Nitrogen in tirers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomasr1950, Aug 22, 2009.
  1. Aug 22, 2009 at 7:34 PM
    thomasr1950
    thomasr1950 [OP] 19 Tacoma TRD Off Road
    central us
    There have been numerous posts about nitrogen filled tires. What is the overall opinion? I've had 2 service mgrs. suggest i have it, both are about the same price. Is it worth it as far as wear on tires & mpg?
  2. Aug 22, 2009 at 7:58 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    From what I understand, regular air theoretically breaks down the rubber from the inside of the tire, weakening it and causing wear. Practically speaking, I would think you'd be changing tires because of tread wear long before this ever occured. As for MPG benefits, I can't imagine it would even be noticeable, but I admit that I've never used Nitrogen so I am speaking with a big of ignorance on that.
    Personally, I can think of a thousand things I'd spend my money on before nitrogen for my tires.
  3. Aug 22, 2009 at 8:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "Regular" air is 79% nitrogen. Do you really think 21% more is going to have any influence on tire life?
  4. Aug 22, 2009 at 8:01 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    What that guy said :D
    Just a sales pitch, nothing more.
  5. Aug 22, 2009 at 8:04 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I've had Nitrogen in my tries since about 1000 miles... I now have almost 8000... I got it free when I had my new tires installed...
    Temperature variance doesn't effect pressure nearly as much... They have a more stable feel when lateral force is applied (cornering), and I routinely get ~21 mpg... I just got 22.5 on a 600 mile trip from Divide, CO to Telluride, CO and back... through the mountains...
    Seems to work for me...
  6. Aug 22, 2009 at 8:20 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Never noticed a diffrence, G35 or Tacoma. G35 had nitro filled tires when I got new rubber, same with the taco. Filled with reg air after that... no diffrence to me. Like chris said.... air is already 79% nitro.
  7. Aug 22, 2009 at 8:21 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I use "regular" air and I don't have a complaint. Just run them at normal PSI and you'll be fine.
  8. Aug 22, 2009 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Whatever gas is filling the tires, isnt going to affect lateral capability. Psi, tire composition, design, and suspension play those roles. ;)
  9. Aug 22, 2009 at 8:23 PM
    TL697
    Jacksonville, FL
    I'll be honest, if it wasn't free, I would have gone with air...
  10. Aug 22, 2009 at 8:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    If I'm currently using dino air, can I switch to synthetic air or just stick with dino?
    Furthermore, would premium air be more cost effective than regular?
    And, should I do this myself or take my truck to the dealership?
  11. Aug 22, 2009 at 8:29 PM
    jandrews
    '09 FourDubDee TRD OR
    This.
    What the hell is it with Nitrogen these days? First Shell's bullshit, now this.
    FWIW, I've noticed Diamond Shamrock gas in my area seems to butt dyno better than Shell's nitrogen "enriched" stuff.
  12. Aug 22, 2009 at 8:30 PM
    TacoNut
    Adam
    Denver, Co
    Your welcome
  13. Aug 22, 2009 at 8:30 PM
    Incognito
    VA
    :laugh:
  14. Aug 22, 2009 at 8:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many people dont realize this, But the number one product that increases carbon build up in an engine is...........ready for this???
    NITROGEN!
    Its all marketing hype, and if Shell is really "Infuseing" more nitrogen (which is already in the gasline molecule) into their fuel, they are dolts, and must be hit with a fish.
  15. Aug 22, 2009 at 8:36 PM
    brickisred
    brickisred Well-Known Member
    (still) Looking for Tacoma Prerunner 2wd
    Doesn't Chevron with Techron gas have nitrogen in it also?
  16. Aug 22, 2009 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    TacoNut gave some valid answers, But I would like to add:
    "If I'm currently using dino air, can I switch to synthetic air or just stick with dino? "
    If you are going to switch to Synthetic, its best to do so when new....Most synthetic air, when added to a tire with higher milage, say 150,000 miles, could possibly cause an oil leak
    "Furthermore, would premium air be more cost effective than regular?"
    Only if the tires are designed to run with Premium air. You should be able to tell, as they will have knock sensors on them.
    "And, should I do this myself or take my truck to the dealership?"
    I wouldnt take it to the dealership. Many times you think you are getting Premium air, or synthetic, but they give you the same old air thats been in the atmosphere for eons.
  17. Aug 22, 2009 at 8:48 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Thanks, that's great info. I knew I could count on you guys.
  18. Aug 22, 2009 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :d
  19. Aug 22, 2009 at 9:20 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    Damn, my kinda thread and I missed it!
  20. Aug 22, 2009 at 9:57 PM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Nitrogen=Nonsense
