Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Nov 18, 2017 at 9:59 PM
    #121
    zumos1
    zumos1 Member
    Richard
    2017 White Tacoma SR
    Don't recall seeing indicator light up. Grounding to bolt next to air bag under steering column. I'll double check the pin location and replace the wire.
  2. Nov 25, 2017 at 11:48 AM
    #122
    lbrewer
    lbrewer Member
    El Paso, TX
    2017 Tacoma SR 4x4 4 banger
    Anyone know where to find a tutorial on removing the wires from the deck lighting plug? I popped up the white “E” retainer, but can seem to push the wires out. I am guessing I need to push the end of the wire clip up or down. Any advice is appreciated.
  3. Nov 25, 2017 at 11:54 AM
    #123
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Push something small and thin (but solid) down this part of the slot, and then you can pull the wire out from the back.
    Think of it like a phone or internet cable with one of those little tabs you press down on to pull it out. That's what you are sticking a tool down the slot to release.
  4. Nov 25, 2017 at 12:20 PM
    #124
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Great instructions! I'll be digging in to this mod as soon as I can get all the necessaries together. Thank you Nitori for doing the ground work for us and for doing it so well!
  5. Nov 25, 2017 at 12:53 PM
    #125
    lbrewer
    lbrewer Member
    El Paso, TX
    Found a pick that took them right out! Thanks
  6. Nov 26, 2017 at 7:46 PM
    #126
    zumos1
    zumos1 Member
    Richard
    Found the issue. The wire in pin 26 didn't click and pushed out and didn't make contact. Once that was rectified all is good. indicator works.
    My fogs come on when parking lights are on , headlights do not have to be on. Does not come on when DRL is on, however with then coming on with parking or headlights works for me.
    Thanks again for the write up.
  7. Dec 9, 2017 at 5:43 PM
    #127
    Guitargeak99
    Guitargeak99 Well-Known Member
    Oakdale, Ca.
    2017 Silver Tacoma SR 2wd 4-cyl AT
    SUCCESS!!!!!!
    I am so stoked about this. I can build a screaming Big Block Chevy motor, but my wiring ability stops at installing batteries in a flashlight.
    Much thanks to Nitori for such a comprehensive write-up, for all my PM’s to him, and his patience in his replies.
    Great guy.
    I like this set up because it is wired like OEM. I tried to keep it on a budget, so I didn’t go the “stalk switch” method on the steering column. My SR was pre-wired though.
    I was able to purchase the fog lights and wiring harness used from a forum member- he had taken them off his 2017 Taco in order to go the LED route (huge score). Then I purchased the remaining parts as outline in this thread, from gunni1005/Gary @ Camelback.
    Also, a big thanks to Moe2o4 for his fog light write up, as there were pics in his thread that were used here.
  8. Jan 30, 2018 at 1:04 AM
    #128
    aaronarakaki
    aaronarakaki Well-Known Member
    2020 off-road 4x4
    Let's revive this thread because I need help. I am going to look this weekend before I purchase, but would a corolla turn stalk with a fog light switch work if I am pre-wired?
    I am going to do the intermittent wiper mod at the same time so I found one with both and figured I would ask before I purchase
    NightHawkTaco420 likes this.
  9. Jan 30, 2018 at 9:15 AM
    #129
    Nitori
    Maricopa AZ
    2021 T4R SR5
    It looks like it should work based on what the parts catalog I use shows. That said, as far as I know you are gonna be breaking new ground with a full corolla swap.
  10. Jan 30, 2018 at 4:29 PM
    #130
    aaronarakaki
    2020 off-road 4x4
    I just figured since the wiper stalk was the same it should work, but then again I was scared it wouldn't which is why I asked
  11. Jan 31, 2018 at 6:00 AM
    #131
    aaronarakaki
    2020 off-road 4x4
    This is the part number on the corolla turn stalk
  12. Jan 31, 2018 at 8:59 AM
    #132
    aaronarakaki
    2020 off-road 4x4
    Also just checked and I am pre-wired for fogs to the switch
  13. Jan 31, 2018 at 10:59 AM
    #133
    Nitori
    Maricopa AZ
    2021 T4R SR5
    You should be good to go then. Not being able to actually test the parts out I cannot guarantee you, but every indication so far has been yes, this will work.
  14. Jan 31, 2018 at 11:03 AM
    #134
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    I’ve got a set of fogs and the bezel fo free if you’re in Dallas.
  15. Jan 31, 2018 at 11:39 AM
    #135
    Forge
    Forge Well-Known Member
    Rick
    I have a 17 SR with convenience package...foresee this mod some time in the future. I like the button method better than the stick. Reminds me of my old 02 Ranger. Wish one of you guys were in VA that have successfully done this. I suck at wiring. great write up @Nitori
  16. Jan 31, 2018 at 3:16 PM
    #136
    aaronarakaki
    2020 off-road 4x4
    I ordered everything will see next week once it all comes in
  17. Feb 3, 2018 at 9:40 AM
    #137
    aaronarakaki
    2020 off-road 4x4
    Got everything early so tomorrow I'm gonna put it all in
    Tlaloc1916 and Nitori[OP] like this.
  18. Feb 4, 2018 at 11:43 AM
    #138
    aaronarakaki
    2020 off-road 4x4
    Anyone wanting to do this the 14 corolla stalk with fogs and intermittent wiper fit perfectly in my 16 Sr tacoma. I was wanting the intermittent switch anyways so when I got the fogs why not all at once with the same stalk.
    Wipers work exactly they way they should. Fogs come on with parking lights, indicator on dash comes on.
    Yea I know my Tacoma isn't squeaky clean, but I actually don't care because it's mine not yours :p
    Top is OEM sr tacoma
    Bottom is OEM 14 corolla
    Top is OEM corolla
    Bottom is OEM sr tacoma
    Cole man, Farcedude and Nitori[OP] like this.
  19. Feb 4, 2018 at 6:54 PM
    #139
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Do you have part numbers for the side marker light pigtail connector, or where did you get that part from?
    Edit: nevermind I found them, Toyota part number 90980-11156, Dorman part number 645-673
    skierd likes this.
  20. Feb 15, 2018 at 8:55 PM
    #140
    Joshjones6357
    Joshjones6357 Member
    2017 White Toyota Tacoma
    Do you have the part number for the corolla stalk?
