Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Apr 29, 2018 at 11:44 PM
    #161
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Is it actually necessary to remove the steering wheel? On the SR intermittent wiper mod thread, the wiper stick is modular and can be snapped in and out of the main steering column ring.
  2. Jun 2, 2018 at 11:50 AM
    #162
    Grasswally
    Grasswally Member
    Tempe, AZ
    2017 4x4 DCSB
    I just installed fog lights on my 2017 SR v6 3.5L 4x4. I was prewired. I bought a used turn signal shaft on eBay ($80), an electrical wire harness to the fog lights on eBay ($63), the Relay fuse from Amazon ($18), and some factory lights and surroundings off this website from somebody that upgraded theirs ($53). $214 total and it looks factory/stock. It took me and a buddy about 3 hours taking our time.
    After everything is put back together I realized my wheel is about 1 click to the left of center when driving straight. :( I think I’ll buy a new wiper shaft before I take everything apart to fix the wheel.
    NightHawkTaco420 and mdcoma like this.
  3. Jul 27, 2018 at 2:23 PM
    #163
    Guitargeak99
    Guitargeak99 Well-Known Member
    Oakdale, Ca.
    2017 Silver Tacoma SR 2wd 4-cyl AT
    Does anyone know where I can get the larger “ice blue” fog light switch (like RocTaco’s pictured in post #158)?
    I’ve already installed my fogs (see post #127), but I want to move the switch to the center location.
    Thanks in advance.
    Existing:
    Proposed center location:
  4. Jul 28, 2018 at 9:29 PM
    #164
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Have you tried Amazon or ch4x4? Search toyota small push switch.
  5. Jul 29, 2018 at 7:05 AM
    #165
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    They must've changed some stuff around, I'm pretty sure this is the switch I have:
    https://www.aironboard.com/online/p...t-toyota-oem-replacement-fog-lights-blue.html
    It's cheaper than when I bought it too.
  6. Jul 29, 2018 at 10:17 AM
    #166
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you can solder, the leds are easy to change as is the brightness level.
  7. Aug 1, 2018 at 6:54 PM
    #167
    Guitargeak99
    Oakdale, Ca.
    Thanks Roc & Bagelboy,
    I found one on Amazon. Supposedly it has 2 internal LED’s - one that lights when fog lights are on, and the other is on whenever the lights are on. It came with a 4-wire pigtail, but the switch itself has 5 terminals.
    My existing switch is 4-wired OEM according to Nitori’s instructions.
    I’ll just need to figure out how to mate up the 4 wires to the new switch.
  8. Aug 3, 2018 at 12:35 AM
    #168
    bagleboy
    Scott
    Norcal, Santa Rosa
    The center terminal is unused on all of these switches. Its soldered to the switch pcb but no traces are connected to it.
    A9F6301E-558D-4360-8BC5-8AA49C05AB59_zps_158c4444374ab2beb3e9994322ea5ce6c4de2b72.jpg
    09F55BAF-0DE3-4F42-8AA0-CE9FC881C66C_zps_9485334003966c7efab8170662188abe72dc2b46.jpg
    Look closely at the connector and you'll see none of the 4 wires go to that pin either.
    Guitargeak99[QUOTED] likes this.
  9. Aug 3, 2018 at 7:11 AM
    #169
    Guitargeak99
    Oakdale, Ca.
    Ok, that definitely helps.
    Thanks
  10. Aug 3, 2018 at 9:36 AM
    #170
    bagleboy
    Scott
    Norcal, Santa Rosa
    Sure, no problem. The way these are set up one led is connected to the switch output and comes on with the switch and the other has a dedicated pin to feed it power but both share the same ground because toyota dims the lights on the ground side. If you want them to dim with the dash you need to connect black to the dash dimmer ground. If not, simply connect black to chassis ground but they'll be very bright and not dimable. You can also connect red 2 to the switch output to have both leds come on with the switch.
    The wire colors vary from seller to seller but on your switch these should be the wires:
    Green- connect to 12v supply
    Red 1(next to green) -switch output
    Red 2 (next to black) - connect to 12V supply(switched or not)
    Black - connect to either chassis ground or dash dimmer ground
    It took me awhile to get this straight but it helped when I got a peak inside(a delivery dude tossed the packet in the driveway and it got munched when the gf backed over it) the pcb survived but the button and case did not. Otherwise I'd probably still be in the dark too. Lemons>lemonade.
  11. Aug 3, 2018 at 9:40 AM
    #171
    bagleboy
    Scott
    Norcal, Santa Rosa
    One more thing, if you only connect green and red1 the switch will work just fine but neither led will light up. Ground is for the leds only and has nothing else to do with switch function.
    Guitargeak99 likes this.
  12. Aug 4, 2018 at 2:49 PM
    #172
    Guitargeak99
    Oakdale, Ca.
    Ok, I got it wired up.
    And Bagelboy, you’re right about TOYOTA wiring the dimmer the way it does.
    I couldn’t make this switch work utilizing both of the internal LED’s, because of how I originally wired up my fogs - OEM thru the ECU.
    Otherwise, your way would have worked for me.
    After a few PM’s with Nitori I have it figured out. I either had to have the fog light switch illuminate when ever my parking lights /headlights are on, or illuminate only when the fog lights themselves are on.
    I chose the latter, and I’m happy with the outcome.
    I did not have to disassemble anything on the center console - I was able to pry off the cover to the un-used slot and fish a wire thru, which I used to pull the 4 wires to the new switch.
    I did not remove the existing fog light 4-prong plug. I just tapped off those wires.
    Thanks guys.
  13. Aug 4, 2018 at 4:16 PM
    #173
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yup, the dimmer circuit is only activated through the parking/headlights. One led has a dedicated power lead but to have dimming you have to have the lights on. Since that's the stock arrangement, that's how mine's set up.
  14. Sep 25, 2018 at 5:34 PM
    #174
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    What fog lamp kits are people using for this install curious about quality pictures and links are helpful
    Thanks
  15. Oct 10, 2018 at 6:14 AM
    #175
    Guitargeak99
    Oakdale, Ca.
    I don’t know what others are using, but I was able to find a used set that included the wiring harness, from a member here. Which I think is the way to go. I was planning on purchasing the harness new, but it was included in box when I received the fog lights. All plug and play.
    Fishingeek603[QUOTED] likes this.
  16. Oct 10, 2018 at 8:24 AM
    #176
    Fishingeek603
    New Hamphire
    thanks for the reply, i havent gotten around to seeing if im prewired or not im fairly confident i am. i also figured out the sr and sr5 bezels are different from all the higher models
    edit: any pics? im curious how it came out
  17. Oct 10, 2018 at 8:27 AM
    #177
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Any of you SR boys in DFW can have the fog lights and bezels off my TRD off-road if you come get them
    jcast0311 likes this.
  18. Nov 11, 2018 at 9:48 AM
    #178
    mdcoma
    mdcoma Member
    2018 Metallic Gray SR V6 4x4
    Thanks for the write up. I did mine in about 1.5 hours.
    Guitargeak99 and Nitori[OP] like this.
  19. Nov 24, 2018 at 5:37 AM
    #179
    bagleboy
    Scott
    Norcal, Santa Rosa
    The illumination is separately wired from the switch which is why it has 4 wires, switch power in, out, illumination power and ground, though the switch " on " indicator gets power from the same source as the switch it still needs a ground wire to come on. Choice of illumination power source and ground(both illumination and switch "on" leds share a common ground) determine when the switch is illuminated when "off" and whether dimming is used. The switch would still work even if the 2 illumination wires weren't connected but in that case I'd seal the unused ground wire as the end becomes hot whenever the switch is on.
  20. Dec 7, 2018 at 2:33 PM
    #180
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    Just did it. The airbag is a white knuckle experience, but not bad after. I let the truck sit without power for an hour. It was way easier than I thought. Disconnecting the round thing from the blinker harness was a look and learn thing. There are three clips that I didn't know about, but if you stare at it, you will see them.
    I ordered the harness for the fog lights and the relay. I have an 2017 SR with convince and it was prewired. I didn't take pics as this thread said almost everything needed.
    Thanks Nitori !!!!
