Nitro Front Diff LSD
Discussion in 'Technical Chat' started by TireFire, Jan 29, 2021.
  1. Feb 24, 2021 at 3:44 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    TireFire[OP] and TodayWasTHeDaY like this.
  2. May 10, 2021 at 10:49 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
  3. May 11, 2021 at 3:48 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yes. It went in well. Made minor adjustments to the carrier shims to dial in backlash and tighten the preload. It was on an AWD v8 T4R, so as soon as we took off, you could feel it, super grabby. Then we went to test it out on some hill climbs, worked flawlessly.
    https://www.instagram.com/p/CNxJi9YHepb/?igshid=pkhtya4by2o7
  4. May 25, 2022 at 11:55 AM
    TireFire
    TireFire [OP] Superunknown Member
    Olympic Peninsula
    Have you done any more? Maybe on a part time 4WD setup like stock Tacos? No doubt this is great off-road or in snow but wondering how it affects steering feel and turn radius?
  5. May 25, 2022 at 2:06 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Haven't done any on selectable 4wd. I imagine it would work well in a low traction situation, but regular street driving in 4hi it would bind the front end more than open diff.
  6. May 25, 2022 at 2:52 PM
    TireFire
    Olympic Peninsula
    I was talking about 2hi. No way that this diff would bind up the front in 4hi before the transfer case would
  7. May 25, 2022 at 5:36 PM
    My White Tacoma
    My White Tacoma Well-Known Member
    Andrew
    Springfield, mo
    2014 White Tacoma double cab, SR5, 4x4
    I installed a Torsen up front and a TruTrac in the rear of my 2nd gen Taco with 4.56 gears. Have had it in for a little over year and a half. Does really well in snow, mud, and yes, even rock crawling. If you do hardcore rock crawling of course a locker is the better choice. But with these LSDs in 4lo and the brakes applied, it will spine all 4 wheels and pull you out, even if you only have two wheels touching the ground! I have been behind rigs on the trails more then once and they had to use their lockers, my LSDs pulled me right on through with a little use of the brakes. Pretty cool!
    With a ADD systems in 2wd, the differential is disengaged outside of the differential housing, so even with a locked/LSD installed it is still open. However like pointed out earlier, since the LSD isn't open, the driver side wheel will spine the differential and driveshaft even though the passenger side wheel is disengaged. Even a open differential will spine the driveshaft some due to friction, but with a LSD up front it has no choice but to spine. I have notice a slight pull to the driver side at 60mph+ because of this, but it isn't a bother. I have measured diff temps front and rear after long highway drives and haven't seen anything to worry about. Time will tell if I start to have premature wear, but I really don't think it will be an issue.
    I have driven it a little on the ice in 4hi with no problems. Yes, the transfer case will bind just before the LSD does. If you're binding, you probably have to much grip to need 4wd and start to run the risk of blowing something up at higher speeds.
    Just my 2 cents.
    TodayWasTHeDaY and BassAckwards like this.
  8. May 26, 2022 at 3:56 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yeah, 2hi would be zero binding because of the ADD.
  9. May 26, 2022 at 7:54 AM
    TireFire
    Olympic Peninsula
    ADD delete
  10. May 26, 2022 at 11:01 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Front would b8nd some due to the different rotation on turns
    My White Tacoma likes this.
  11. Jul 25, 2023 at 11:26 PM
    TacoTuesday1
    FL
    Why does ECGS site not show more options like this?
    Under their front clamshell (2nd gen) it only lists elocker and ARB
  12. Jul 26, 2023 at 5:39 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    They are having a hard time getting the Nitro LSD units.
    I know - I ordered one in March...
  13. Jul 26, 2023 at 10:08 PM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    It used to show the T8. Thanks for the clarification, wondering what happened!
