Nitro Gear + Install Kit : 4.88/2016-23/8.75" Rear/Auto w/ E-Locker or Manual// $1400 + shipping
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FATS, Aug 21, 2024.
Thread Status:
Not open for further replies.
  1. Aug 21, 2024 at 7:49 AM
    FATS
    FATS [OP] Well-Known Member
    Fats
    Williamsburg, VA
    2019 TRD OR DCSB
    Tires, tonneau, lights, suspension, cameras, skids
    4.88 Nitro Gear package purchased from Toytec, new in box, unopened. Includes Master Install Kit. I dearly want to get this installed, but the work is beyond my personal capacity and I cannot for the life of me find an experienced shop that will install customer-provided parts in the eastern VA area. Bummer for me, bonus for you.
    I'm not going to open the box in order to maintain the NIB status, but see below for pictures of the box and label, and info about everything included.
    Current price Toytec sells this for is $1650 plus shipping, yours for $1400. Pick it up in person in Williamsburg VA, or pay shipping. The package is just under 50 lbs, 18" x 12.5" x 12", and will ship from zip code 23188.
    Alternatively ... if you know a shop that can & will skillfully install this customer-provided part into a 2019 6MT TRDOR that is within a 2-3 hour drive to Williamsburg, VA, please let me know. Thanks all!
    GPTAC2016-8.75 - Nitro Gear Package (2016-2023 Tacoma with 8.75" Rear)
    The 2016 & Newer Tacoma is a fantastic vehicle, the new engine packs a punch into a fairly small displacement, and needs RPM’s to operate efficiently and at peak performance. We have found the factory gearing to be inadequate even on stock vehicles in many cases. By re-gearing your diffs with a Nitro Gear Package you can restore performance and economy by optimizing the RPM range your engine runs at. We’ve already provided gears for hundreds of the 2016+ Tacoma, with excellent feedback and reports of much better drivability, performance, and economy. Many say that they love that their truck is not constantly shifting, and just feels “right”.
    Here are some rough recommendations based on tire sizes for the average daily driver / weekend warrior:
    • 31"-33” 4.88
    • 34" or larger 5.29 (Great for especially loaded trucks, or towing. Also ideal for 4 cylinder trucks)
    Nitro Complete Gear Package Includes:
    • Front ring & pinion
    • Front Master Install Kit including upgraded solid pre-load spacer
    • Rear ring & pinion
    • Rear Master Install Kit including upgraded solid pre-load spacer
    -Solid Preload spacer replaces stock type crush sleeve improving bearing preload retention, eliminating possible crush sleeve damage if the yoke is impacted offroad and allows the pinion seal to be serviced without complete disassembly of the differential to replace a crush sleeve and reset pinion bearing preload.
    -Nitro Master kits include name brand OE quality bearings.
    Tech Note:
    • *Will not fit Dana built rear axle
    • Fits 3.91 & up carrier.
    • Will work with OEM carrier or ARB - RD111
    • Only fits models with automatic transmissions and OEM E-locker or manual transmission models
    Features:
    • Nitro Rings & Pinions:
      • Manufactured in South Korea
      • 8620 Steel Gear Forgings
      • Precision Machining
      • CNC Triple-lapping
      • Heat Treatment
      • Rockwell Hardness Tested
    • Nitro Master Install Kits:
      • Koyo or OEM Carrier Bearings
      • Koyo or OEM Pinion Bearings
      • Pinion Nut if applicable
      • Pinion Seal Crush Sleeve or Preload Shims or Solid Spacer Carrier Shims if applicable
      • Gasket or Silicone
      • Loctite
      • Gear-marking Compound and Applicator Brush
  2. Aug 24, 2024 at 6:37 AM
    ScaryVersion
    ScaryVersion Well-Known Member
    Lancaster, PA
    2017 Cement PRO DCSB
    OG_Tacoma likes this.
  3. Aug 24, 2024 at 7:42 AM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    I would probably trust ECGS the most to do this job.
    Also..."I cannot for the life of me find an experienced shop that will install customer-provided parts". A major problem I've seen in my area too. I even had a shop turn me away from mounting my tires onto a new set of wheels...because I didn't buy tires (or wheels) from them. Was glad to give them my money for the labor, but oh well.
    Didn't used to be this way :(
  4. Aug 24, 2024 at 10:39 AM
    FATS
    Fats
    Williamsburg, VA
    2019 TRD OR DCSB
    Absolutely, ECGS was the first place I looked. They wouldn’t do it with customer parts, wouldn’t even entertain letting me waive the warranty on the work.
    I will probably end up going to them to buy the parts and get the work done when it’s time … but in the meantime I’ve gotta find someone else who can make better use of these gears that I bought. Real bummer.
  5. Aug 27, 2024 at 3:04 PM
    FATS
    Fats
    Williamsburg, VA
    2019 TRD OR DCSB
    bump
  6. Aug 27, 2024 at 3:13 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Might be a little further than you wanted to drive but I have no idea about their reputation but they will use customer supplied parts.
    and then maybe @Backdoc could offer a recommendation.
    And then I think Mainline Overland in West Chester PA. Good luck!
    FATS[OP] likes this.
  7. Aug 28, 2024 at 5:26 AM
    Lancejoker
    Lancejoker Well-Known Member
    Lance
    Williamsburg,Va
    2017 TRD Pro
    I'm in Williamsburg too. Have you tried Eastern Trucks down in and Accessories in Norfolk? That shop is great to work with. One of the only shops I can find for hours that will rebuild shocks as well.
  8. Aug 28, 2024 at 7:08 AM
    Backdoc
    Backdoc Well-Known Member
    Harford County, MD
    2021 SR5 DCLB
    Bilstein 6112/Eaton Truetrac/RCI sliders Some other stuff
    Try World Tour Off Road in Annapolis, MD. When I talked to them last year they were willing to do a gear swap with customer supplied parts.
    FATS[OP] and hyrule_trd[QUOTED] like this.
  9. Aug 28, 2024 at 7:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Need pictures of the actual items, not the box.
Thread Status:
