Nitro 4.56 gears today WOW!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Nov 11, 2011.
  1. Nov 11, 2011 at 3:34 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Had the shop intall 4.56 gears today in my 2.7 4x4. Huge expense but worth every penny. What a tremendous difference- all my power back plus some. Purchased a complete front differential and a rear differential kit from East Coast Gears - $1040.00 shipped. Shop gave me a break because they know me and charged me $625.00 for install. I had them put Lucas 80/140 in (18.50/quart) (this is what ECG wants you to use). Props to Chase and all the folk at East Coast Gears
  2. Nov 11, 2011 at 4:01 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    congrats, i need to do this, as i can only really get on it in 4x4 low, running 285 km2's on 17's and i need my power back. what major difference besides power are you getting, re: running in 5th gear on highway> what rpms are you at highway speeds or in 4th gear/5th gear.
  3. Nov 11, 2011 at 4:26 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I was running about 2500@70mph ,2700@75mph and about 2900@80mph these are all in 5th gear. I hit some hills that I would normally have had to downshift to 4th but didnt need to anymore. I suspect my mpg will go back up as well.
  4. Nov 11, 2011 at 4:28 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Nice! This will be my next mod, Gears and lockers.
  5. Nov 11, 2011 at 4:32 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Lockers are definately nice. I went with the Detroit TruTrac (mech limited slip) in the rear.
  6. Nov 29, 2011 at 7:52 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    any update on mpg's?
  7. Nov 29, 2011 at 8:15 PM
    907taco
    Bobby
    Alaska
    yes updates, how about your speedo, is it accurate to true mph on odometer
  8. Dec 1, 2011 at 1:25 PM
    JLink
    Josh
    Ocean, NJ
    The "Big Nig"
  9. Dec 1, 2011 at 2:27 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Dont think there will be good mileage here.
    80/140 dino oil ? In Upstate NY ? Thats like filling diff with grease in the winter.:D
  10. Dec 1, 2011 at 2:29 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Congrats on the re-gear!
    In regard to the bold: for the front and rear already assembled, they still charged $625?
    Also why did you not go with the 75-90 Toyota recommended weight?
  11. Dec 1, 2011 at 2:31 PM
    08pretaco
    Oliver
    az
    Need to take into consideration when you calculate your MPG that NOW you are OPPOSITE of what it was before. You will be putting MORE miles on the odometer rather than previously with the larger tires and factory gearing.
  12. Dec 1, 2011 at 3:54 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    re gearing changes your speedo??????
  13. Dec 1, 2011 at 3:57 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Only the front diff was complete from ECG's and only had to be installed the rear had to be built by the shop so Im thinking they gave me a great price for labor. As far as the oil weight, ECG's gives a five year warranty on the diffs although they recommend that you use Lucas 85-140. They are the professionals and they claim this is what works the best for front/rear diffs and transfer case. They also say to stay away from synthetic for two reasons 1) does not cushion like dino does and 2) although the oil temp is cooler with synth the metal gears are actually higher temp then with dyno.
  14. Dec 1, 2011 at 3:58 PM
    08pretaco
    Oliver
    az
    yes because the speed sensor is in the back on the transmission. with gear changes the rpm's are altered which means that the driveshaft spins more/less than what was from factory.
  15. Dec 1, 2011 at 3:59 PM
    08pretaco
    Oliver
    az
    Thats interesting! I guess everyone has their favorite brand/weight. I personally use redline 75-90 with my gears and ARB in the diff.
  16. Dec 1, 2011 at 4:00 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Actually my gas milage went back up to 20mpg (true reading taking into consideration odo being off due to re-gear) from 17.5mpg before re-gear (was getting 20mpg before I put 265 75 16's on KM2's). Gears front and rear are like butter-no issues
  17. Dec 1, 2011 at 4:01 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I have always used mobil 1 synthetic so this was a big change for me. By the way the Lucas is just as expensive as synthetic
  18. Dec 1, 2011 at 4:01 PM
    08pretaco
    Oliver
    az
    what conversion factor are you using when you say true reading? explain the math please :)
  19. Dec 1, 2011 at 4:03 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Yes re-gear will change the speedo and odo
    speedometer registers 82mph Im really going 75mph
    when ODO registers 100 miles I really have driven 95 miles
  20. Dec 1, 2011 at 4:05 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I have a gps that actually gives you a accurate speed and milage so I just documented what my speedo and odo registered at several speeds and compared it to the gps
