Nitrogen in tirers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomasr1950, Aug 22, 2009.
  1. Aug 22, 2009 at 10:39 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    ROTFL! Just got a very vivid image in my head of a guy being slapped with a 30 lb. steelhead--"Three Stooges" style.:D
  2. Aug 22, 2009 at 10:56 PM
    TacoOwner?
    TacoOwner? Well-Known Member
    Joshua
    Camas/Spokane, WA
    '10 4x4 Double Cab 6M
    Anti-thief tailgate, anytime rear-view camera, anytime locker mod
    I think nitrogen filled tires expand and contract less than oxygen during temp and elevation changes...I just check tire pressure often.
  3. Aug 22, 2009 at 11:24 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Yea I always make it a point to check my tires at 30,000ft cruising altitude also...
    wait...
  4. Aug 22, 2009 at 11:29 PM
    TacoOwner?
    Joshua
    Camas/Spokane, WA
    That is the pitch, and as stated above oxygen is already 79% nitrogen...
  5. Aug 22, 2009 at 11:37 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I know for a fact, from first hand experience, that nitrogen does very well at maintaining a specific pressure and is not a gimmick. I used nitrogen in my race slicks for years with much success.
    As for if it is worth it... I would not pay any more than what you would to have your tires filled with compressed air. In a street car, the difference between cold and hot tire pressures are negligible. If anything, once the tire is warm your tire pressure will increase, causing you to in theory gain MPG.
    FWIW, quite a few large tire service chains will fill your tires with nitrogen for no charge.
  6. Aug 23, 2009 at 12:06 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Can't tell the difference.
  7. Aug 23, 2009 at 1:30 AM
    Cheesycook
    Cheesycook Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    This was popular with a few of my musclecar buds back in florida because it was dry. You average shop didn't use a drier on their compressors so filling a tire was like an excited kid with a lisp spitting in your face as he talks. Not good. Also, nitrogen molecules are larger than oxygen and many other components of ambient air so it cuts back on leakage over time. Okay if free for a daily driver, not worth it for a rig that gets aired down for traction all the time.
  8. Aug 23, 2009 at 8:45 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Good for race tires, we used in the sprint car tires when we ran at PIR on the asphalt where heat would grow the tire so much that it would change the set up as they got hotter. The nitrogen helped a lot.
    On a street car just stick with nice fresh dry Arizona air:D.
  9. Aug 23, 2009 at 10:36 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Aircraft tires use nitro just because of the temp and pressure changes. And the amount of weight put on the tires. No need for it on a normal vehicle.
  10. Aug 23, 2009 at 12:09 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^OK, so here's a question: What effect does nitrogen have on a tires load carrying capacity? I ask because I see you are a Navy flight engineer so I assume you will know.
  11. Aug 23, 2009 at 12:43 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    nitrogen is an inert gas, so the temp has minor effects
    also the molecule is a bit larger
  12. Aug 23, 2009 at 12:44 PM
    rmb_crew
    Well aircraft tires are a lot thicker and hold about 5 times the amount of air pressure than a normal car tire does, Also the more weight the more pressure we have to service the tire to. The big thing is that the tire filled with nitro will hold pressure longer than a tire that is filled with normal air, so in the long run it will hold the weight better and stand a better chance of holding that air pressure with more weight and harder impact. It will also make the tire last longer due to nitrogen is more resistant to moisture forming inside the tire. Thats just a few of the reason why we use it in the aircraft tires. To me its not worth paying for nitrogen in a truck. Maybe a big mac truck or something.
  13. Aug 23, 2009 at 12:46 PM
    rmb_crew
    Yes but the extreme temp changes an aircraft is subjected to it does make a difference. If you think about it we take off and the temp down here in florida is 35 degrees Celsius and at cruise alt its probably -10 or so degrees Celsius. So its a big change in temp.
  14. Aug 23, 2009 at 12:48 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Benefits from using pure nitrogen in tires? Nonsense. It's just a way for the purveyors of this "technology" to suck a few more $$ out of the uninformed.
  15. Aug 23, 2009 at 12:51 PM
    #35
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Thanks for the explanation!
  16. Aug 23, 2009 at 12:53 PM
    #36
    rmb_crew
    No problem.
  17. Aug 23, 2009 at 12:53 PM
    #37
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    last time I checked it was -43 but the EICAS could be wrong
    EICAS Warning
    < kick >
    it is ok now
  18. Aug 23, 2009 at 12:55 PM
    #38
    rmb_crew
    Jacksonville, FL 30.243103, -81.591007&#8206;
    EICAS warning?
  19. Aug 23, 2009 at 1:02 PM
    #39
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    Engine Instrument and Crew Alerting System
  20. Aug 23, 2009 at 1:06 PM
    #40
    rmb_crew
    HAHA all that fancy stuff. In the P3 world we dont have all the automated stuff. Thats what my job is! :D
