Nitrogen filled tires
Discussion in 'Wheels & Tires' started by Tepidy, Jan 15, 2011.
  1. Jan 15, 2011 at 3:12 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Anybody have any pro's or con's on using nitrogen in tires for off roading. My 350z I use nitrogen to maintain a constant tire pressure which does not go up or down with different temperatures. Great for road and racing but not sure if there are any advantages for off roading.
  2. Jan 15, 2011 at 3:13 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    most people lower their tire to around 10-15psi to off road but most people run around 35 normal so it would be a waste if you were going to be changing pressure a lot
  3. Jan 15, 2011 at 3:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    There really is no pro considering air is 73% N anyway.
  4. Jan 15, 2011 at 3:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    78% :cool:
  5. Jan 15, 2011 at 3:23 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    ah yes...the trump card....
  6. Jan 15, 2011 at 3:24 PM
    98tacoma27
    Ben
    Not Beech Creek
    Hhhmmm..........it's gone up since I was a kid.
  7. Jan 15, 2011 at 3:29 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    So chris providing you are not airing down your tires is it still a waste on a 4x4 to use nitrogen, I use my truck as an everyday driver as well off road (not rock climbing or racing)
  8. Jan 15, 2011 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be the ozone?
    I think its a waste. If the tire isnt going on a race car, or an airplane, I dont see the benafits.
  9. Jan 15, 2011 at 4:11 PM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    A car salesman tried to sell a lifetime warranty of that gimmick shit to me for the tires. I told him the air we where breathing at that second was 78%. I got up and left he chased after me. LOL. FUCKWADS!
  10. Jan 15, 2011 at 4:13 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    Nope, y'all just got the number off a bit. 78% for millions of years.....:D
  11. Jan 15, 2011 at 4:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What are you guys talking about, nitrogen filled tires are good for a gain of at least 5 HP due to decreased friction of the air on the inside of the tire...:rolleyes:
  12. Jan 15, 2011 at 4:23 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    thanks guys.
  13. Jan 15, 2011 at 4:26 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    actually all of you are wrong, the air is ACTUALLY 437.6% nitrogen....... :anonymous:
  14. Jan 15, 2011 at 4:30 PM
    Fienoma
    Fienoma Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    Don't be fooled by their scheme to squeeze more money out of you..My bfg A/T were nitrogen filled..and the pressure was always changing..
  15. Jan 15, 2011 at 4:31 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Not needed
  16. Jan 15, 2011 at 5:06 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Nitrogen does 2 things: (Supposedly)
    1) its grows and shrinks less with temperature so it will help maintain tire pressure
    and
    2) Air molecules will actually migitate through the rubber of a tire over time, SUPPOSEDLY, Nitrogen migitates less through rubber.
  17. Jan 15, 2011 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add:
    The main reason nitrogen came into play in tires, is due to it being inert gas. In a crash, it wont promote a fire, and being "dry", Ice wont build up at high altitudes. Race teams use it so as to more accurately be able to predict how the tire will heat up, as again, no moisture in the N2, it expands, and contracts more predictably.
  18. Jan 15, 2011 at 6:09 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Here is my problem with the whole Nitrogen filling thing.... How do you know if they actually do it?
  19. Jan 15, 2011 at 6:21 PM
    98tacoma27
    Ben
    Not Beech Creek
    Nitrogen is not inert............:p
  20. Jan 15, 2011 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What do you know......You thought there wasw only 73% in the air we breath...:p
