul 15, 2017 at 10:21 AM
    #108
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I finally got around to this today, it was a breeze. I was going to snap pictures of the steering wheel removal, but this video VERY similar
    https://www.youtube.com/watch?v=jllh2VjM4H8
    There are a few more connectors for our truck relative to that Hilux in the example , so just be sure anything coming from the clock spring is disconnected from the steering wheel. Otherwise, pulling the wheel off with one of those connectors still in place could potentially ruin the clockspring.
    The clockspring has three plastic tabs holding it to the stalk assembly. One at the top, and the other two are about 120 degrees apart. They are very easy to see.
    The stalk assembly took me a few minutes to figure out ... just lift on these three tabs in the picture below and it'll come right off.
    Few more pictures.
    My install was slightly different, as I put in Baja Designs Squadron R Sports. For completion sake, here is the thread for that ..
    https://www.tacomaworld.com/threads/baja-designs-squadron-r-sport-fog-light-install.492391/
    Thanks @Nitori ! I would have never done this myself without folks like you on here.
  9. Jul 15, 2017 at 3:57 PM
    #109
    trzpiola
    trzpiola Member
    2017 tacoma
    none
    another question about factory stalk, do you guys have a picture of pinouts - talking about 0R020 - assuming thats the one with the fogs and no auto, have 2 extra pins for white and blue ? quessing thats the 0R010 stalk is with auto and fogs and 3rd pin, also if its a matter of connecting pin 26 (blue wire) with the ground to fire the fogs. do i get same result running that wire from ecu up to the steering wheel and install it in stalk connector instead of dash switch and the white wirec just tp the ground ? anyone can confirm that ?
    also if yes - how to find terminal fix part number that goes to turn signal switch
  10. Jul 30, 2017 at 8:10 PM
    #110
    jmonz444
    jmonz444 Well-Known Member
    Joe
    Wisconsin
    2017 MGM DCSB
    Predator tube steps Painted steel wheels Debadged Plasti dipped grille emblem Bright white headlight bulbs Removed front air dam SR fog light mod Yellow fog lights North Mountain Tonneau Weather tech floor mats AVS in channel visors OEM roof rack Malone Downloader kayak rack Morimoto HID headlight kit
    Anyone know if this wiring harness I found on eBay would work?
  11. Aug 8, 2017 at 10:53 PM
    #111
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Wow, what a great write up. Rather than replacing the entire harness to have the new stalk switch work with non-pre wire, would it be possible to just replace the plug with one that has the additional ports and add the two wires outside the existing harness wraps? It would mean pulling the wires from the existing plug and swapping them to the new plug(can this even be done?)then adding the extra wires. You'd have to source the plug somehow as well. I'm probably missing any number of things.
  12. Oct 27, 2017 at 4:52 PM
    #112
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
  13. Oct 30, 2017 at 7:51 AM
    #113
    tuanhuy0301
    tuanhuy0301 Well-Known Member
    2017 Tacoma SR DCSB 2.7l 4X2
    anyone know how to connect to this switch?
  14. Nov 5, 2017 at 5:44 AM
    #114
    j2k
    j2k Well-Known Member
    My SR is prewired. But I tapped pin 26 wire found out pin 26 is always hot - I measured it to about 7 volt. If I ground it according to the instruction, will it short circuit anything?
  15. Nov 5, 2017 at 7:32 AM
    #115
    Nitori
    Maricopa AZ
    2021 T4R SR5
    OK so it's basically the same exact style of switch, they are just assuming you are switching a positive load as opposed to going ground switched.
    Let's get this bad boy back out:
    On your Diagram, pin 3 (RED 2) would hook to Green Wire, Pin 4 (BLACK) would hook to Beige Wire
    Pin 1 (GREEN) would hook to Pin 26 Body ECU, and Pin 2 (RED 1) would hook to appropriate ground.
    No. Pin 26 is controlled by the body ECU- if you click that switch in it is simply telling the body ECU "Turn the fog lights on when appropriate" and the body ECU will do so. This is how pressing your fog light switch does not turn the fogs on when your headlights are off, and also how the body ECU clicks the fogs off when you hit your high beams.
    This method is controlling pin 26 exactly as it is controlled on a truck that came with the fogs from the factory.
  16. Nov 5, 2017 at 10:09 AM
    #116
    j2k
    You are correct - My fog lights are working now and nothing got shorted.
    Your explanation is very appreciated. Thank you.
  17. Nov 5, 2017 at 2:15 PM
    #117
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Logic highs or buffered/high impedance inputs are + voltages all the time.
    Meaning they are not direct 12 volts.
    Do exactly what nitori says.
    Get the factory harness ($50), plug in the relay ($12), and ground the wire to a switch ($5) or get the stalk. That simple. 45 minute job.
    Fogs better than factory at a lower cost.
  18. Nov 9, 2017 at 2:14 PM
    #118
    j2k
    Here is something I'd like to share. I found the factory harness a bit pricey and I had some leftover wiring sitting around, so I rigged my own harness for less than 10.00.
    These are the parts you need:
    2 x H11 H8 Headlight/Fog Light Female Adapter for 1.99
    1 x Side Marker Light Pigtail Connector Fits Toyota Tacoma for 7.59
    The H11 connects to the fog light, and the side marker pigtail connects to the engine room harness.
  19. Nov 18, 2017 at 11:27 AM
    #119
    zumos1
    zumos1 Member
    Richard
    2017 White Tacoma SR
    Nitori, Nice write up easy to follow. However once complete, with headlights on, push switch, bummer fogs do not turn on. Pulled fogs and wire to 12 v and they light. If I ground ECU pin 26 no lights with headlights on, tried another relay as well. Any thoughts? 2017 Tacoma SR not prewired.
  20. Nov 18, 2017 at 12:40 PM
    #120
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Is your dash lighting up with the little "fog lights" icon when you ground pin 26 w/headlights on?
    That little guy should light up green (as well as the other "bulb" indicator underneath and to the left to indicate that your lights are on)
    If you DO NOT see that indicator, double check to make sure you are grounding the right pin, and that your ground is a good ground. The Body ECU is somehow not getting the ground signal.
    If you DO see the light, your problem is somewhere after the body ECU. Since you checked the relay already, check to make sure that Toyota hasn't gotten wise to giving us a free fog light fuse ( :laughing: ) and that it hasn't been accidentally blown if it is there.
    Tlaloc1916 likes this.
