Nitro Gear Inventory Blow Out - Metal Tech 4x4
Discussion in 'Metaltech 4x4' started by MT4x4, Oct 6, 2011.
  1. Oct 6, 2011 at 1:01 PM
    MT4x4
    MT4x4 [OP] Metal Tech 4x4 Vendor
    Travis "LT"
    Portland, OR
    07 FJ Cruiser
    Sway Away 2.5 coilovers, MT F&R Tube Bumpers, MT Sliders, Marlin Crawler Dual Transfer Cases
    It's time to clean out our Nitro Gear ring and pinions and accessories to make room for more inventory here at Metal Tech 4x4. We have limited quantities on hand of the items listed below and once they are sold the price is no longer valid. You will need to call in your order since we only have specific parts on the shelf. Contact us at 503-822-1111 ext 1 or 1-800-839-0684 ext 1 Thanks!
    Land Cruiser Gears
    FJ40/55/60 front and rear FJ80 rear
    TLC-456 x 3qty - $187 (Retail $240)
    FJ80 Front Axle
    TLCF-456 x 5qty - $163 (Retail $230) each
    TLCF-488 x 4qty - $163 (Retail $230) each
    TLCF-529 x 3qty - $163 (Retail $230) each
    FJ Cruiser/Tacoma 05+ Gears
    T8S-456 x 8qty - $184 (Retail $300) each
    T8S-488 x 2qty - $172 (Retail $250) each
    FJ Cruiser/Tacoma/V6 third members
    TV6-456 x 9qty - $195 (Retail $215) - requires YOKT60030 - $42 each
    TV6-488 x 2qty - $154 (Retail $208) - requires YOKT60030 - $42 each
    Tacoma non e-locker rear ring gear
    T100-488 x 1qty - $169 (Retail $209) each
    Mini Install Kits
    IK TV6 (works with TV6 ring gears) x 6qty - $18 (Retail $23) each
    IK T8SR (works with T8SR ring gears) x 4qty - $78 (Retail $100) each
    Master Overhaul Kits
    MK TLC-A (works with FJ40/55/60 w/o an ARB air locker) x 3qty - $120 (Retail $156) each
    MK TLC-B (works with FJ80 rear axle or FJ40/55/60 with ARB air locker) x 3qty - $148 (Retail $192) each
    Pinion Flanges
    YOKT60030 (required for TV6 ring gears) x 6qty - $42 (Retail $57) each
    YOKT35021 (old Land Cruiser patterns) x 1qty - $40 each
    Wheel Bearings
    AK TOY-FRONT (front wheel bearing replacement FJ40/55/60, completes one set per side) x 3qty - $30 (Retail $37) each
    Knuckle Rebuild Kits
    KNCLKT-TOY (FJ40/55/60) x 5qty - $73 (Retail $100) each
    KNCLKIT-FJ80 (FJ800 x 2qty - $122 (Retail $140) each
    Nitro Gear Birfields
    AX TBIRF-FJ40 (FJ40 30 Spline Birfields) - x 2qty $484 (Retail $600) each
  2. Oct 6, 2011 at 1:07 PM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Sent you a pm.
  3. Oct 6, 2011 at 1:08 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    PM sent.
